    S9 Baro takes very long to find GPS signal before a move
    134 Posts 29 Posters 28.0k Views 29 Watching
      @Dimitrios-Kanellopoulos said in S9 Baro takes very long to find GPS signal before a move:
      @silentvoyager I see the issue. Please if you have a different system font for you system (eg enlarged) switch it back to to normal for the app not to crash
      The font doesn’t seem to be an issue. I’ve reverted back to default font, installed the app again (version 4.6.0 from June 26). It was behaving OK, albeit a bit slow, initially. Then, once I synced it with the watch, it became extremely laggy again, and after a while it crashed with “not responding” message. And I still couldn’t see the long trail activity from the last weekend in the log.
        @silentvoyager Got it . I think I know the issue , I have escaleted that to n1 prio. Hold on.
        (check post about syncing long duration activities)
          stokje Bronze Member @Dimitrios Kanellopoulos
          shrek3k as I did understand?
            Dimitrios Kanellopoulos Community Manager @stokje
            @stokje I made a separate thread about this. Check it out.
            • Shahaf EttedguiS Offline
              Shahaf Ettedgui
              hey 🙂
              my suunto 9 has many troubles after I updated to v2.8.24.
              the top tow are -
              1. the heart rate strap doesn’t work at any kind of sport
              2. the GPS isn’t syncing
                what is the root of the problem?
                shell I reset the firmware to have the old settings?
                Dimitrios Kanellopoulos Community Manager @Shahaf Ettedgui
                @Shahaf-Ettedgui No issues reported about straps. Can you check the battey of it?
                What do you mean GPS is not syncing and via what app ?
                  tomahawk5000 @cosme.costa
                  @cosmecosta said in S9 Baro takes very long to find GPS signal before a move:
                  @silentvoyager said in S9 Baro takes very long to find GPS signal before a move:
                  This has been a problem for me too since end of April. It looks like A-GPS data (satellite almanac) update is no longer updating reliably, at least when syncing to Movescount. A soft reset fixes that temporarily, but after a week or two the problem repeats. Currently AGPS date on my watch is 2019-06-06.
                  I have an SSU as per right know my AGPS is dated on 2019-06-17 and on Friday it was 2019-06-14, so you AGPS is out of date. Something is wrong and is not updating your AGPS.
                  Hi how can I check agps date? All what I see in settings is GPS 19073,0939bf6,140
                  Kind regards,
                  Tomek
                  Suunto 9 baro + Android
                    isazi Moderator @tomahawk5000
                    @tomahawk5000 look for assisted GPS.
                      tomahawk5000 @isazi
                      @isazi oh, right now I see 2020/03/07
                      Thank you
                      Kind regards,
                      Tomek
                      • Michal PostupalskiM Offline
                        Michal Postupalski
                        I have problems with my Suunto 9 Baro. I use Suuntolink to synchronize settings and AGPS data. Unfortunately AGPS data are not updated. AGPS file is 3 weeks old so it takes a long time to find GPS signal. The only solution is to reset my watch and sync again but it shouldn’t work like this. In my opinion this file should be updated every time the new one exists.
                        Suuntolink app version: 2.28.1
                        Suunto 9 soft version: 2.11.38
                          Dimitrios Kanellopoulos Community Manager @Michal Postupalski
                          @Michal-Postupalski why not sync with sunto app ?
                          • kabziorK Offline
                            kabzior Bronze Member
                            Recently, I have experienced this problem too with S9B.
                            Last 2 weeks it takes about 5-7 minutes to find a GPS fix.
                            I checked the AGPS on my watch, it is up to date, I always synchronize with the SA before leaving the house and the date is current day.
                            I did a soft reset, it didn’t help. I used GPS + Beidou, changed to GPS only, also no improvement.
                            I don’t think I did anything right before the problem happened (FW update or anything like that)
                            Is there anything else I can do?
                              Brad_Olwin Moderator @kabzior
                              @kabzior This is not normal. I have never had this problem. Make sure that the AGPS is there, sometimes mine does not sync properly. The only time I have had this issue is when the AGPS file is missing. Are you using the cable and the newer Suuntolink, charging via connection to the computer?
                              kabziorK 1 Reply Last reply Reply Quote 0
                              • kabziorK Offline
                                kabzior Bronze Member @Brad_Olwin
                                @Brad_Olwin Yes, AGPS is there, I always sync before activity and the date of AGPS in settings->info is up to date.
                                I charge with wall charger. The only two times I connected watch to PC and Suuntolink was when I was upgrading software.
                                • cosme.costaC Offline
                                  cosme.costa @kabzior
                                  @kabzior said in S9 Baro takes very long to find GPS signal before a move:
                                  I think your problem is that you sync before the activity. The AGPS file needs some minutes to deploy, if you sync just before the activity, when you try to get the GPS lock it is deploying so it is like it is missing but later when you check it, it is up to date, these are my findings and my own experience.
                                  In my opinion with an AGPS up to 3/4 days old you should not have issues getting a GPS lock in less than a minute and if you sync before the activity do it at least 30 minutes before it.
                                  Łukasz SzmigielŁ kabziorK 2 Replies Last reply Reply Quote 2
                                  • Łukasz SzmigielŁ Offline
                                    Łukasz Szmigiel @cosme.costa
                                    @cosmecosta if I remember correctly from similar discussions in this forum, the watch needs 15 minutes to extract the data.
                                    S9PP 2.44.52
                                    • kabziorK Offline
                                      kabzior Bronze Member @cosme.costa
                                      That is a valuable advice, thank you, will try to do that.
                                      But on the other hand - if I sync every day before the activity, even if watch needs like 15 mins to process the data, it still has AGPS data from the day before…
                                        No it doesn’t has the one from the day before, when it is updating it is like there is no AGPS file, at least in my experience.
                                        kabziorK 1 Reply Last reply Reply Quote 1
                                        • kabziorK Offline
                                          @cosmecosta OK, so I did soft reset once more, synced in the morning and went for a run in the evening. Got GPS fix in exactly 110 seconds, which is worse than before problems began, but still significantly better than 6-7 min that I had for last 2 weeks.
                                          Mff73M surfboomerangS 2 Replies Last reply Reply Quote 0
                                            Mff73 @kabzior
                                            @kabzior
                                            After the soft reset, the first fix can be little longe : the reset will aslo reset the “previous” position data (not only AGPS).
