    Strange behaviour with Garmin HRM
    29 Posts 11 Posters 3.5k Views 10 Watching
      false Bronze Member @isazi
      Does anyone know here how it works under the hood? I mean the belt transmits ready to use value of HR or the watch does some calculations before showing the data on the screen?
      • Francesco PaganoF Offline
        Francesco Pagano Silver Members Bronze Member @Mff73
        @Mff73 Yes I only use the belt and I would know if I am starting an activity using OHR instead. As I wrote previously, am I even wearing the watch on my jacket sleeve so I wouldn’t expect HR readings from my wrist.
        S9PP
        S5
          Francesco Pagano Silver Members Bronze Member @TonyG
          @TonyG Thanks for the advice, I’ll try the strap position you suggested there. Today it happened again but luckily the HR went back to normal in a few seconds after I paused and restarted the activity.
          S9PP
          S5
            isazi Moderator @false
            @false I can only answer for the Suunto sensor, although I believe most chest straps work the same: the sensor sends IBI to the watch (the time in milliseconds between two beats) and the watch uses that to compute heart rate (watches may use different algorithms, especially on the filter side, to do that)
              After some time I am more and more convinced that this problem is related with wearing a jacket.
              When running with just a synthetic t-shirt on warm days I haven’t experienced it. Yesterday I ran again with t-shirt plus jacket and the HR values were all over the place. I did some research, and it seems to be a known issue.
              It’s just strange that the HRM is sending correct values, as displayed both on the Garmin step counter and on the S9PP on the pause screen, whilst the wrong values are displayed (and recorded) on S9PP during the activity.
              S9PP
              S5
                Mff73 @Francesco Pagano
                @Francesco-Pagano
                maybe a data filter process difference between activity pause and activity recording ? Only Suunto expert in FW could say. It would not be logic, but who knows.
                • Francesco PaganoF Francesco Pagano referenced this topic on
                  With the dry, cold days in Prague I am experiencing this issue more often now, even after wetting the belt sensors.
                  I recently found out something interesting: the average HR reported on my activity in SA - for the whole activity, or for specific intervals - seems to be the correct one. How would the app know this number versus, for example, intervals.icu or strava? I assumed the processed .fit file contains the same information for all.
                  See an example from yesterday with “broken” HR on my second lap: intervals.icu reported an average of 154 bpm (strava 155), SA reported a more realistic 165 bpm
                  S9PP
                  S5
                    MKPotts Bronze Member @Francesco Pagano
                    @Francesco-Pagano
                    Have you tried uploading the file to Runalyze, so you can see plots of the r-r data?
                    I’m fairly certain that where you see the sudden drop in HR, the r-r values will show a very large scatter. You will also probably see quite a lot of scatter throughout the run but when it isn’t so bad, the filters your watch (and later the different apps) apply can still calculate a realistic HR. I assume intervalsicu and Suunto are using different parameters to accept or reject r-r intervals, causing the difference you’re seeing.
                    What does the ZoneSense data show for this run? If the belt is sending bad r-r data, then the ZS graph will likely show a flat line where your hr drops out.
                    If the r-r data is bad, it’ll most likely be caused by the belt being too dry, moving because it’s too loose (or too tight), static electricity from your clothes or a worn out belt. If the r-r data is good, I don’t know what is wrong.
                    If you don’t find ZS useful, the most robust solution is to use an optical armband like the Polar Verity Sense. It reacts to fast changes in HR slower than a belt but that generally doesn’t matter. And you’ll never get bad data like you’re seeing with a belt (for running at least, based on using mine for 2.5 years and probably about 750 runs).
                    Francesco PaganoF 1 Reply Last reply Reply Quote 1
                      Francesco Pagano Silver Members Bronze Member @MKPotts
                      @MKPotts I didn’t use Runanalyze before, thank you for showing me another distraction from my work 😄
                      The problem is definitely caused by static electricity otherwise the belt works very well after almost 4 years!
                      On another run when the HR was bad for the first 30 minutes or so, ZoneSense shows absolutely nothing for that part, which is a fairly correct behaviour I think. And you’re right, Runanalyze shows a very large scatter:
                      S9PP
                      S5
