Vertical 2 syncing of routes
Hi all! Hope you can help me with my query.
I am undecided between the Vertical 2 and the Fenix 8. Both have their pros and cons as can be seen from a quick search on the net but I am currently leaning more for the Vertical 2. My only gripes are the non-routable maps (which I can live with, since I do not create routes on the field) and the maximum number of 15ish routes on the watch. Regarding this matter, can anyone confirm or otherwise:
- If the routes on the Suunto app are available without internet connection? Are they stored on the mobile device or only in cloud, requiring internet to access them.
- Is syncing of routes from Suunto app to SV2 done via Bluetooth without the need of an internet connection?
Just asking so that I can see if there is some sort of workaround to the limited number of routes that can be downloaded to the SV2.
TIA
@Wenzudeg You can sync and add routes offline. You can also create routes offline in SuuntoApp, but only manually (without routing), i.e., by drawing on the map.
@Wenzudeg You can sync routes between the watch and the app while fully offline using the BT connection. Even better routes will sync during an exercise/activity and the new route can be selected in the watch and followed. I did this last weekend.
Drawing a route in the app requires a cellular connection now but I think offline maps in the app may be coming. -
@Brad_Olwin Thanks. That’s a good workaround to the limited number of routes on watch.
@Brad_Olwin You can draw a route offline on the map, but only using the “Free drawing” option, i.e. just drawing straight lines by hand. A bit more time-consuming, but it can be used offline.
But currently you need a map of the given area in the application cache.
@maszop said in Vertical 2 syncing of routes:
Where we can have this offline map in the suunto App!?
@GiPFELKiND The map has been in the app cache for some time. Turn on airplane mode on your phone and you’ll see that some areas you’ve recently used or saved routes in the Suunto app have maps of those areas in the app cache.
Of course, Suunto should have had fully usable offline maps long ago. I hope they implement this soon, as it’s a huge limitation of the entire Suunto platform.
I just tested a much more convenient method. The Maps. com app can generate an offline GPX file that can be opened in SuuntoApp and used on the watch—even offline. This is exactly what’s missing from SuuntoApp itself.
@maszop totally agree! Offline re-routing on downloaded maps is perhaps the greatest Achilles’s heel of the Suunto platform and, I think, the most important difference from Garmin’s system. As said in previous posts, this Achilles’s heel is further compounded by the limited number of routes one can offload onto the SV2.
I believe that watch processor and storage space are not the issues. And even if they are, why, at least, not use Suunto app on mobile device for these two jobs for eventual BT transfer to watch of gpx file (like you did with a third party app)? It’s not ideal since you have to have a mobile device on activity/exercise but you will have peace of mind that you are covered for any eventuality.
@maszop
I do not what I am missing, but after creating the new route offline, as you described, ie using the “free drawing” option, the Suunto app wants me to save the newly created route before it can be followed/used, either in the app itself or be synced to the watch.
But when trying to save the route and pressing the button “Save”, the app shows a error message saying “No internet connection” and wont accept the “Save”, hence the new route created offline does not sync to the watch…and/or can not be used in the app for navigation.What am I missing?
BR
Carl -
@maszop
BR
Carl -
@CarlW Are you using Android phone or IPhone?
Iphone
@CarlW said in Vertical 2 syncing of routes:
@maszop
BR
CarlYou are not missing anything. This is a big disadvantage of the iOS app at the moment.
@Egika
Thanks once again for a useful answer
