    Battery drain
    729 Posts 133 Posters 168.9k Views 115 Watching
      GKnoll
      For the Suunto Vertical is there an option to display the battery % or hours remaining during an activity such as running?
      I’ve looked at the Sport Mode Customisation options and could not see it there.
      I need this option for some events so I can plan for re-charging the battery in good time.
      SamuelPS 1 Reply Last reply Reply Quote 0
      • SamuelPS Offline
        SamuelP Bronze Member @GKnoll
        @GKnoll just long press the lower button to acces the “control panel”. It shows “battery %” and “hours left”
        Vertical All Black
        BrunoHB G 2 Replies Last reply Reply Quote 1
        • BrunoHB Offline
          BrunoH Gold Members @SamuelP
          @Samuel-Pirttikangas a quick reminder. Not all of us have Control Panel configured to the lower button long press. I used to have, but I had to change it because of the Control Panel carousel rendering problem. The problem stopped when I moved it to mid button short press. Weird, I know!
          Compasses: M-311, A-10, SK-7
          SportsfreundS SamuelPS 2 Replies Last reply Reply Quote -1
          • SportsfreundS Offline
            Sportsfreund Bronze Member @BrunoH
            @BrunoH er meint wenn du die untere Taste während einer laufenden Aktivität gedrückt hälst.
            • SamuelPS Offline
              SamuelP Bronze Member @BrunoH
              @BrunoH i ment if you hold down the bottom button during an ongoing activity then you get battery stats. 🙂
              Vertical All Black
                GKnoll @SamuelP
                @Samuel-Pirttikangas Thank you!
                • MarioPedrazaM Offline
                  MarioPedraza @OnlyoneKenobi
                  @OnlyoneKenobi Oops, sorry. Mine goes to technical support on Tuesday. I’ll cross my fingers.
                  • Abu bakar UmarA Offline
                    Abu bakar Umar @Klaane
                    @Klaane said in Battery drain:
                    The battery on my Suunto Vertical Solar has dropped from fully charged to 55% in only two days. Last night it dropped by 15% while I was sleeping with the watch on.
                    I have mobile notifications and 24/7 HR turned on but it still shouldn’t drain that fast, right? Standby backlight is off and I’ve used GPS for less than 10 minutes during those two days.
                    Do I have a defective battery or could this be some other issue?
                    It sounds frustrating! While mobile notifications and 24/7 HR can drain the battery, a 15% drop overnight seems excessive. Try resetting your watch or updating the firmware. If the issue persists, contacting Suunto support might help. 🔋
                    • Devil SchemeD Offline
                      Devil Scheme Banned
                      This post is deleted!
