Hey all! I am tempted to upgrade from s9pp to V2. Really like the fact that i can see a lot of data on watchface without turning on or even move wrist to display all that info. I also fond watch more attractive to look at since it is not only black screen.
Anyone upgrading from mip find amoled annoying as edc watch? -
@krakra I upgraded from 9P to RaceS. As a watch the AMOLED Display works quite good in Always On Mose. Only in bright Sunlight you need to wake it, but it has a light sensor.
The problem is more during activities, where Lift to wake takes some time and the AOD display is too dim during the day. But if you are running before sunrise and after sunset the AMOLED Display wins easily -
@brekke89 said in Suunto Vertical 2 General Discussion:
I’ve just switched from a Garmin Forerunner 265 to the Suunto Vertical 2. I really like the Vertical, and the Suunto ecosystem is much more intuitive and informative!
The only thing that annoys me is that the watch never disconnects from Bluetooth, even when I put it in flight mode. I still receive notifications, and it keeps syncing with my phone all the time. How do you completely disconnect it from the phone? I’ve tried restarting the watch. Any suggestions?
apparently there are two “flight modes”.
one you access from the control panel -> does not stop BT
and one you access from setting -> communication -> stops BT -
@krakra I have the V2 from V1. In everyday use the V2 is fantastic. Clear, bright and with colour. Looking at the V1 after the V2 makes the V1 look very old…
However when cycling the MIPs is far superior.
On the V2 with AOD the map still goes dark and isn’t brilliant to read. I haven’t tried it walking yet but imagine it will be brilliant for that as you raise your to wrist to view.
Initial reaction to the V2 was too send it back with the cycling performance after a few days as an everyday watch I wouldn’t want to go back to the V1… I do have a bike computer from wahoo so the comparatively poor performance on the bike isn’t a big deal.
Any chance to demonstrate how dim modes work in navigation activity mode?
@Egika said in Suunto Vertical 2 General Discussion:
and one you access from setting -> communication -> stops BTThanks! It is working now
@Egika Oh ! that explains a lot ! Is it planned for future bugfixes ?
@Elipsus It´s intended design by Suunto as I read somewhere…
I can´t understand that. -
@Elipsus don’t know if this will change. At least this is pretty unintuitive.
reported it to Suunto -
@Jan-Suchánek that sounds a lot like a bug that was “feature-ed” to avoid making changes (I know what I’m talking about, i’m a product engineer ^^)
@Antoine-Lancrenon
after a week of reflexion, and since my solar harvest V1 is not working anymore (hardware issue, only the solar charging is out) and I am adove the 2 years warranty, i was thinking to upgrade.As a “normal” user of the v1, it makes not really sence to upgrade to the v2. i dont care about the oled, i care about battery much more as a hicker and ultra runner.
I am an outdoor man and do use the torch of my v1 (with. the screen) it is pretty poor in comparison with the dedicated led of the V2, this is thenonly point really where i want to upgrade.
may be the improved accuracy of the HR? but i am happy with wath I got with v1, true with issues.I think Ill stick with the V1 until the v3 is out… what about you v1 owners, why are you upgrading really here?
*we loose the mip
*we loose a significant battery longevity on different conditions
*no configurable battery management
*no solar -
I much prefer the V2 screen for every day use.
The watch faces come to life. And the face in reality looks a lot bigger for my ageing eyes as there is no solar bevel.
Battery life is still excellent.The upgrade is minimal but for me worth it. But I totally understand skipping a generation of watches. It is the logical thing to do!
One area I don’t like on the V2 is the bike performance when on the handlebars. V1 is better.
Owe yes, the torch is great
If I choose Athletics watchface with Display settings (brightness low, AOD off, raise to wake - full wake mode) and I lock the watch (bottom button) after some time watch cannot be unlocked. Top button reset helps. If I choose raise to wake - Display only there is no issue.
@Egika Is this a bug or an intentionally designed feature?
P.S. Edited. I read other comments, so I got my answer. -
Sometimes my Vertical 2 turns off the HR sensor until I take it off and put it back on my wrist. This creates problems reading parameters, especially sleep tracking.
I did a factory reset but it didn’t solve the issue.
The firmware is updated to the latest version.
Has this happened to you too? -
Don’t like the concept of V2.
For me It’s not differ so much from the race 2…The spirit of V1 was with a huge autonomie.
That’s clear the the solar panel bring not so much.
But a watch better sensor, and same autonomy, and a bigger screen readable (with mip technology) by hiking for a long time would be welcome.
Worse autonomy/performance for a gadget screen… sad.Would suggest that suunto make a M version of the V2 with mip screen…
@Manuel-Extreme said in Suunto Vertical 2 General Discussion:
Has this happened to you too?It has happened on v1 so I assume it could be firmware related
After 11 days of using V2, OHR, sleep tracking, some GPS activities I got 42% left. Race 1 was charged 1 day after V2, rebooted, everything turned off, just laying on the shelf and also has 42% left…
I don’t know, where Suunto get these numbers. If the discharge rate will stay same, it will last 19 days, but my guess is 15-17 days. OK, it´s UP TO, but even with 19 days it´s 27% less with only one wake per day :-).
@Jan-Suchánek you are talking about the Race 1 battery here?
Maybe better in a different thread, as this one is about Vertical 2. -
When will Suunto add the “Vertical 2” section to support, to at least have a record of updates and their contents?
My Vertical 2 has fw: 2.46.12 but what updates and fixes does it contain?
On the support site:
Vertical 1 shows 2.44.52 with release notes
Race 2 has no information
Race 1 is nowhere to be found…
