Suunto 9 Peak Pro and Polar Verity Sense: connection dropping after start
Greetings,
I received a Polar Verity Sense armband in December and was able to connect and use it without trouble. Right around New Years, I started having the following problem:- I start the armband, then chose my sport in Suunto 9 Peak Pro.
- The connection to the armband is confirmed in the 9PP and I can see my pulse. I wait for the GPS connection.
- I start my sport, but I no longer see my pulse. It is just marked with “–“. After finishing my run, I have no HR data.
I have tried every kind of reset and reconnection known to man (and to Polar and Suunto), but I always get the same behavior. I have also tried both Bluetooth and AMT+ connections.
I was so frustrated, I just resorted to using my H10 chest strap, which sometimes chafes my chest. With the summer months approaching, I’d like to get the armband working. The Firmware on the Verity Sense is 3.0.15. The fw on the 9PP is whatever the lastest is.
Any one have any ideas?
Cheers!
@jmlee I have similar issues with my Vertical 1 and Polar Verity sense.
In the start exercise screen the watch finds the sensor, and everything seems okay. But when I start the exercise it loses it and i won’t reconect for the whole duration of exercise.
The only solution/workaround is to stop the exercise and start it again. Repeat that 2 - 3 times until the heart rate is visible in the exercise on the watch. Usually after that the hearth rate works for the whole duration. -
It could be an issue on Polar side, they withdrew the 3.0.15 firmware shortly after the release. https://support.polar.com//en/updates/verity-sense-firmware-version-3015-no-longer-available
@CroShark Thanks for the tip. Unfortunately, it’s not working for me. I tried many, many times, both just pausing and restarting as well as stopping completely and discarding the exercise.
@c-d : Yes, I would wager than the issue hangs together with the firmware update, as the timing fits. I shall write to Polar support.
I received the armband in the US as a gift, but I live in Europe. So, unfortunately, there is no practical way for me to return it.
I know it’s not much help, but just wanted to say that I have no issues currently and I haven’t experienced this. I use the same HR monitor with my V1 and it’s always been reliable with no connection problems
I just wanted to chime in so you know that it’s not a blanket issue for everyone pairing these two units. Hope you find a fix for it soon -
@C-D said in Suunto 9 Peak Pro and Polar Verity Sense: connection dropping after start:
Version 3.0.16 is now available – it’s well worth giving it a go straight away…
@snow & @c-d
Thanks for the tip. I installed the 3.0.16, but it hasn’t solved the problem. I tried all manner of reconnecting and resetting the device, blue tooth connection etc., but the verity sense still behaves as described. In fact, I noticed that at point 2 (see above), I see the pulse, but it does not change. So, it must deliver an initial reading, and then the connection conks out.I will now write to Polar support.
@snow Can you install the update using the Polar Flow app via bluetooth? I downloaded it but can’t see a clear way to update my unit. Thanks in advance
@MiniForklift Hi, I’ve updated it yesterday. Please take a look at this and this.
I have a similar issue with my vertical 2. Today it buzzed me about every 3 minutes on a 10km run because it suddenly had no heart rate and then it came back. Seems like the connection was dropping constantly for a few seconds before reconnectin. But it doesn’t show up on the heart rate chart in the app so I guess suunto fills in the blanks of missing heart rate data
@snow Thanks for the tip. I tried it, but still see no improvement.
I downloaded the Polar Beat App to my phone, and it connected with the VS-Armband without any problems.I assume that Polar is going to say it’s a Suunto issue, and that Suunto will say the opposite. The chronology of my problems points to Polar, as the Suunto P9P was updated in November and again in January. But, I was able to use the VS-Armband fine from receiving it in early December until the 3.0.15 firmware upgrade.
Alas….
@jmlee I’m sorry it didn’t work. I’ll ask a friend if he’ll let me try it with his 9PP and let you know.
Hi @jmlee ,
I have experienced exactly the same as you in my Suunto 9 Peak Pro, including the pulse detection before starting the activity (although it remains constant with the first detected value). After starting the activity, the “—” appears.
Have you solved this issue?
Thanks!
I only recently had this issue after the Polar Flow app forced a firmware update on the Verity Sense. I’ve unpaired, repaired, factory reset, started and stopped runs. Nothing makes it work. The whole reason I got the Polar sensor was b/c the 9PP was wildly inaccurate (swings from 120 to 190 bpm when I knew I was in zone 2 and feeling fine). If the Verity Sense does not work with 9PP anymore, does anyone use an alternative sensor that is accurate? I’d rather not spring for a whole new watch just yet as I like literally everything else about the 9PP.
Alas….
Maybe if you contact Polar with those insights they can track what changed on the firmware.
Contact here
I ordered a Verity Sense to use with my Ambit 3 because my coospo hw9 did exactly the same as you explain with the ambit 3 peak (worked ok with garmin 1040, hammerhead etc), hope I can use it.
Edit: just sent an email to polar france poiting to this thread, maybe useful if those who already have the issues can contact polar and them doing something.
Also open issue here. Feel free to complete.Edit2: if someone still has 2.2.6 or older maybe can back it up connecting to a pc and using claude code or other way
DOes anyone can confirm me if it works or not with Ambit 3? Some old threads said yes and hence why I bought it, would annoy me that it would do the same thing as the Coospo HW9 I had.
