    Suunto ZoneSense
    955 Posts 146 Posters 187.3k Views 124 Watching
      borgelkranz Bronze Member @flo7z
      @flo7z Your screenshot shows the 5 Zones model. As far as I know, Z1 and Z2 in this model are below the Aerobic threshold, which is green in Zonesense.
      ZE and Z4 are above Aerobic but below Aerobic threshold. This is yellow in Zonesense.
      Z5 is above the Anaerobic threshold. Red in Zonesense.
      I never trained for a marathon but I suspect that it should mostly be aerobic. So green in Zonesense.
      As @Brad_Olwin stated: Zones and Zonesense are not the same. Use what helps you most.
      I can also confirm that the thresholds reported by Zonesense do vary. Across different sports and even across different days.
      For example in indoor rowing my Aerobic Threshold is at around 150, while in commuting by bike it is at around 136.
      • flo7zF Offline
        flo7z Silver Members
        That’s exactly my point, it seems there is a big difference between the HR and ZS zones.
        I understand you cannot directly compare HR and ZS but at the end of the day, you want to know if you are in aerobic or anaerobic.
        As I prepare marathons, I do big volumes and I have observed that difference on several runs and indoor biking sessions.
        Florian Z.
        Suunto 9 Peak Pro
        Suunto Wings
        Suunto D4
        Suunto Ambit 3 Peak
        • flo7zF Offline
          flo7z Silver Members @Brad_Olwin
          @Brad_Olwin by running marathons i know my paces and HR zones by heart, and the terrain does not play a role in this case.
          if we are not supposed to compare HR and ZS zones, then why is the SA doing it as on my screenshot?
          Florian Z.
          Suunto 9 Peak Pro
          Suunto Wings
          Suunto D4
          Suunto Ambit 3 Peak
          ? Brad_OlwinB 2 Replies Last reply Reply Quote 0
            A Former User @flo7z
            @flo7z You can compare, but assuming a correlation and immediately dismissing ZoneSense as ineffective is misguided. ZoneSense relies on HRV during activities to measure intensity and fatigue, and reducing it to just heart rate oversimplifies the multiple factors involved in its calculation. For example, after a good night’s sleep, the same pace and HR might indicate an aerobic effort, whereas after poor sleep, that same pace and HR could shift into anaerobic territory. This makes pace and HR unreliable—and for me, obsolete—when it comes to targeting training effectively.
            A little perspective about the factors involved in ZoneSense calculations:
            Heart Rate Variability (HRV) is influenced by several physiological, environmental, and behavioral factors:
            1. Physiological and Biological Factors
              • Autonomic Nervous System: The balance between the sympathetic (stress, action) and parasympathetic (rest, recovery) nervous systems is the primary regulator of HRV.
              • Age: HRV naturally decreases with age.
              • Sex: Women tend to have slightly higher HRV than men before menopause.
              • Genetics: Some individuals naturally have higher or lower HRV.
              • Physical Fitness: Better cardiovascular fitness is generally associated with higher HRV.
            2. Lifestyle Factors
              • Physical Exercise: Regular training improves HRV in the long term, but intense exercise can temporarily lower it.
              • Sleep: Poor sleep quality or insufficient sleep reduces HRV.
              • Hydration: Dehydration can lower HRV.
              • Diet: A balanced diet low in inflammatory foods supports better HRV.
            3. Environmental Factors
              • Temperature and Altitude: Extreme cold and high altitude can affect HRV.
              • Air Quality and Pollution: Exposure to toxins or poor air quality can lower HRV.
            4. Psychological and Emotional Factors
              • Stress and Anxiety: Chronic stress reduces HRV by increasing sympathetic nervous system activation.
              • Relaxation and Meditation: These practices enhance HRV by activating the parasympathetic nervous system.
            5. Medical and Hormonal Factors
              • Chronic Diseases: Conditions like hypertension, diabetes, and heart disease reduce HRV.
              • Inflammation: Chronic inflammation is associated with lower HRV.
              • Hormonal Fluctuations: Cortisol (stress hormone) lowers HRV, while melatonin and testosterone may increase it.
              • Substance Use: Caffeine, alcohol, nicotine, and certain medications can alter HRV.
            6. Circadian and Temporal Factors
              • Time of Day: HRV is typically higher at night due to parasympathetic dominance.
              • Circadian Rhythms: Jet lag and disruptions to biological rhythms affect HRV.
              Mattg576
              I’ve been using ZoneSense since it’s release on my race.
              I love the idea of it & really want to base all my training around it but continuously see random stuff like this going on.
              Is this just highlighting the interval “limitations” discussed above or something else going on ?
