    Suunto Smart Sensor HR Monitor No Longer Pairing
    11 Posts 5 Posters 4.3k Views 5 Watching
    • stromdiddilyS Offline
      stromdiddily Gold Members
      Have been using a Polar for a while but just switched back to the Suunto sensor to make it easier in the gym.
      Sensor will not pair to my vertical or my phone. Replaced the battery, still no connection. Any tips or tricks from folks here using the same HR monitor?
      Mff73M EgikaE 2 Replies Last reply Reply Quote 0
        Mff73 @stromdiddily
        @stromdiddily
        Put the battery in the wrong polarity during 3s to reset the sensor (potentially 😊), and place it back normal and check.
        New batteries can also be faulty, so another fresh battery can be tested also.
        SSU (retired), SV1, SV2
        Android + Galaxy S205G
        • EgikaE Online
          Egika Platinum Member @stromdiddily
          @stromdiddily sure you are using the correct battery? Suunto’s belt is using CR2025, not the more common CR2032.
          The belt will switch on when it has skin contact only.
            Tieutieu Platinum Member @Mff73
            @Mff73 said in Suunto Smart Sensor HR Monitor No Longer Pairing:
            @stromdiddily
            It this manipulation an “official one” ? I had the issue few month ago : impossible to pair my smart sensor depsite it had always worked perfectly…I had tried everything (changing strap, battery…).
            I had to buy another one.
            Suunto Wing & Spark
            • EgikaE Online
              Egika Platinum Member @Tieutieu
              @Tieutieu yes
                Tieutieu Platinum Member @Egika
                @Egika Thanks, I’ll try with my “old” sensor then, hopefully it will be a real spare one if procedure works !
                Suunto Wing & Spark
                  stromdiddily Gold Members @Egika
                  @Egika said in Suunto Smart Sensor HR Monitor No Longer Pairing:
                  Very sure…wore it for my entire gym session yesterday to make sure the skin contact was sufficient then tried the 3 second reverse trick. Still doesn’t connect 😞
                  • EgikaE Online
                    @stromdiddily then - broken…?
                    You can still check with a BT app on your phone if the Sensor has any signs of life in it…
                    M stromdiddilyS 2 Replies Last reply Reply Quote 1
                      Mauerwegler @Egika
                      @stromdiddily If you’re on iOS there are some apps suggested in this post/thread: https://forum.suunto.com/post/131880
                      Vertical All Black, Spartan Ultra Stealth Ti (with Polar H10 or Suunto Smart Sensor)
                      Vector
                      iOS Suunto App
                        Yeah…seems like it. Didn’t show up in bluetooth devices on my android or pull in when I tried to connect through SA.
                        Thanks for the tip on reverse polarity, will keep that in mind for next time
                          Mff73 @stromdiddily
                          @stromdiddily
                          did you check the belt instead of the sensor ?
                          https://forum.suunto.com/post/124621
                          if the belt is not waking up the sensor properly, then, probably the sensor looks dead.
                          just to be sure, do you have tested another new fresh battery ? i sometimes have new batteries somehow not powerful enough despite new 😞
                          according to the video, try to plug the sensor on the belt and put both belt electrode in contact to each of them (like short circuit), if it definitively not make the sensor seeable, it is probably dead or something we may not think about
