    Watch beep and show message charging over and over when 99-100%
    46 Posts 13 Posters 6.8k Views 11 Watching
    • Ádám PatkósÁ Offline
      Ádám Patkós
      Hello!
      My Suunto 5peak behaves the same way. I don’t think it’s a problem. I have been using it for more than 6 months.
        A Former User @Tomas5
        @Tomas5 Any news on the S5P in relation to the charging?
        • Tomas5T Offline
          Tomas5 Gold Members @Guest
          @skifun based on communication with seller and service for central europe, it is going for warranty check to service. I head to post office today.
          • Tomas5T Offline
            Tomas5 Gold Members @Ádám Patkós
            @Ádám-Patkós thank’s for info, as i mentioned above seller and service center suggested to sent it to them for check. I will post result as soon as i get any new info. But I didn’t have much time so I am only today going to post office to sent it.
            • Tomas5T Offline
              Tomas5 Gold Members
              So today watch arrived from service with message:
              I have checked your device for faults reported in the fault description and performed all the necessary tests, and no fault has been discovered. WATCH ONLY INFORM YOU THAT THEY ARE FULLY CHARGED.
              So I don’t understand, watch even don’t have message that they are fully charged but “qualified” servician says it only informs me that it is fully charged.
              And it looks like they even didn’t bother to disable power saving mode (or they enabled it again before sending back but watch was set up exactly like when i put it into box). So watch couldn’t beep at all if I am not mistaken.
                @Tomas5 So, do you accept this or perhaps you’re returning the watch? If this kind of behavior of the watch is by design, there’s nothing you can do but use as it is.
                • Tomas5T Offline
                  @skifun well i am not able to return it. Since they claim it is ok. But do you think this behavior seems correct? I recorded video of this behavior https://www.dropbox.com/s/uwfr7wiv9f72plt/FullSizeRender.MOV?dl=0
                  As soon as charged, watch starts to do this, I am afraid to let in on charger to see for how long it will do this. So i disconnect it every time as soon as this starts to happen. But if this is “by desing” than i am afraid I am not target group of suunto anymore 😞
                    sartoric Moderator @Tomas5
                    @Tomas5
                    Did you check the charging clamp and cable ?
                    Suunto App Android 6.3.3 beta
                    • Tomas5T Offline
                      Tomas5 Gold Members @sartoric
                      @sartoric 2 different chargers, and laptop as pover source, i tried cable which arrived with S5Peak, i tried cable from my S5 and i tried even 2 old calbles from Ambit 2 watch. All the time same result.
                      Tomas5T sartoricS 2 Replies Last reply Reply Quote 0
                      • Tomas5T Offline
                        Tomas5 Gold Members @Tomas5
                        I never let it beep for longer than 2 minutes because i am concerned how it will impact battery when it starts charging multiple times per minute when battery fully charged.
                          @Tomas5
                          Did you ever try to connect it to a wall charger?
                          Maybe it’s the laptop that is disconnecting and reconnecting while fully charged
                          • Tomas5T Offline
                            @sartoric well as i answered you two posts above. 2 different chargers and laptop still same behavior. And as i mentioned multiple posts above. All chargers i tried with my older S5 and they don’t behave so strange like this S5P.
                            • Tomas5T Offline
                              To be more specific i think it was samsung charger, htc charger, and thinkpad laptop.
                                @Tomas5
                                Oh,ok I missed it
                                I supposed you were always using laptop as power source
                                Well, so based on others replies and support report it seems to be normal on 5peak.
                                I’ll ask a friend that has a 5 peak too
                                Tomas5T 2 Replies Last reply Reply Quote 0
                                • Tomas5T Offline
                                  @sartoric well only one person here says it has same issue. So i am not sure if normal is right way to say it. But i have some knowledge on electronics and i see that this is clearly bug or design fault 😞
                                  • Tomas5T Offline
                                    @sartoric I am curious what your friend with S5P will say.
                                    Ádám PatkósÁ 1 Reply Last reply Reply Quote 0
                                      Ádám Patkós @Tomas5
                                      @Tomas5 hi
                                      I think there is nothing wrong with the watch.
                                      its battery is very strong. It can easily last 7 days with 4 training sessions per week.
                                      Tomas5T 1 Reply Last reply Reply Quote 1
                                      • Tomas5T Offline
                                        @Ádám-Patkós i hope you are right and it will be ok. Two of my other suunto watch don’t behave like this. But i don’t have any other possibility just to use it as it is.
                                        ADHDMonkeyA 1 Reply Last reply Reply Quote 0
                                        • ADHDMonkeyA Offline
                                          ADHDMonkey Bronze Member @Tomas5
                                          @Tomas5 you should have returned it while you were within the window. It’s not normal behaviour. Clearly a dodgy unit. I would insist o a replacement if I were you. Maybe video it and share with customer support?
                                          • Soojong MoonS Offline
                                            Soojong Moon
                                            Not sure but I would try these.
                                            • restart watch. If no successful, do factory reset
                                            • change adapter to old one which do not support fast charge
                                              (ex. 5w adapter for old iphones or similar ones)
                                            • full charge and discharge. Then, full charge again.
                                            S9BT, A3P, Suunto Smart Sensor, Polar OH1
                                            iPhone13 Pro Max (iOS), Windows10
                                            Feature Suggestions:
                                            1)Activity Planning with basic analytical function.
                                            2)Basic Training Gear Management connected to Strava or Runalyze.
