    S9 Baro takes very long to find GPS signal before a move
    134 Posts 29 Posters 28.0k Views 29 Watching
      Brad_Olwin Moderator @stokje
      @stokje said in S9 Baro takes very long to find GPS signal before a move:
      @Brad_Olwin
      The AGPS file is old, a few days ago…
      When I soft reset, the file will update to a resent date, but
      then again the watch refuses to update this file.
      and so on…
      So there is a problem with how you are updating it. Suuntolink, Movescount or SA?
      • Fatih KaleF Offline
        Fatih Kale
        I had a similar problem today. At the beginning of run watch was on performance mode and no issues it found gps in seconds but when I climbed a uphill which was not covered by any trees or any building etc. It lost the gps and I had to wait for 10 20 minutes to find it back. I can’t understand how it happens. I had to stop the activity, start a new one etc. It was frustrating. Second time it found the GPS there was no issue until end of the run.
        BTW any recommendation when to use GLONASS or GALILEO?
        Suunto 9 Baro
          stokje Bronze Member @Brad_Olwin
          @Brad_Olwin
          I use suuntolink with movescount, I’m a long time Suunto user, this never was an issue before…
          No intention to use SA until forced:)
            This issue keeps plaguing my Suunto 9. From time to time it just stops updating AGPS, and the time it takes to find satellites starts to increasingly get worse. Then at some point I reboot the watch by pressing the upper button for 12 second and re-sync, and it gets the new AGPS, and everything is fine for a week or so. Then everything repeats again. That isn’t what I’d call a good experience.
            Is Suunto doing anything about this?
            • Jessica MonkJ Offline
              Jessica Monk Bronze Member
              @silentvoyager said in S9 Baro takes very long to find GPS signal before a move:
              I am experiencing this as well. For me at least, seems to be only recently (past 2 weeks or so). Prior to that I would get GPS consistently within 5 seconds, even while I was indoors.
                I am not experiencing this and I am typically syncing an S9 baro with MC app. I will check on this and keep updating all of you.
                  @stokje Try MC app and see what happens
                    @silentvoyager No afaik Suunto is not doing something about this so far.
                    So just to understand you sync with the Suunto app and then you have no AGPS and after waiting for a few for the watch to process them? (Up to 10 minutes?)
                    Or AGPS is not updated (old date) .
                    One small thing here. MC app is not the focus here so lets please leave that aside.
                    • pilleusP Offline
                      pilleus
                      I use Suunto app to sync my S9. The syncing process sometimes takes up to 3 Minutes!? But it works fine. Starting an activity the GPS fix is done after 3 to 5 seconds. SA is the latest beta, firmware of S9 is also the latest.
                      Suunto Vertical Black Lime
                      Suunto 9 Peak Pro Black
                        @Dimitrios-Kanellopoulos said in S9 Baro takes very long to find GPS signal before a move:
                        AGPS date isn’t updated. When initial sattelite acquisition becomes slow I check AGPS date and find it to be two weeks old. That is despite syncing almost daily. I sync only with MC app. I am not ready to switch to SA.
                        When you say MC app is not the focus here, does it mean that the issue isn’t relevant to MC app? Or does it mean that the issue won’t be addressed in MC?
                          sartoric Moderator @Guest
                          @silentvoyager
                          So the problem is MC App not updating AGPS ?!
                          What happen to AGPS if you connect by cable ?
                          SVTS - 2.48.16
                          Suunto App Android 6.4.7 beta
                            A Former User @sartoric
                            @sartoric said in S9 Baro takes very long to find GPS signal before a move:
                            I don’t know. I’ll test it next time I have this issue. The issue is intermittent.
                              MC app is being retired at the end of 2019. But, until SA is caught up a bit more, those that are having trouble with AGPS could use SA and MC apps together. You would then be able to sync to MC, use the POIs and workout calendar as well as SA sync to update AGPS. It is not that much hassle to use both but only one app can be running at one time.
                                A Former User @Brad_Olwin
                                @Brad_Olwin said in S9 Baro takes very long to find GPS signal before a move:
                                After reading this post I said to myself - OK, let’s give it a try!
                                So, I’ve created a new SA account, paired my Suunto 9 to SA, and synced 19 activities I had on the watch to it.
                                It may be updating AGPS to my watch now, but the app is simply unusable after the initial sync! It freezes so badly that every tap takes a few seconds for the app to respond. And it is missing some activities including a recent 12 hour run - is that a reason it is freezing by any chance?
                                If that is what I’ll be forced to use when MC is retired, it won’t take me long to switch to another brand. I have zero tolerance for bad software.
                                Mff73M Dimitrios KanellopoulosD 3 Replies Last reply Reply Quote 0
                                  Mff73 @Guest
                                  @silentvoyager
                                  there is a “bug” for long run sync, and if you are in that case, until it is fixes, you could use this instead :
                                  https://forum.suunto.com/topic/2841/long-activities-not-syncing-for-android-try-this-version
                                  old version, surely new features missing, but at least to sync your activities, and wait for the fix.
                                    @silentvoyager what version ? Thanks for the time and effort.
                                    I’ll create an issue for the mc app. Its clear now.
                                      @silentvoyager I see the issue. Please if you have a different system font for you system (eg enlarged) switch it back to to normal for the app not to crash
                                        Sooooo, more people experiencing problems with updating the AGPS.
                                        MC, cable and SA users, it seems…
                                        What to do now? does Suunto know, if not, how?
                                        sartoricS Dimitrios KanellopoulosD 2 Replies Last reply Reply Quote 0
                                          sartoric Moderator @stokje
                                          This is the place to let Suunto know … and now they know
                                          SVTS - 2.48.16
                                            Dimitrios Kanellopoulos Community Manager @stokje
                                            @stokje I am not sure people said it doesnt get updated via SA or did I miss that?
