    Battery drain
      Mff73
      for those more expert than me and knowing how to make a dump log of android suunto app, some of the files are containing regular battery gauge informations 😉
      I charged my SV today morning, from 1% to 100% : it is there 😉
        surfboomerang
        No issues here. Battery drains as before the update.
        • W Offline
          wasajones
          I was experiencing the battery drain (1% / hour). After a couple of recharges from 20% to 100%, and turning off and on it seems like battery is performing as normal now. I don’t know if battery will drain fast again after my today’s workout (will update).
          W 1 Reply Last reply Reply Quote 1
          • Antoine LancrenonA Offline
            Antoine Lancrenon Bronze Member
            I will turn off the notification from Cell on my watch to see the impact on the battery.and see if it is worth it. it looks like notifications are pretty battery foody…
            I will finish discovering why my battery never last more than 10 days. I am tired in looking now.
            • stromdiddilyS Offline
              stromdiddily Gold Members
              Ok - I’m finally back to a normal rate (and actually have seen some definite improvements in drain during activity).
              Started with 40% after update
              Drained down to less than 10% and full charge
              Still saw worsened battery life so allowed another drain to sub 10%
              Soft reset, full charge back to 100%
              Now I’m at 94% after two days of all day/night wear and 3 hours of GPS activities.
              • I Offline
                Iggge
                My Vertical just went from 19% to 9% during night. That’s new. Soon 0% and then I will charge it to 100%
                  Egika Platinum Member
                  Still valid:
                  Q1:
                  https://forum.suunto.com/topic/9960/more-faq
                    Mff73 @Iggge
                    @Iggge
                    https://forum.suunto.com/post/149372
                      MeazzaS9 @Egika
                      @Egika ok thanks, for the problem of abnormal battery consumption do you have to follow the guide so between 10% / 20% recharge or completely discharge the battery to re-calibrate it?
                        Egika Platinum Member @MeazzaS9
                        @MeazzaS9 as written in the FAQ section. A discharge to 10-20% battery followed by a full charge will be sufficient.
                          MeazzaS9 @Egika
                          @Egika ok thanks, some say to bring it to 0 and then reload. I wanted to be sure
                          • gerasimosG Offline
                            gerasimos Bronze Member @Dimitrios Kanellopoulos
                            @Dimitrios-Kanellopoulos everything is perfect now!
                            1. Soft reset
                            2. Full circle 0-100%
                            Stable and powerful again. 💪
                            Even the indication of battery at full charge saw me 100% and not 99% as previews updates 🔺
                            Suunto Vertical Ti
                            Suunto S9 gen1
                            Suunto Ambit3 peak
                            • Tami999T Offline
                              Tami999 Silver Members @gerasimos
                              @gerasimos said in Battery drain:
                              That’s not becouse of update. I got Vertical since November 2023, and sometimes it was charge always to 100%, battery jumps 98 ->99 and 99-> 100 at same “length- time”, but sometimes stop at 99%, and this 1% was added like after additional 30 minutes or something.
                              • Emi OrtizE Offline
                                Emi Ortiz @Marton Attila
                                @Marton-Attila just same…
                                • I Offline
                                  Iggge
                                  Do a full recharge from 0%- 100% did fix the problem for me altso.
                                    duffman19
                                    I did a full discharge cycle yesterday (0-100%), left the watch on a table overnight (upside down, no OHR), and it is now at 90%. Something is surely amiss.
                                    Battery drain during activity seems to be ok, but there are clearly some issues with daily wear.
                                      Mff73 @duffman19
                                      @duffman19
                                      B D 2 Replies Last reply Reply Quote 0
                                        borgein @Mff73
                                        I have a weird issue with my batteri on the recent firmware. I discharged it fully to 0% and waited for the watch to turn off. Then I charged it to 100% and left it on the charger at 100% for a few hours to make sure it was fully charged. I did this because from battery level 40% and below the battery level dropped drastically, up to 15% during one day even without activities.
                                        Then I used it for a day like normal and saw that the battery drained to 97% after one day, which is all normal. Then I was out in the sun for 20 minutes and now the battery is back at 100%… I’m fairly sure the solar charging didn’t charge 97>100% after 20 minutes of sun exposure… So it seems like the battery calibration is just pure hit and miss?! Never experienced this type of inaccurate battery level on any device since NiMH and NiCd batteries went away…
                                        Suunto App username: borgeindergaard750
                                        Sportstracker (Suunto App) profile: https://www.sports-tracker.com/view_profile/borgeindergaard750
                                        • SuperFlo75S Offline
                                          SuperFlo75 Silver Members Bronze Member @borgein
                                          @borgein I see this behavior with solar charging with a hight battery load above 95% too… but not only after the latest update, but just before for some month. You can load from 97% to 100% in some minutes 😂 At the battery level above 95% there was a crazy behavior with solar charging from the beginning, but always a bit different. Sometimes I didn‘t see the solar symbol loading in plain sun above 95%… and they wrote here this was to protect the battery from overcharging… 🤔 but nevertheless, I like my watch!
                                          Suunto Spartan Ultra
                                          SA iOS 3.5.1 (20789)
                                          Instagram @superflo75
                                            duffman19 @Mff73
                                            @Mff73 said in Battery drain:
                                            @duffman19
                                            I saw this. Not sure what you’re trying to tell me. I am on 2.35.34 and have now fully drained the battery twice (which would have been near impossible on previous firmware in such a short time) and am still seeing odd behavior. Is @Dimitrios-Kanellopoulos suggesting there is a fix in the works?
