    Suunto Vertical GPS Problem?!
    34 Posts 10 Posters 4.4k Views 9 Watching
      @twekkel keep in mind that gps recording is not the same as polling of 1s. That means that even if the 1s frequency is used it does not mean that it will record every 1second if on second xx the quality of the signal is not acceptable.
      Also keep in mind that gpx files are xml files and it’s not so well structured for data.
        @Dimitrios-Kanellopoulos if XML isn’t structured, what is? 🙂
        Indeed a very poor GPS signal might have prevented to write accurate lat/lon. So for now I “blame it on the forest”.
        GiPFELKiNDG Dimitrios KanellopoulosD 3 Replies Last reply Reply Quote 2
        • GiPFELKiNDG Online
          GiPFELKiND Silver Members @Guest
          @twekkel
            @twekkel look there the beginning with good tracking is in the woods… The rest when terrible tracking open field without trees
              GiPFELKiND Silver Members @GiPFELKiND
              @GiPFELKiND Screenshot_2023-05-21-19-54-34-574_com.stt.android.suunto.jpg Screenshot_2023-05-21-19-54-42-917_com.stt.android.suunto.jpg
                @GiPFELKiND any questions!? 😭😭😭😭😭
                ? freeheelerF 2 Replies Last reply Reply Quote 0
                  A Former User @GiPFELKiND
                  @GiPFELKiND if this was a one time bad track, I wouldn’t worry about it. It can happen, although this particular example is pretty bad with so much open field.
                  Even with the best GPS watch out there, SV, it isn’t always perfect. If this issue persists with other activities also, I would go or a warranty claim. Upcoming firmware update (June?) might also improve the situation.
                    freeheeler @GiPFELKiND
                    @GiPFELKiND
                    it would indeed be interesting to see if you can replicate this with another activity in case you have some spare time to do something similar now/soon.
                    I haven’t seen this kind of tracks in any watch.
                      @twekkel Screenshot_2023-05-21-21-28-06-493_com.vecturagames.android.app.gpxviewer.jpg
                      Also I analyse my track with app. And see what mystery I see… When this lines come my speed is 30 km/h NEVER NEVER… is my hand shaking when i run the problem?!
                        @GiPFELKiND
                        this for sure is not arm movement.
                        again: record another activity and if it is the same again -> logs.
                        maybe it is a one time issue and never happens again. we will only know with more samples. until then all we can do is guessing
                          GiPFELKiND Silver Members @freeheeler
                          @freeheeler Screenshot_2023-05-22-05-45-20-940_com.stt.android.suunto.jpg good morning community, today morning next run! And nothing so bad like the first run! Looks so good! Good start to you all in this new week 😊
                          ChrisAC 1 Reply Last reply Reply Quote 4
                            zhang965
                            Suunto watch generally has some spindle during the first GPS tracker, it’s kinda normal.
                            • ChrisAC Offline
                              ChrisA Platinum Member @GiPFELKiND
                              @GiPFELKiND that looks a lot better 👍🏻. Have a nice - good GPS tracking - week too!
                              Currently Race I
                                @twekkel exactly for that reason is bad. Sensor data are not structured on the top level entity (tree) such as the xml. They are streams, or lets say messages.
                                For example the limitation that XML has is that the parent entity is a trackpoint and inside that you get the sensor data. So that essentially means that if you dont have a trackpoint then you cannot have sensor data. For example inside a tunnel all points are lost
                                • trckpoint
                                  • HR
                                  • Speed
                                While on fit files for example we have messages that can contain any info and are just a timestamped payload.
