    Suunto 7 Altitude Issues
    321 Posts 34 Posters 69.7k Views 35 Watching
      freeheeler @Aleksander H
      @aleksander-h
      looks very “active”… first question could be: is it windy? then after either yes or no: how is the satellite reception, does the track show one spot or did it paint a nice mandala around your balcony?
      • Aleksander HA Offline
        Aleksander H Bronze Member @freeheeler
        @freeheeler Honestly not sure about the wind. I’d say “not much”, but I wasn’t paying that much attention to it. As for sattelite reception, I got a nice little square.
        If you look at the activity on quantified-self, the movement seemed to take place at 2 places. Rest of the time it seems to know its not moving (if I’m interpreting this correct, no guarantees there).
        [edit] I suppose I could find some field to go and sit in 😆
        • aeroildA Offline
          aeroild Bronze Member
          In my experience, the altimeter on the Suunto 7 works best when the watch is strapped to my wrist. And it also works very well (maybe even better) when I’m wearing it under a jacket.
          I think that the simple, but probably cost effective design (compared to the Suunto 9’s more sophisticated and costly design), with one hole in the watch case for the barometric sensor could mean that even the slightest wind can influence the altimeter. And when wearing it on my wrist my arm works as some sort of a wind shield.
          I have made tests where I walk 100 meter on a flat open space and then back to the starting point. First with the watch on my wrist and then holding the watch by the strap in my hand. On the wrist the watch only measured 1-2 meters ascent/descent. When holding the watch in my hand, it measured 30 meters ascent on a 100 meter walk. I will however do more tests before I conclude.
          Aleksander HA freeheelerF 2 Replies Last reply Reply Quote 0
            Aleksander H Bronze Member @aeroild
            @aeroild said in Suunto 7 Altitude Issues:
            Unfortunately no such thing as flat surfaces around here 😆 . Maybe I can put it in a box with holes in it on the balcony. That way it should shield it from wind 🤔
              freeheeler @aeroild
              @aeroild
              that is a crazy weird observation…
              I think the S7 baro hole design is actually very good and in some cases even better than S9B.
              @Aleksander-H
              you mean “fortunately no flat areas” 😉
              I would expect the watch can filter gusts because of the recording interval and FusedAlti.
              aeroildA 1 Reply Last reply Reply Quote 1
                Mff73 @Aleksander H
                @aleksander-h
                your balcony altitude values doesn’t looks good and not coming from a baro sensor. are you sure you have a S7baro ? 😰
                or some wind during the test ?
                • aeroildA Offline
                  aeroild Bronze Member @freeheeler
                  @freeheeler I can assure you that I am not crazy 😉 Screenshot_20210310-143113.jpg
                  On this screenshot the first walk to the turning point and back was with the watch on my left wrist. Then I shifted the watch to my right wrist and took the same walk. All the time with a stable altitude. Then I held the watch in my hand and that’s when the ascent starts. Then I put the watch back on my left wrist and you can see a sharp descent, then a slight ascent and then a stable altitude as I walked to the turning point and back. And finally I once again held the watch in my hand and walked and you can see another ascent.
                  https://quantified-self.io/user/PnlTiZJzblYOwuY7qIAxWZNG3Za2/event/f696cdc3ff3be590dee3abae585e287ce4eee0e7f68d88ade72947d4a225b5f4
                    Aleksander H Bronze Member @Mff73
                    @mff73 said in Suunto 7 Altitude Issues:
                    @aleksander-h
                    Doing a new test now with the watch in a box with ventilation holes. That should protect it from any wind.
                      Still a bumpy ride it seems, despite protecting it from wind.
                      https://quantified-self.io/user/DUrrVK0qMVZO5TtAP0r6Ox2HVLD2/event/41e635f7cf5a136c301ee66008445ff8a447b14f1afcdab6a2a6375cd5f602a5
                      freeheelerF aeroildA 2 Replies Last reply Reply Quote 0
                        @aleksander-h
                        let me do some testing with my wife’s S7 and my S9B tonight. I’ll post it here
                          @freeheeler much appreciated 🙏
                          • aeroildA Offline
                            aeroild Bronze Member @Aleksander H
                            @aleksander-h I also tried to leave my Suunto 7 on the balcony for 15 minutes. It was quite windy outside 4-8 m/s. The correct altitude should be around 80 meters. I left the watch in a box without a lid. The result is very different from yours, but still just as bad.
                              @aeroild I’d say yours is worse!
                              • aeroildA Offline
                                @aleksander-h Yeah, but the strange thing is that it worked well on my run earlier today.
                                  @aleksander-h
                                  this is what S7 and S9 did stationary on the balcony for 17 minutes.
                                  S7 is red, S9 is green
                                  S7 is darker green, S9 is yellowish-green (Edit: I know from Dimitrios, that temperature drop can affect the altitude to some extend)
                                    @freeheeler so the S7 stayed within 2 meters during those 17 min. Quite a bit better than mine then. I’ll test again tomorrow in case the weather was some how affecting things.
                                      mikulass @isazi
                                      @isazi Hi, thanks for reply, app version is 2.1.0 (8785) on ios 12.5.1 iPhone 6… and 0m is on Trail Running, Walking or Trekking activities. Also It happened few days ago when I was walking uphill - S7 started to decrease altitude…I was up around 40+ m and on the watch was shown something like -18 m…
                                        isazi Moderator @mikulass
                                        @mikulass the 0 meters issue will be fixed, from what we read today in the forum, with the next software update.
                                          mikulass @Aleksander H
                                          @aleksander-h Hi, thanks pointing the other thread, yes this is my case… and as @ISAZI pointed I see the graph 96375.jpg with ascent, but summary “table” shows Ascent 0m 43090.jpg …(apologize don’t know how to resize pictures in forum online editor)…
                                            mikulass @isazi
                                            @isazi Hi, great thanks for info. It will be mobile app update or S7 sw update?
