    Suunto ZoneSense
    955 Posts 146 Posters 187.2k Views 124 Watching
      Brad_Olwin Moderator @Sportsfreund
      @Sportsfreund said in Suunto ZoneSense:
      @tschogo that’s the point why ZoneSense doesn’t work.
      It seems you are in a minority here. I have had laboratory tests as well for AT and LT and VO2M. ZS does a good job with those values when I feel great. On days when I am fatigued ZS does a great job as my set HR values are incorrect. I find ZS invaluable.
      I have a substantial aerobic base having run ultramarathons for 14 years. I have a good idea of my max HR, you will not hit MaxHR on a Cooper test as the test is too long. Short 1-2 min all out uphill intervals will likely come close to your max HR. I suspect your HR zones are off and ZS is likely interpreting your efforts correctly.
      85% of my HR max is anaerobic at 153 but nowhere near my LT at 163. I would run a Cooper Test at above my LT at 90% or more of my max HR. My last Cooper Test was 168 bpm avg for the 12 min test and ZS nailed my LT in fact, higher than my test.
      PS I am 68.
        borgelkranz Bronze Member @Sportsfreund
        @Sportsfreund I am interested how Zonesense works for you in rowing.
        I never rowed on water, only on ergs. For me Zonesense delivers plausible feedback and helped me to fine-tune my zone settings.
        My intensity targets come from EXR where I regularly perform a ramp test. What I found out by now is, that my zones in running differ from the zones familiar to me from running.
        • ChrisAC Offline
          ChrisA Platinum Member @Sportsfreund
          @Sportsfreund … or you’re just way fitter than you assume 😅! Actually one of my trainingpartners for the II. Dan training was an ex russian rower (quite on pro level) and then in his late 50s this guy was extremely fit and could actually train for hours without appearant signs of exhaustion.
            tschogo
            Very interesting to read. I think Suunto needs to address this more clearly in their ad/description for ZoneSense. With this I mean how crazy widespread ones AT can be on a daily basis (on a HR scale). To me, not being any sport scientist at all, it still feels crazy, that on one day AT can be at 140, the next at 160. But I‘m very curious to see where this journey goes and will use ZS on all my upcoming trainings.
              Brad_Olwin Moderator @tschogo
              @tschogo said in Suunto ZoneSense:
              Mine vary as much or more than yours! I believe this is the power of ZS! I train primarily by RPE and ZS is scary good at matching my RPE. On days I feel even a little tired my AT has tanked according to ZS. I am primarily using ZS to keep my Endurance and Recovery runs easy enough.
              • SportsfreundS Offline
                Sportsfreund Bronze Member @borgelkranz
                @borgelkranz this is one of my last rows on concept2. This is the graph from the app. On the watch it was shown always green. It does not work on the watch, only the result in the app is clear.
                SportsfreundS B 2 Replies Last reply Reply Quote 0
                  Sportsfreund Bronze Member @Sportsfreund
                  @Sportsfreund and I can’t imagine the waves while the heartrate is constantly rising.
                    @Sportsfreund thx for sharing. I am too stupid to upload pictures, it appears. If you can give me a hand I will post some. Finally I found the upload button.
                    This one is from a an 8k cadence drill. 24 spm sandwiched in 22 spm blocks (both with the same intensity) followed by a ramp test to push me to the limit. Bad idea, I know. But wanted to test whether ZoneSense detects my anaerobic threshold, which it did.
                    This one is from long intervals that start with 30s of VO2max intensity,directly followed by a longer perior of at around FTP:
                    SportsfreundS 2 Replies Last reply Reply Quote 0
                      @borgelkranz Go to your pictures. Copy it and paste it here.
                      Yea this forum with its „ insert attachment“ does not work.
                      It only made for older user which still use a PC. 🤣
                        @borgelkranz does your watch show the zone sense graph in realtime? Or also delayed or after end activity in the app?
                          @Sportsfreund sorry I don’t get it even though I am one of the old people…
                            @Sportsfreund I do not see a graph on the watch but a bar that is color coded. Data is displayed after 10 minutes of warmup as explained in the description of the Zonesense app.
                            SportsfreundS 1 Reply Last reply Reply Quote 1
                              @borgelkranz yes. This is what I mean. I bar. A graph. A colored line. So what.
                                far-blue Bronze Member
                                Regarding the delay on ZS reacting, I’ve been testing out on threshold intervals and, although this is likely quite personal, for me it is about 10s behind the related change in HR. Of course there’s often a 10s to 20s delay in my HR reacting to a sudden increase or decrease in pace so overall ZS has a total lag for me of around 30s. Personally I think that’s pretty decent given I’m used to the 20s or so lag on my HR 🙂
                                • herlasH Offline
                                  herlas Silver Members
                                  One observation I’ve seen is, if we warm-up way slower than what a regular warm-up pace is for us, this will make ZS have a lower baseline and hence thresholds (if measured) will be lower as well.
                                  Advise is, do aerobic warm-ups but do not do them at a slower pace than your regular warm-up.
                                  SRS Ti
                                  Galaxy Z Flip 3 / Galaxy S24+
                                    @Sportsfreund I actively monitored that only during a hike and during one of my bike commutes to work. I shot a foto of the watch after the hike:
                                    In SuuntoApp this looked like this:
                                    Not a perfect match I’d say…
                                    Caveat: this was the first hike I did using a HF belt and ZoneSones. So perhaps this is not yet calibrated?
                                    • cosme.costaC Offline
                                      cosme.costa @borgelkranz
                                      @borgelkranz As I said before and info extracted from the Spanish Forum, the inconsistency between watch and app should be solved with next android app version, is seems that it is already fixed in iOS.
                                        A Former User @cosme.costa
                                        @cosme-costa I can confirm being on iOS and not having the issue.
                                        SportsfreundS thanasisT 3 Replies Last reply Reply Quote 2
                                          Sportsfreund Bronze Member @Guest
                                          @Mountain i also dont have problems with iOS app. Only the delay in the watch.
                                          • thanasisT Offline
                                            thanasis Bronze Member @Guest
                                            @Mountain i definitnely have discrepancies between the app and the watch. strong ones i would say. my last run shows in the app like 40% in Red while the watch showed like 1-2% (in iOS)
