    186 Posts 57 Posters 13.2k Views 51 Watching
      This morning I charged my SV, almost at the end of charging the watch said that the maps were loaded (but I did not load the maps), reset the notifications, seemed to have reconnected the charger and charged the watch to 100%. After 10 hours of inactivity (daily HR, notifications, gesture backlight on) the battery charge was 95%. This was definitely not the case with the previous software. After a full charge, I did not reboot the watch. There is clearly something wrong with the battery discharge. Another note, I have a feeling that the increased discharge is only without activity, during activity the discharge is 2-3% per hour (it was like that before).
      gone troppoG 1 Reply Last reply Reply Quote 1
      • D Online
        dulko79
        I charged SVT one day before the update, I believe software release was on Friday, 22.08. Now I have 13 % of battery. Since then I did around 16 hours of GPS activities: walking and cycling with and without chest strap. I have enabled sleep and hrv tracking, notifications and blood oxygen are off. I find battery duration for my needs perfect.
        App: beta
        Phone: Iphone
        iOS
          sky-runner Silver Members
          Here is the issue I see with multiple HR sensors every single time I want to switch from one sensor to another.
          1. I start a run. It doesn’t show HR sensor connected because I wear another one - not the one I used previous time in the same activity type
          2. I go to the Exercise Options --> Sensor Data and select the sensor I want to use, select Connect. The sensor gets connected.
          3. However when I exit the Exercise Options menu I see on the top of the activity start screen is that it has already locked to the optical HR sensor and doesn’t actually use the sensor.
          It sometimes takes me several attempts of exiting the activity and restarting to make it actually use the sensor I want.
          The reason I have two sensors is that one of them is chest HR sensor for shorter runs and another is Coros armband HR sensor for longer runs. The latter is far more comfortable, especially when running with a pack.
          ? Brad_OlwinB 2 Replies Last reply Reply Quote 0
            A Former User @sky-runner
            @sky-runner today I went on a run with my wife. We both have Suunto watches, we both have Coros HRMs, we both had issues to get them to work. I had for example had it paired, it didn’t connect. I tried multiple things, selecting it in the activity menu as source, nothing. I had to delete/unpair the second HR monitor I had paired with the watch and only then I was somehow able to get it to work. I spend like 15 minutes before my run fiddling with it and was super annoyed. My wife lost patience and has left it in the car… This was a test of my patience today. I am fed up, really.
            MiroslavaM sky-runnerS 2 Replies Last reply Reply Quote 1
            • MiroslavaM Offline
              Miroslava @Guest
              @timecode this problem i have too. But only if i have too sensors polar 10 a d coros. I solve it now i use only coros and polar h10 remove from the watch
                sky-runner Silver Members @Guest
                @timecode said in Battery drain after update 2.44.46 (2025 Q3) on Vertical Watch:
                I wanted to emphasize that the problem is not with the Coros HRM. I was using only Coros HRM for months before with zero issues. I didn’t bother switching HRMs before because it was too annoying to unpair and pair sensor, but now with this “improvement” it doesn’t really work either. The only improvement, really, is that I can see the Coros HRM battery level.
                  @sky-runner @Miroslava yes it’s independent of the brand and type itself. It’s a general issue.
                  • gone troppoG Offline
                    gone troppo Bronze Member @Sergei Ladeishchikov
                    @Sergei-Ladeishchikov
                    Yep during activity the battery remain is still like it use to be it’s just during the day night when the battery consumption has increased significantly
                    CarmakC 1 Reply Last reply Reply Quote 0
                    • CarmakC Offline
                      Carmak @gone troppo
                      I think battery consumption has increased since the update on my Race too. It use to be 5% now it’s more like 12% per day without activity recording.
                        Brad_Olwin Moderator @sky-runner
                        @sky-runner Start a dedicated thread with this. Clearly there are issues although with my sensors I have not had this problem. I think a dedicated thread will help with fixes.
                          gone troppo Bronze Member @Brad_Olwin
                          My suunto vertical went through another 10% battery in last 24 hours with no activity recorded from 65-55% will try hard reset today
                            sartoric Moderator @gone troppo
                            @gone-troppo
                            just let it discharge fully (battery icon) then recharge.
                            maybe it just need to calibrate
                            Suunto App Android 6.3.3 beta
                              gone troppo Bronze Member @sartoric
                              @sartoric said in Battery drain after update 2.44.46 (2025 Q3) on Vertical Watch:
                              @gone-troppo
                              Already tried that didn’t work. Have tried every single thing I have seen recommended on this forum and on the fb groups nothing has worked so I just did hard reset as last resort what a pain.
                                fedequei
                                I have noticed as well a significant reduction in the battery life of my Suunto Vertical between April and today. This happened without any changes to my watch settings (notifications off, daily HR on).
                                While previously the battery could last much longer: fully charged the 16/4 was 70% the 23/4 (8 days).
                                Now full charged the 04/09 today is already 74% (4 days).
                                  @gone-troppo
                                  just remember that after the hard reset a calibration is basically needed
                                  I’m at 51% after 10 days, and I have increased training time (GPS) in the last weeks, so it looks pretty ok to me.
                                  I usually charge it after 20/21 days when it gets to 15/20 %
                                  • JonasLarssonJ Offline
                                    JonasLarsson
                                    To summarize: 50 % has problem, 50 % don’t.
                                    • Mff73M Online
                                      Mff73 @JonasLarsson
                                      @JonasLarsson said in Battery drain after update 2.44.46 (2025 Q3) on Vertical Watch:
                                      So, it is not a bug. It is a half-bug.
                                      JonasLarssonJ 1 Reply Last reply Reply Quote 1
                                        JonasLarsson @Mff73
                                        @Mff73 said in Battery drain after update 2.44.46 (2025 Q3) on Vertical Watch:
                                        Half-bug, half-feature.
                                        • Stefan KerstingS Offline
                                          Stefan Kersting
                                          Battery drain here too. Charged Sunday 20.00 from completely dead to 99 % with running of 20 minutes. Monday 12.00 already down at 92 %. 8 % loss after 16 hours!!! I have just 24/7 OHR on. Nothing else, no notifications etc.
                                          jjpazJ F 2 Replies Last reply Reply Quote 0
                                          • jjpazJ Offline
                                            jjpaz Bronze Member @Stefan Kersting
                                            @Stefan-Kersting
                                            Do you use external sensors?
