    186 Posts 57 Posters 13.2k Views 51 Watching
      fedequei @Stefan Kersting
      @Stefan-Kersting same same!
      • Stefan KerstingS Offline
        Stefan Kersting @jjpaz
        @jjpaz hr belt but that have I used before too
        jjpazJ 1 Reply Last reply Reply Quote 0
          Stefan Kersting
          Now I lost 2 % in 4,5 hours
            Stefan Kersting
            After 24 hours and 1 hour of gps activity 12 % battery drain 😱
            • gone troppoG Offline
              gone troppo Bronze Member @Stefan Kersting
              @Stefan-Kersting said in Battery drain after update 2.44.46 (2025 Q3) on Vertical Watch:
              Yeh mate mine is exactly the same even after a hard reset hasn’t fixed it have tried everything. Must say I have loved my vertical and suunto to this point one of the main reasons is they don’t have all the nonsense and clutter like Garmin. All I expect is excellent gps accuracy and excellent battery life. And whilst the vertical still has excellent gps accuracy It no longer has excellent battery life.
              • JonasLarssonJ Offline
                JonasLarsson @gone troppo
                @gone-troppo said in Battery drain after update 2.44.46 (2025 Q3) on Vertical Watch:
                Don’t give up. Future update can fix this.
                  A Former User @JonasLarsson
                  @JonasLarsson said in Battery drain after update 2.44.46 (2025 Q3) on Vertical Watch:
                  Yeh mate mine is exactly the same even after a hard reset hasn’t fixed it have tried everything. Must say I have loved my vertical and suunto to this point one of the main reasons is they don’t have all the nonsense and clutter like Garmin. All I expect is excellent gps accuracy and excellent battery life. And whilst the vertical still has excellent gps accuracy It no longer has excellent accuracy battery life.
                  I have the feeling this is all becoming a flip-coin, 50% it fixes things, 50% it doesn’t. And as a bonus you get a new bug.
                    MatĂșĆĄ Bronze Member @Guest
                    @timecode said in Battery drain after update 2.44.46 (2025 Q3) on Vertical Watch:
                    Accurate.👌
                    Suunto Spartan Sport
                    #swatt
                    • jjpazJ Offline
                      jjpaz Bronze Member @Stefan Kersting
                      @Stefan-Kersting
                      Yes, that’s the key. I have reported the issue and my verifications in the Spanish Support Telegram Group (awesome group).
                      The issue is that after activities the watch remains looking for the BT devices and that process is draining battery in the backplane.
                      How can you test it? With the watch in repose mode (in watchface mode) power on your your previously sinced BT device. In my case, I power on my Coospo HR armband and the Vertical watch vibrates, the same way it vibrates when syncs with the device in the preactivity screen
                      Workarounds:
                      • Unsync BT devices (maybe after activities, and sync again before new activity)
                      • Soft reset after activities. In this case tha watch forgets the sensor and the “scan” process doesn`t starts until you sync the sensor again in the preactivity menu.
                      Hope this helps until the hotfix is ready.
                      Stefan KerstingS L gone troppoG 3 Replies Last reply Reply Quote 9
                        @jjpaz all Right. Thanks for your help. My Problem is that I have to bt connections that I can’t delete
                          lessthanmore Bronze Member @jjpaz
                          @jjpaz I can confirm this with my Race S and a Garmin HRM Pro.
                          • kriskusK Offline
                            kriskus Bronze Member
                            So, today, after more than a full week from charging to 100% (took the watch off the charger last Wednesday in the morning) I’m at 70%. This included 6h of GPS activity (3 with map screen on). I’d say this is normal.
                              gone troppo Bronze Member @jjpaz
                              @jjpaz
                              Hey mate do you mean by unsync after activities to click the “discovery off” button to off so it’s not looking for any devices ?
                              • jjpazJ Offline
                                jjpaz Bronze Member @gone troppo
                                @gone-troppo I mean to unpair the connected device.
                                In my case, I prefer to soft reset the watch after activities, altough I have to select the sensor again every time I start a new activity
                                gone troppoG 1 Reply Last reply Reply Quote 1
                                  @jjpaz
                                  Ok thanks damn that’s a pain to have to unpair and repair every time I will give up his a go tommorow and see if it makes a difference
                                    MeazzaS9
                                    Does downgrading the firmware to the previous one fix the problem? What if the battery problem is caused by the latest update?
                                    • DuĆĄan KovićD Offline
                                      Duơan Ković
                                      It would be really nice of suunto to give us bug-fix FW update soon, so we don’t have to wait for another quarter update
                                      SR
                                      SA latest beta
                                      Polar Verity Sense
                                      Polar H10
                                      Pixel 6
                                        gone troppo Bronze Member @MeazzaS9
                                        @MeazzaS9
                                        Mine has been doing this for a long time before the last update prolly 6-12 months ago it started draining like this.
                                          MeazzaS9 @gone troppo
                                          @gone-troppo My Vertical had a similar problem a while ago, but it was fixed with an update or bug fix. I don’t remember.
                                          My watch wasn’t updated to the latest firmware as soon as I read about the battery issue.
                                            Jugger
                                            I charged my watch on 30.8 and today I have still 47% of battery left. HR, HRV and sleep tracking ON 24/7. 6,5 hours of running and walking with best GPS and H10 as HR sensor for 4 hours of that time. No battery calibration after last FW update. Batterylife is the same as the day I bought mine two years ago.
