    Battery mode not rememberd
    6 Posts 3 Posters 425 Views 3 Watching
      ESegerer
      According to the support page (https://www.suunto.com/de-de/Support/faq-articles/suunto-9-peak-pro/wie-kann-ich-die-batteriemodi-der-suunto-9-peak-pro-optimal-verwenden/) the battery mode of an activity is remembered.
      I set the mode from Performance to Endurance when I select the Mountaineering activity. This works fine for the day. When I select Mountaineering on another day the mode is Performance again.
      I tried the same on other activities (e.g. Running) and had the same effect.
      Why does it not remember the mode?
      It is bothering that I have to go down several levels in the menu to set it before starting a training.
        Egika Platinum Member @ESegerer
        @ESegerer I am not sure if someone here can answer why this is this way…
        • R Online
          RichardM
          It is the same for the Vertical 2. I would like it to remember, but it seems to be the way it works, and perhaps there is a good reason.
            I checked with Suunto:
            They say it is by design, so people don’t accidentally leave the watch in the lesser mode unintenionally.
            At least this is the case with current generation watches. I reported, that function and documentation for S9PP and Vertical differ.
              ESegerer @Egika
              @Egika Thanks for your feedback
              • R Online
                RichardM @ESegerer
                @ESegerer I can understand that’s a reasonable design decision. There do seem to be some inconsistencies though. For example, if I start an exercise, go to Exercise Options and turn off GPS this setting is remembered next time. So, next time I do the exercise I might forget I turned it off. Turning off GPS (maybe to save battery!) seems to me to be a more fundamental change than battery mode. Maybe there’s a good reason. (This is Vertical 2 not 9PP)
