    For s9p and s9b
    18 Posts 7 Posters 2.7k Views 7 Watching
    • O Offline
      outtatime
      It has a way of manually setting altitude.
      But some weather stations give it in inches of mercury.
      Be nice to set it using either.
      Brad_OlwinB ? 3 Replies Last reply Reply Quote 0
        Brad_Olwin Moderator @outtatime
        This post is deleted!
          @outtatime I do not ever set altitude manually on the watch. There is an auto-calibrate altitude feature that I have used. Typically I just let FusedAlti do its job when exercising. Why do you need to set the altitude manually?
          • O Offline
            outtatime
            Maybe not all the watches fault, but drive across town and come back home the baro will be off about 50 feet.
            freeheelerF Brad_OlwinB 2 Replies Last reply Reply Quote 0
              freeheeler @outtatime
              @outtatime
              the reason could be various… assuming you just look at altitude in watch mode? or does this happen during an activity?
                @outtatime said in For s9p and s9b:
                I drive ~ 25 miles to and from work where the actual altitude difference is about 500 or 600 feet. My watch is typically within 100 feet of the actual altitude. Typically our weather is responsible for the change. Once I do an outside exercise the altitude is correct. I just let fused Alti do its job.
                  A Former User @outtatime
                  @outtatime there was an interesting post (search the forum) about the matter. Long story short: FusedAlti is used, of course, inside an activity session and when you use the watch as watch, so there’s no need to manually set the altitude reference in both cases as suggested by the other people. Since then I’ve never manually corrected the altitude even if the weather is changing… and it is almost always spot on
                  TieutieuT renton82R 2 Replies Last reply Reply Quote 0
                    Tieutieu Platinum Member @Guest
                    Interesting : I have an opposite behaviour to set up altitude on my S9B…I calibrate it always manually when I’m on an known reference altitude. I found the automatic calibration far too long and not as precise.
                    Derivation highly depend on weather changes. I live at 282m high. Doing some large car travel for work, I have often up to 40/50m derivation. When staying at home it never reach more than 20m.
                    I
                    Suunto Wing & Spark
                    ? freeheelerF 2 Replies Last reply Reply Quote 0
                      A Former User @Tieutieu
                      @Tieutieu said in For s9p and s9b:
                      sure but, at least on my S9P, as soon as I move altitude is being corrected
                        @gi0vanni I also noticed that derivation on my wife’s S9P is far less important than on my S9B. Perhaps I missed a setting on my watch ?
                        Suunto Wing & Spark
                        ? O 2 Replies Last reply Reply Quote 0
                          I do not think so.
                          Just to be sure things work as intended try to manually set altitude to a crazy value. It should be corrected within ~15min by FusedAlti.
                            freeheeler @Tieutieu
                            @Tieutieu
                            you can avoid this extra effort 🙂
                            FusedAlti will adjust after around 15minutes and overwrites your manual adjustment if necessary. you can try: set it 2’000m wrong, after 15min in activity (with satellites) it corrects altitude.
                            it works like a charm 👍
                              sartoric Moderator @freeheeler
                              @freeheeler said in For s9p and s9b:
                              I’m not sure about this.
                              Maybe there’s something new in the latest firmware but afair, if you manually set the altitude before starting the activity, FA won’t kick in
                              SVTS - 2.50.28
                              Suunto App Android 6.10.7 beta
                              • renton82R Offline
                                renton82 Platinum Member @Guest
                                @gi0vanni said in For s9p and s9b:
                                … FusedAlti is used, of course, inside an activity session and when you use the watch as watch, …
                                I don’t think FusedAlti works outside of an activity, maybe am i missed something?
                                  freeheeler @sartoric
                                  @sartoric
                                  no, that was until some years ago. you can manually adjust whenever you want… FusedAlti knows it always better 😉
                                  • O Offline
                                    outtatime
                                    Over a significant travel distance you could expect the baro to change. But as far as fusedalti, it working without gps might operate the same as just watch mode.
                                    • O Offline
                                      outtatime @Tieutieu
                                      S9P apparently fixed some of the problems that S9B had.
                                      • O Offline
                                        outtatime @freeheeler
                                        @outtatime
                                        It looks like it can be off on the activity mode as well. So it’s not just baro. Gps has its own ellipsoid that it follows and is a rough estimate of altitude.
