    186 Posts 57 Posters 13.2k Views 51 Watching
      Dimitrios Kanellopoulos Community Manager @Belial
      @Belial yes please validate its turned on
      BelialB 1 Reply Last reply Reply Quote 0
      • BelialB Offline
        Belial @Dimitrios Kanellopoulos
        @Dimitrios-Kanellopoulos said in Battery drain after update 2.44.46 (2025 Q3) on Vertical Watch:
        I’m sure the switch was active (in control panel).
        Now I’ve checked, it’s still on and watch is syncing, with connection icon displayed on watchface 🙂
          Squirrel Bronze Member @OutdoorMan
          @OutdoorMan said in Battery drain after update 2.44.46 (2025 Q3) on Vertical Watch:
          if you turn off airplane mode via control panel, then all the connections remain on. But if you do it via Settings - Connectivity - Airplane mode, then it turns everything off. I don’t know if it’s a bug or working as designed.
          Surely a bug in the watch firmware. In Control panel it simply doesn’t work despite showing the switch as enabled.
          @Belial said in Battery drain after update 2.44.46 (2025 Q3) on Vertical Watch:
          Well then disable it in Control panel, then go to Settings > Connectivity > Airplane mode and enable it there. Double check that it can not connect to phone, and then monitor power consumption.
          • gone troppoG Offline
            gone troppo Bronze Member @Squirrel
            I’ve tried turning aeroplane mode on mine in the settings that did not stop the battery drain.
              fedequei
              I’m also trying to test leaving the watch in airplane mode, but I don’t see any real improvement — maybe about 1% less battery drain per day, but it still loses around 8% daily.
              Please, Suunto, do something about this… it’s really starting to get annoying.
              • thanasisT Do not disturb
                thanasis Bronze Member
                putting the watch into energy saving mode works like a charm . So it’s obviously some process (?) that is consuming the battery
                • JacobusJ Offline
                  Jacobus @Stefan Kersting
                  @Stefan-Kersting I used to do this in the past, attaching it to a single button, but it would then try to connect, so I’ve since removed it entirely.
                  This has nothing to do with the latest update.
                  • Stefan KerstingS Offline
                    Stefan Kersting
                    After almost exactly 72 hours I have left 91 % and to hours of gps activity included the watch used 9 % energy. In my opinion there s something wrong with the Bluetooth WiFi connection. Airplane mode always on
                      surfboomerang
                      For reference…
                      I’m not suffering from the battery drain and have these connectivity settings configured:
                      Airplane mode: off
                      Paired devices: Mobile app
                      Wireless network: On/Auto
                      Discovery: Off
                      • K Offline
                        Kramble @surfboomerang
                        @surfboomerang Can you be more precise? OHR 24 ? sleep tracking? daily battery consumption without activities ?
                        Ambit 3 peak saphir
                        Spartan Ultra (sold)
                        S7 graphite copper
                        S9 peak all black
                        Wings
                          surfboomerang @Kramble
                          @Kramble
                          24/7 OHR: Off
                          Sleep tracking: Off
                          Notifications: On
                          Daily consumption: 2-3% (with almost no solar power)
                            maszop Bronze Member @surfboomerang
                            @surfboomerang If you turn everything off and use it like a Casio watch from the 1990s, it’s no wonder that the battery drain problem doesn’t occur 🙂
                            E L 2 Replies Last reply Reply Quote 8
                              Elipsus Silver Members @maszop
                              @maszop and Casios have 10 years battery life (with probably a smaller battery)
                              M 1 Reply Last reply Reply Quote 3
                                maszop Bronze Member @Elipsus
                                @Elipsus Apples to apples, not oranges.
                                  Luis Andés Olmedo Bronze Member @maszop
                                  @maszop said in Battery drain after update 2.44.46 (2025 Q3) on Vertical Watch:
                                  Casios had no GPS 🙂
                                  I do have exactly the same settings as @surfboomerang. Well, in fact no… my notifications are OFF 😛
                                    fedequei
                                    I’ve also tried unpairing all Bluetooth devices and changing the watch face, but the result is the same… I can see there are now reports about the Vertical 2 as well, so I really hope they’re working on a solution.
                                      fedequei
                                      Shall we give up on the reports in this thread? Should we wait for the December update and hope they’ve figured out what’s causing the problem?
                                      OutdoorManO W 2 Replies Last reply Reply Quote 0
                                        OutdoorMan Bronze Member @fedequei
                                        @fedequei I don’t know but I gave up, in general. I put the Race 2 up on sale - and nobody wants it.
                                        • W Offline
                                          Wilson75 @fedequei
                                          @fedequei said in Battery drain after update 2.44.46 (2025 Q3) on Vertical Watch:
                                          and hope they’
                                          I am having the same problem since this update. I also reported watch charging issue. All we can do it to leave with it + wait for the next update.
                                          Really hope that the next release will not be too long to receive. I am charging my watch every 5days now + checking every 5min if the watch is currently charging.
                                          Super annoying at this time…
                                          Suunto Vertical Titanium
                                          SA (bêta) on Pixel 9pro
                                          S9B Titanium (sold)
                                          SSU (sold)
                                            slash1111 @Wilson75
                                            Before the update my battery cycle was 15-17 days (Vertical 1). After the update it dropped to 8-10 days. Then I did hard reset and the cycle is back on 16-18 days.
                                            I’m guessing it has something to do with the new sensor management.
                                            After the update, every time I switched on the Polar Verity Sense it connected to the watch instantly.
                                            After the hard reset it connects only when I select any sport activity.
