    Battery drain
    • jjpazJ Offline
      jjpaz Bronze Member @thanasis
      @thanasis Did you enter preactivity menu and exited without starting activity? I’ve noticed that after this procedure the fast battery drain starts.
      It seems like GPS is not deactivated or something like that and keeps draining battery in background.
      martintrailM TrailEyesT 3 Replies Last reply Reply Quote 0
      • martintrailM Offline
        martintrail Silver Members @jjpaz
        @jjpaz I thought this was already fixed. Or? maybe I’m wrong 🙂
        Vertical 2 Titanium
          @jjpaz no, sorry, it was power “consumption remained high after navigation”
          Vertical 2 Titanium
          • TrailEyesT Online
            TrailEyes Gold Members @jjpaz
            @jjpaz This is the action I’ve noticed too. The seconds stay visible when I do this (pull up activity screen but don’t actually start an activitiy). Like you said, GPS or something must stay active, which prevents the watch from going back into its more “dormant” state of time mode.
            Suunto Vertical 2 / Run / Vertical / 9 Peak Pro (gifted away) / 9 Baro / 5 Peak (lost on adventure) / Vector
            Instagram: @rytipps
              larrybbaker
              Decided to track battery life and here is what I found:
              Full charge on 11/10 down to 4% on 11/27.
              this included 14 hrs and 13 min of GPS usage tracking 81.6 miles.
              This is not my daily wear watch and I have no notifications, 24 hour HR or sleep tracking enabled. I use a chest strap for all activities.
              Vertical Ti Solar
              Race 2
              iPhone 17 Pro
              • thanasisT Offline
                thanasis Bronze Member @larrybbaker
                The battery issue is getting really crazy at times .
                Lost 15% today which just 1.5hours of training and the rest was the watch resting … at home
                SuperFlo75S 1 Reply Last reply Reply Quote 3
                • SuperFlo75S Offline
                  SuperFlo75 Silver Members Bronze Member @thanasis
                  @thanasis I also noticed that the battery consumption gets worse… I‘m at 33% after 13 days… and I did‘t change anything 🙈
                  SA iOS 3.5.1 (20789)
                  Instagram @superflo75
                  thanasisT L 2 Replies Last reply Reply Quote 2
                  • thanasisT Offline
                    thanasis Bronze Member @SuperFlo75
                    @SuperFlo75 said in Battery drain:
                    that’s a lot better than mine though! 67% drop in 13 days leads to 5.3% per day!!!
                    i am seeing like 15% per day!!
                      larrybbaker @SuperFlo75
                      @SuperFlo75 It seems to me that the drain accelerates as the battery decreases. 😕
                      I have been holding goff on a hard/factory reset - but may be willing to try it if we don’t hear any more about a forthcoming update…
                      Vertical Ti Solar
                      Race 2
                      iPhone 17 Pro
                      • Francesco PaganoF Offline
                        I saw a new thread on this issue this morning, and now reading these posts. I’m a S9PP user and I noticed an uncommon battery drain in the past 2 days. I ended I run with 91% battery on Sunday morning, yesterday I did nothing so I didn’t even look at my battery charge status, this morning I woke up with 68% 😱 And it’s at 66% now after 2 hours.
                        The only “new” thing for me was update ZS app.
                        S9PP
                        S5
                        • t-DoxT Offline
                          t-Dox
                          hi, i’m also experiencing battery issues on my 9PP. I never reached the 21 days of battery life with 24/7 monitoring as promised by suunto, but usually the battery lasted me 10-12 days with 3-5h of activity per week. Since the last update, however, I have to recharge the watch every 4-5 days with 1h of activity. I tried to open a specific thread for the 9 peak pro, since, even though they share some of the hardware, it is a different watch from the suunto vertical (it does not have maps, it does not have solar charging, it is smaller and will have a smaller battery, …) but the thread was blocked as a duplicate of this one. mistakenly.
