    128 Posts 46 Posters 7.7k Views 44 Watching
    • K Offline
      Kramble @MeazzaS9
      @MeazzaS9 What is your sources about this please ?
      Ambit 3 peak saphir
      Spartan Ultra (sold)
      S7 graphite copper
      S9 peak all black
      Wings
      • K Kramble referenced this topic
        MeazzaS9 @OutdoorMan
        @OutdoorMan @Kramble These are just my considerations, but I repeat, since battery life is a must for Suunto, they cannot ignore this issue.
        OutdoorManO 1 Reply Last reply Reply Quote 2
          OutdoorMan Bronze Member @MeazzaS9
          @MeazzaS9 ok, you stated it as fact so I was curious. I am not sure if I share your optimism though, but let’s see…
          • U Offline
            uvrays
            Former long-time Garmin user – I switched to Suunto at the end of last year because Garmin put me off with a lot of messed up updates and among other things the resulting high battery consumption.
            And now the same thing is happening with my Suunto Vertical Solar, which I switched to because of its high power efficiency…
            As I’m new to the Suunto universe, can someone explain to me if and how I can roll back to the firmware without high battery consumption? Where can I get the firmware (I can only see the last two firmware versions in the watch – and the second to last one is already faulty) and how can I downgrade the firmware of the SV?
            Thanks for advice!
              I’m reading through this issue, but I’m not entirely sure I agree with what’s being said here.
              Since not everyone is experiencing battery drain, how can we say the drain is deliberate?
              I’m raising this issue, but let’s keep things in perspective — it’s not that Suunto wants to drain the battery faster. The Vertical 1 is Suunto’s flagship model for MIPS.
              Could you please check whether the battery drain remains the same if you unpair your sensors (under Connectivity)? This was one of the main low-level changes in the latest update, so it would help narrow things down.
              Thank you for taking the time to write here and report your findings — it’s appreciated!
              H K gone troppoG 3 Replies Last reply Reply Quote 2
              • H Offline
                halajos Bronze Member @Dimitrios Kanellopoulos
                @Dimitrios-Kanellopoulos I’ve experienced random restarts with my Race v1 every few hours on 2.44.52, which were gone when I reverted to 2.44.46 (hard reset didn’t help on 2.44.52). May the restarts and increased battery drain related? I assume the watch draws more current during startup. Could someone who has battery drain issue check for an error code in the debug menu (mine showed an error code)?
                • K Offline
                  kurtpenter Bronze Member @Dimitrios Kanellopoulos
                  @Dimitrios-Kanellopoulos unfortunately yes, power drain is a thing even if I unpaired sensors and disabled Bluetooth visibility.
                  Something bad happened with the last 2 firmware updates on my SV1 (Finland): footpod does not work, battery drain, and dismissing notifications takes seconds. First time I complain about a FW update in years. First time I reach 4% battery.
                  I really hope a fix comes out soon and I’m starting to think to go back to previous FWs.
                  • gone troppoG Offline
                    gone troppo Bronze Member @Dimitrios Kanellopoulos
                    @Dimitrios-Kanellopoulos said in Battery drain after update 2.44.46 (2025 Q3) on Vertical Watch:
                    Hi
                    Yes I have tried this and it did not work, I literally tried every single “fix” that was suggested on these forums and various fb groups on mine none have worked. I’m not someone who just complains for no reason if you look at my historical posts I was singing praises for the suunto vertical more than anyone when it first come out on here when it worked properly. The solar stopped working which I can live with but the battery drain is a fundamental failure of this watch. I sent my watch to suunto repair cost me $50 who said there is nothing wrong with the battery or hardware and they claim it is only draining 4% per 24 hours!!! Yet I have approx 6 week worth of notes every morning I would record battery level when I wake up. I would get anywhere from 12-40% drain every 24 hours it gets worse as the battery gets lower below 50%. So either I’m lying or the suunto repair shop is lying???
                    To all the others this battery drain has been happening well before the last two firmware updates so rolling back to the last firmware won’t help you. This is something suunto must fix. Currently I’m using my old reliable ambit 3 peak which goes through maybe 2-3% battery a day and puts the vertical to shame how embarrassing. 2014 technology smashing the current stuff
