    S9 Baro takes very long to find GPS signal before a move
    134 Posts 29 Posters 21.5k Views 29 Watching
    • Phil PowellP Offline
      Phil Powell @Richard Thygesen
      @Richard-Thygesen that’s what mine was already set on. Since doing the factory reset it seems to be working 100% quicker/better so far
      • helgonet12H Online
        helgonet12 @Phil Powell
        @Phil-Powell I meant GPS+ qzss sorry.
        • Richard ThygesenR Online
          Richard Thygesen
          Just an update. It seems to work after changing to GPS only. I got the new a-GPS file this morning.
          S9
          S9 Peak
          Race
            Richard Thygesen
            Well now I don’t get the newest A-GPS file again. This is annoying. I’m out of ideas. Has anyone found a solution?
            S9
            S9 Peak
            Race
              isazi Moderator @Richard Thygesen
              @Richard-Thygesen yesterday there were issues with Sony distributing the AGPS files, maybe related.
                Richard Thygesen
                I got it yesterday and then did a soft rest after @Dimitrios-Kanellopoulos wrote us to do that and after the soft restart I got the file directly after syncing with SA app. Today I didn’t get the new file. I’ll wait a couple of hours and see what happens.
                S9
                S9 Peak
                Race
                  @Richard-Thygesen I didn’t get the file either, and there are other people complaining so it is most probably related.
                  • Łukasz SzmigielŁ Offline
                    Łukasz Szmigiel
                    I don’t have AGPS too. Did a cold start, it took around 30 seconds and then the GPS seemed ok (tested it only via POI navigation for a while).
                    Also, I did a soft-reset yesterday which went as usual and did it today too as I’ve seen no AGPS despite SA sync and an hour or so later it was still N/A. This time after soft-reset the watch displayed a low-battery indicator and didn’t restart until I connected it to the charger, weird as it had ~40% of battery left.
                    S9PP 2.43.12
                      Dimitrios Kanellopoulos Community Manager @Łukasz Szmigiel
                      @Łukasz-Szmigiel let it be without agps.
                      Maybe it’s better for now. If I understand correctly it’s a sony fuckups on the predictions. It just will take time to find gps at first run.
                      Let it outside on the balcony etc for a while and then go for a run.
                        Łukasz Szmigiel @Dimitrios Kanellopoulos
                        @Dimitrios-Kanellopoulos sure, no problem on my side. Just reporting my findings. I’m impressed that cold start was in around 30s anyway.
                        S9PP 2.43.12
                          Phil Powell
                          So since calling Suunto and going through a factory reset on the phone with them 5 days ago, the watch worked perfectly until today when the display went completely blank again, it synced with the app fine but took a soft reset to get the display back. This is the 4/5th time since I purchased the watch at the beginning of December. Showing assisted gps not available again to.
                          cosme.costaC Richard ThygesenR 2 Replies Last reply Reply Quote 0
                          • cosme.costaC Offline
                            cosme.costa @Phil Powell
                            @Phil-Powell are you in the last firmware? I had this blank screen issue one or two firmwares ago, not anymore.
                            On the other hand, it is normal to not have AGPS info after a softreset, because it cleans cache. After the softreset you have to sync the watch with SA and wait 15 min. aprox.
                            Phil PowellP 1 Reply Last reply Reply Quote 2
                              Richard Thygesen @Phil Powell
                              @Phil-Powell it should say ”in progress” if you look directly after sync. If not you havent downloaded the file.
                              S9
                              S9 Peak
                              Race
                                Phil Powell @cosme.costa
                                @cosmecosta yeah the software is up to date. Last time it was checked was 5 days ago when doing the factory reset on the phone with them
