    Suunto ZoneSense
    955 Posts 146 Posters 196.3k Views 124 Watching
    • MarynM Offline
      Maryn Silver Members @Brad_Olwin
      @Brad_Olwin have you had a chance to check? 🙂
        Brad_Olwin Moderator @Maryn
        @Maryn No answer yet
          Luis Andés Olmedo Bronze Member
          https://www.correrunamaraton.com/zonesense-suunto-test-prueba/
          5 Months testing Zone Sense. He found inconsistencies in data and several other issues…
          It’s in Spanish, but maybe you can translate the text to your native language using any online translator.
          2 Jan SuchánekJ isaziI 3 Replies Last reply Reply Quote 1
            2b2bff @Luis Andés Olmedo
            @Luis-Andés-Olmedo the interesting piece is that he connected two Suunto watches to the same Polar H10 and they gave different ZoneSense data what completely defers the point of using it…
            • Jan SuchánekJ Offline
              Jan Suchánek @Luis Andés Olmedo
              @Luis-Andés-Olmedo I think, we will see soon a DC Rainmaker version in English. I watched the video, it’s a huge disappointment. Useless random number generator at least for the tester. Very sad.
              VoiGASV 1 Reply Last reply Reply Quote 2
              • VoiGASV Offline
                VoiGAS Silver Members @Jan Suchánek
                @Jan-Suchánek Rays test was a long time ago - I would say it would have been published already if all the participants would have agreed to do so…
                Edit: It was November 2024 https://bsky.app/profile/dcrainmaker.com/post/3lbaymc64fk25
                ElmiuelE 1 Reply Last reply Reply Quote 1
                • ElmiuelE Offline
                  Elmiuel @VoiGAS
                  @VoiGAS You may be right. Eduardo (who runs a marathon) provides information in his analysis about a “recent” test, nothing about it having been performed in November. It’s perfectly clear that Ray is the third person to take the same test, and that’s why we can draw any conclusions.
                  A few days later, Eduardo released a video with “clarifications” about possible confusions in the previous video.
                  https://www.youtube.com/live/003mEjs_j9Y?si=X-sc-sqqAUCGjAC0
                  Waiting for possible reactions or Ray’s knowledge of his personal analysis… in short, as far as my use of ZS is concerned, it is a tool more focused on RESISTANCE, ULTRAS… and above all, very personal for controlling your RPE with your device…
                  Sunnto Race Titanium
                    Brad_Olwin Moderator @2b2bff
                    @2b2bff The belts will only send R-R data to one watch even if they connect to multiple watches. So how can one do the test? Have to wear two belts because no two tests can be identical.
                    Inge NallssonI E 2 3 Replies Last reply Reply Quote 0
                    • Inge NallssonI Offline
                      Inge Nallsson @Brad_Olwin
                      @Brad_Olwin I have not read the article, but the Polar H10 has two separate Bluetooth channels (only one enabled as default) plus the ANT+. It would be utterly strange if the R-R only went through one BT channel…
                        Elipsus Silver Members @Brad_Olwin
                        @Brad_Olwin ant + being a broadcast communication, any number of watch can “connect” to the strap at the same time, unless r-r data is just sent over bluetooth ? That would bé weird
                          2b2bff @Brad_Olwin
                          @Brad_Olwin I have an HRM Dual that I use with the Race S (BT) and the Epix Pro (ANT+) same time. Both receive R-R data. In fact I tried Alpha-HRV data field on my Epix today to see if I can make any sense of it compared to ZoneSense…
                          My feeling is that the H10 will send R-R over both BT channels. Otherwise ZoneSense would refuse to work, wouldn’t it?
                            @2b2bff My HRm_Pro his 3 channels but only sends RR on one. Maybe H-10 is different.
                            R 2 W 3 Replies Last reply Reply Quote 0
                            • R Offline
                              raven Bronze Member @Brad_Olwin
                              @Brad_Olwin said in Suunto ZoneSense:
                              Does the HRM_Pro differentiate the channels so one knows which has RR? For the Polar H10, connecting it to two devices there’s no difference in how the two channels appear that I can tell.
                              The Wahoo TRACKR has three bluetooth channels and claims to provide HRV with compatible apps. From my review of their tech specs, it does not say there’s a difference in those channels either.
                              https://www.wahoofitness.com/devices/heart-rate-monitors/trackr-heart-rate-buy
                                2b2bff @Brad_Olwin
                                @Brad_Olwin as I said HRM Dual sends via BT and ANT+ same time…
                                I just read that on an article on alphaHRV that a Polar H10 or a Suunto Belt is preferred for good quality data… 🙂
                                https://aiendurance.com/blog/real-time-readiness-with-alphahrv-and-ai-endurance
                                That said, my alphaHRV values have been completely off. Judging from those values I ran around LT2 with about 150bpm. ZoneSense showed be short dips into yellow for that run, what is more likely, as my LT2 is usually above 170bpm.
                                • R Offline
                                  raven Bronze Member @2b2bff
                                  The Garmin Pro and Pro Plus, in addition to ANT+, can send three BLE signals. Here’s the comparison chart from Garmin:
                                  What I don’t see is any indication that those three BLE signals differ in any way. I’m curious about the claim from Brad that only one bluetooth channel can send the appropriate data, as I see no indication of that in Garmin’s comparison. Also, if true, I’d like to know if that deficit also affects the Wahoo HRM.
                                  • W Offline
                                    wakarimasen Silver Members @Brad_Olwin
                                    Polar H10 can send HR data to three separate receivers, simultaneously: two via bluetooth and one via Ant+. I routinely run with two watches ‘hooked up’ to the same belt, but three would be possible, so long as one was Garmin and was connected last.
                                    Suunto Race Titanium
                                    Suunto Ambit3 Peak
                                    Polar H10
                                    Polar OH1
                                    R Inge NallssonI 2 Replies Last reply Reply Quote 0
                                    • R Offline
                                      raven Bronze Member @wakarimasen
                                      @wakarimasen ANT+ can send many connections; I’m not sure of the limit but it’s certainly more than one.
                                      W 1 Reply Last reply Reply Quote 1
                                      • W Offline
                                        wakarimasen Silver Members @raven
                                        @raven said in Suunto ZoneSense:
                                        Didn’t know that! I thought I was being greedy with a total of three! 😉
                                        Suunto Ambit3 Peak
                                        Polar H10
                                        Polar OH1
                                          2b2bff @raven
                                          @raven that chart is clearly off. HRM Dual has no running dynamics nor stand-alone activity monitoring and isn’t made for swimming…
                                          HRM-SWIM, PRO and PRO-PLUS has no detachable module…
                                          • R Offline
                                            @2b2bff I think this was the page I found that info:
                                            https://support.garmin.com/en-IE/?faq=Wr0GuiiSEx3BE4mBMX7UL8
                                            I don’t have a Garmin HRM myself. From time to time I’ve considered adding a new HRM as I have the Polar H10 but occasionally have the need for three bluetooth connections and was considering the Wahoo TRACKR one. However, now this thread has me concerned if there’s situations where HRMs with multiple bluetooth might have differing capabilities on each connection. I was hoping searching at Gamin would give me insight to what Brad was claiming.