                          Andrea
                          9pp
                            I really don‘t know why this problem got worse now… for me it startet with the Summer Firmware Update and the new watchfaces choosable in the SA… and I think with using the new ZoneSense App (including the use of the heart rate belt)… before the time of ZoneSense I didn’t use the belt very often with the Vertical… perhaps I will delete ZoneSense before the next battery loading to learn more about the impact of ZoneSense on the battery drain?
                              A Former User @SuperFlo75
                              @SuperFlo75 I always use the belt, which is essential for ZoneSense and should help the watch consume less battery. I consistently disable wrist HR, sleep tracking, and 24/7 HR. With this setup, my battery consumption is normal (1-2% per day without activity and 2-10% per activity depending on map usage). Whenever I adjust exercise options, I perform a soft reset on the watch after the activity. Without this reset, I notice a battery drain issue, which I hope will be addressed in the Q4 update that should logically be released by year-end, though I have no confirmed information about it. (Suunto Vertical and Suunto Smart HR belt)
                                larrybbaker
                                I finally broke down and did a factory reset, reloaded everything and now will track battery usage again… Only issue so far after my reset is the Zonesense - while it showed up in the watch and tracked the activity appropriately - I cannot get it to show up in SA for yesterday’s activity. Older activities it is showing up correctly.
                                Vertical Ti Solar
                                Race 2
                                iPhone 17 Pro
                                  SuperFlo75 Silver Members Bronze Member @Guest
                                  @iterumtenta I have my SV since mai 2023, and I always used 24/7 HR and sleep tracking… and I normally had no problems with wrist HR, so I didn’t use a HR belt. Usually I had to charge my watch every 4 weeks with about 3-4 hours activity per week… but today, I‘m at 25% after 15 days 🥲
                                  O 1 Reply Last reply Reply Quote 3
                                  • O Offline
                                    Outdoorsy @SuperFlo75
                                    @SuperFlo75 15 days? I bought mine in April 2024 and the battery life never exceeded more than 2 weeks. I go for short walks at lunch, 24/7 HR, sleep monitoring and occasional hikes. I lose about 8% a day. If i have to turn off the basic functions of the to use it, then the watch is useless for me.
                                    I’ll be happy having 25% battery after 15 days.
                                    Previous: Ambit 2, Ambit 3 Peak HR, 9 Peak Pro
                                    Current: Vertical non-solar
                                    SuperFlo75S Dimitrios KanellopoulosD 2 Replies Last reply Reply Quote 1
                                      SuperFlo75 Silver Members Bronze Member @Outdoorsy
                                      @Outdoorsy this seems to be too much battery consumption? Far away from the promised power you can read on the Suunto website? 🤔🥲
                                        Dimitrios Kanellopoulos Community Manager @Outdoorsy
                                        @Outdoorsy 8% is pretty much what I get as well with everything on
                                        AntoineA K 2 Replies Last reply Reply Quote 0
                                        • AntoineA Offline
                                          Antoine Bronze Member @Dimitrios Kanellopoulos
                                          @Dimitrios-Kanellopoulos said in Battery drain:
                                          Dev team is still working on battery drain issues or corrections have been found ?
                                          8% per day seems to me already high. It was not the case when i bought the vertical i think 1,5 year ago
                                          Suunto vertical solar
                                          Coros arm HRM / Suunto wing 2
                                          Android A55 Samsung
                                          • K Offline
                                            Kramble @Dimitrios Kanellopoulos
                                            And this is not normal compared to the first time of the Vertical.
                                            Like @SuperFlo75 :
                                            I have my SV since June 2023, and I always used 24/7 OHR and sleep tracking and I didn’t use a HR belt.
                                            Usually I had to charge my watch every 4 weeks with about 3-4 hours activity per week.
                                            That was pretty much what we can read on the official Suunto website at the launch.
                                            Today can you get the 60 days , even without OHR and sleep tracking ? I am really not sure.
                                            There is a little battery drain since summer 2024.
                                            Ambit 3 peak saphir
                                            Spartan Ultra (sold)
                                            S7 graphite copper
                                            S9 peak all black
                                            Wings
