    Suunto 7 Altitude Issues
    321 Posts 34 Posters 69.7k Views 35 Watching
      eurohiker @isazi
      @isazi šŸ˜ž
      Phone: S24 Ultra, Android 12
      Watch: Suunto 7
        isazi Moderator @eurohiker
        @eurohiker it’s totally different from your kind of results though, I never get the S7 to overshoot. In this case I believe the S9 figures the starting altitude better, therefore the gap, and being the difference less than 10 meters it’s difficult for the GPS to solve it. Unfortunately I don’t have bigger hills to do tests here šŸ™‚
          eurohiker @cedric13
          @cedric13 I’m just updating on my Suunto 7 defect.
          ā€œI have replaced your device with a replacement unit that will come with a three (3) month service warranty, which applies if the original devices warranty has expired.ā€
          I dropped it off last Monday morning to a non DHL office (didn’t get handed over to DHL until the next day) and Suunto received it on Wednesday. It’s at the DHL office as of this morning (Monday) and will be at my door by tomorrow or wednesday.
          Tip: if you have a DHL office most likely it will be a business day or 2 faster (ship/receive) due to less mail sorting/3rd party hand off.
          This is Amazon level customer service. I’m extremely happy that it will be here before a big upcoming hiking and ski weekend.
          TDLR: Don’t be afraid to send it in if you really think it’s defective. Its completely free and took a week from small town france to finland.
          Watch: Suunto 7
            mikulass
            Hello sorry if this is off topic…, I am experiencing following issue with S7. It is measuring somehow Descent an not Ascent …, which is 0 m in the app after the activity… and additionally when data are synchronized to Relive and Strava it shows elevation 0 m in those apps as well…(luckily Strava has some correction function for elevation so I can get some elevation there…). I’m using S7 on right hand. Link to the recent activity https://www.suunto.com/sk-sk/move/mikulasstrelecky/6047bd0e148abc47025d3e17
            Could it be bug in the sw or in sensor, or any other idea? Thanks in advance. Regards.
            Aleksander HA isaziI 3 Replies Last reply Reply Quote 0
            • Aleksander HA Offline
              Aleksander H Bronze Member @mikulass
              @mikulass guess I’m not alone. Been discussing the same issue here https://forum.suunto.com/topic/6114/totalt-ascent-descent-doesn-t-seem-to-match-elevation-graph/17?_=1615327273466
              About half way down the thread I discuss having the same issue with 0m ascent. Happened 2 times so far. Both were hikes.
                isazi Moderator @mikulass
                @mikulass the graph shows that there was clearly ascent. Which version of the app are you using? This does not happen to me but now there are multiple users showing this behavior.
                Aleksander HA M 2 Replies Last reply Reply Quote 0
                  Aleksander H Bronze Member @isazi
                  @isazi I’m running 4.371 on Android. That said, I have an activity which synced with quantified-self as far back as 31 january with this issue https://quantified-self.io/user/DUrrVK0qMVZO5TtAP0r6Ox2HVLD2/event/48100bfe1ddfeee6242d124cc67d4cbbff0fc13357bac4207d10f0b9d3bfb895
                    isazi Moderator @Aleksander H
                    @aleksander-h now that I think about it, is the ascent 0 also on the watch right?
                      @isazi For the activity with 0m ascent, the watch shows no info about ascent in the diary. Only the elevation graph and descent. I guess, because the number is 0, it is assuming that there is no point showing it.
                        @aleksander-h I think that’s what the S series does, do not show the profile if ascent is 0 (or something like that). Anyway, this means this is a problem of the watch, not the app šŸ˜•
                          @isazi And a reset isn’t going to fix it, as I’ve already done that once due to getting a new phone :(.
                            @mikulass Discussion regarding the 0m ascent issue got split a bit, but see the latest posts in this topic https://forum.suunto.com/topic/6114/totalt-ascent-descent-doesn-t-seem-to-match-elevation-graph/35?_=1615371423779
                            • Z Offline
                              ZaimoRa @Dimitrios Kanellopoulos
                              @dimitrios-kanellopoulos hello, i have the same problem with suunto 7 (bad altitude 90% of the time). If i leave S7 on the table in sport mode ā€œrunā€, at the end it says i made ascent and descent, even if it never moved. it means the same thing? that the sensor is not working? i tried to wash it, to soak it and so on…but always the same problem
                                Aleksander H Bronze Member @ZaimoRa
                                @zaimora do you have an elevation graph to show how much it moved?
                                Z 1 Reply Last reply Reply Quote 0
                                • Z Offline
                                  ZaimoRa @Aleksander H
                                  @aleksander-h https://www.suunto.com/move/simor160/null
                                  it was only for 11 minutes. but otherwise when doing real activities it says around the double of the real ascent. suunto costumer service told me to send it back but i want to test it still a bit in order to be sure
                                    isazi Moderator @ZaimoRa
                                    @zaimora your link does not work (the ā€œnullā€ should be the ID of your activity). Anyway maybe testing inside can cause problems with altitude because of very bad GPS reception. Try also to leave your watch outside with clear sky view. Not saying you will not see the problem, but it is a better test.
                                      @isazi said in Suunto 7 Altitude Issues:
                                      And attach it to something if you do! I’ve heard stories of people doing this, only to have birds fly off with it šŸ˜†
                                      Fenr1rF Z 2 Replies Last reply Reply Quote 2
                                      • Fenr1rF Offline
                                        Fenr1r @Aleksander H
                                        @aleksander-h said in Suunto 7 Altitude Issues:
                                        Ah, the Vertical Week winners we have missed.
                                        • Z Offline
                                          @aleksander-h ehehe ok! thank you!
                                            I decided to do a ā€œbalcony testā€ myself to try and figure out the issue I’ve had with choppy altitude. Left the watch hanging outside for 1 hour, and this was the result
                                            https://quantified-self.io/user/DUrrVK0qMVZO5TtAP0r6Ox2HVLD2/event/0221b481fde831df8bcae7ef74e3e69133541d41664a45bbe5d6e78b748cc30d
                                            I’ve cleaned the watch a few times now. I’ve no idea what acceptable diff would be, but this seems a bit ā€œjumpyā€ to me šŸ¤”
                                            I also gave the watch about 5 min with a gps lock before actually starting the activity.
                                            freeheelerF Mff73M 2 Replies Last reply Reply Quote 2