              Cheers
              Matt
              Race
              9 Peak
              Ambit 3 Peak
              Ambit 2R (sold)
              Suunto T3d (expired)
                Brad_Olwin Moderator @flo7z
                @flo7z said in Suunto ZoneSense:
                Your HR zones are going to change daily as judged by ZS. That at is the point.
                flo7zF 1 Reply Last reply Reply Quote 1
                  Brad_Olwin Moderator @Mattg576
                  @Mattg576 how long are the intervals? Likely too short. I would not use ZS for any less than 6 min and even then ZS will have a 1 to 2 min delay.
                    Mattg576 @Brad_Olwin
                    @Brad_Olwin
                    They’re not intervals Brad, just some small hills on a tempo run.
                    Race
                    9 Peak
                    Ambit 3 Peak
                    Ambit 2R (sold)
                      @Mattg576 How long? Looks too short as the downhills push ZS low and not enough sustained effort to go higher. On trails I cannot run downhill fast enough for ZS to show actual effort. That’s why I rely on RPE as well.
                      2 M 2 Replies Last reply Reply Quote 0
                        2b2bff @Brad_Olwin
                        @Brad_Olwin @Mattg576 to extend on that, in the ZoneSense videos it is said that you don’t want to look at the actual curve of ZoneSense but only on the color. So, a downvard curve within green means nothing, it is just green…
                          @Brad_Olwin I don’t know what you mean by how long or looks too short, the whole run or the small hills ?
                          Race
                          9 Peak
                          Ambit 3 Peak
                          Ambit 2R (sold)
                            Mattg576 @2b2bff
                            @2b2bff I understand the principles of Zonesense but by that logic my work effort got easier while I ran those hills (which it didn’t, it got harder).
                            I also understand there isn’t a direct correlation between ZS & HR BUT surely as the work effort increases it would push you up further into the anaerobic state - not nose dive back into low aerobic…
                            Race
                            9 Peak
                            Ambit 3 Peak
                            Ambit 2R (sold)
                            2 Brad_OlwinB 2 Replies Last reply Reply Quote 1
                              2b2bff @Mattg576
                              @Mattg576 as @Brad_Olwin said, ZoneSense always needs a couple of minutes to catch up. I remember from the videos that there are physiologic factors (30 seconds) and factors of calculation (2 minutes). So, if your intervals are shorter than those two minutes you won’t see any meaninful effects.
                              Here I had a run with 3 minute intervals and you can see how ZoneSense had a hard time to catch up, but it reached yellow at the end of the interval…
                                @Mattg576 The small hills, how long was the uphill, it looks to be short only 3 minutes or so?
                                  Brad_Olwin Moderator @2b2bff
                                  @2b2bff A perfect example! I don’t use live ZS for less than 6 min. I just use RPE. I will look back at my zones out of curiosity.
                                    @Mattg576 said in Suunto ZoneSense:
                                    The uphills are too short, it is simply green because the hard efforts were not long enough. Have you watched the videos or read the material on ZS. Those explain what you see.
                                      Brad_Olwin Moderator @Guest
                                      @iterum-tenta A great summary! I think to all forum users here…do not equate HR and ZS values or try to force them to fit together. Suunto has extensive information that explains 99% of the issues raised here. It is a substantial time commitment to view all of the videos.
                                      ChrisAC 1 Reply Last reply Reply Quote 4
                                        @Brad_Olwin said in Suunto ZoneSense:
                                        What mystifies me though is that I was already in an anaerobic state & my workload increased (confirmed by RPE - I was hanging out my ar#e) yet ZS suggests the complete opposite for nearly 10 minutes, I’ve experienced the same many times before…
                                        I have read & watched some of the material but granted not all of it, the answer must in the bits I haven’t watched yet.
                                        Thanks for your reply Brad.
                                        Race
                                        9 Peak
                                        Ambit 3 Peak
                                        Ambit 2R (sold)
                                        • ChrisAC Offline
                                          ChrisA Platinum Member @Brad_Olwin
                                          That’s it in one sentence! I think that’s the main problem, the main mistake, made when using ZS at first, since it seems so obvious and somehow it seems like a paradigm change at first. I would also recommend watching the very good videos.
                                          • flo7zF Offline
                                            @Brad_Olwin
                                            On one hand I understand this and this is why I am trying to see how I can “translate” the aerobic work (indicated by HR zone 2) into the ZS area.
                                            On the other hand, when I see at my data, except for big fatigue and heat, my HR is quite constant. Same if you listen to pro marathon runners, their heart rate is the same at +/- 1 or 2.
                                            I feel ZS is a great tool, we just need a bit more experience and maybe some more guidance based upon experience.
                                            Even though I watched all great Suunto videos on the subject, I still miss something to use ZS in my training, without watching the HR.
                                            Florian Z.
                                            Suunto 9 Peak Pro
                                            Suunto Wings
                                            Suunto D4
                                            Suunto Ambit 3 Peak
                                            2 Brad_OlwinB 2 Replies Last reply Reply Quote 0
