    Suunto 9 Peak Pro?
    1.5k Posts 145 Posters 368.9k Views 126 Watching
    • isaziI Online
      isazi Moderator @Guest
      @mountainChris I believe it is only for running/trail running sports mode.
      • lexterm77L Offline
        lexterm77 Bronze Member @isazi
        @isazi said in Suunto 9 Peak Pro?:
        Is it possible to show both power data (wrist and stryd) on same activity?
        • isaziI Online
          isazi Moderator @lexterm77
          @lexterm77 I don’t know. Probably not because only one source is picked for native power, however there is the new Stryd S+ app and it may work with that.
          lexterm77L 1 Reply Last reply Reply Quote 1
          • Mff73M Online
            Mff73
            I read here and there, that the new GPS capability of having 4 GPS system working at the same time, is “only for one mode”.
            What does it mean ? One sport mode ? One battery mode ? else ?
            and
            zhang965Z isaziI 2 Replies Last reply Reply Quote 0
              Is this app taking only data from stryd or is it combining it with watches sensors?
                zhang965 @Mff73
                @Mff73 said in Suunto 9 Peak Pro?:
                and
                I’m waiting for s9pp’s user guide
                • isaziI Online
                  isazi Moderator @Mff73
                  @Mff73 meaning that’s the only mode. No more choosing “GPS only” or “GPS+whatever”. That’s it, single mode, all systems enabled.
                  • isaziI Online
                    @lexterm77 just Stryd. It is already available in S+ store for testing.
                    herlasH 1 Reply Last reply Reply Quote 2
                    • Mff73M Online
                      Mff73 @isazi
                      Eager to see what it gives, thanks.
                      Few reviews are not saying that accuracy is that exceptionnal, just normal. Let see in my area, accuracy is quite personnal feeling 🙂 and area/time dependant.
                      • isaziI Online
                        @Mff73 exactly what you say. What the all systems mode does is allow the watch to pick the best combination of satellites from a larger pool (at most 32). In areas with good visibility of the sky, it may not make any difference at all, in other areas it will depend on how many, and which, satellites are visible. As with everything else GPS related, it changes constantly because we move, satellites move, and management of the satellites changes.
                        I appreciate that users do not have to perform divination anymore to decide which system will they use, the watch decides.
                        Mff73M lexterm77L 2 Replies Last reply Reply Quote 3
                        • Mff73M Online
                          Mff73 @isazi
                          exactely. My SSU is only glonass capable, and i tried it few times at the beginning, not sure to see difference, but maybe just not the right day/position, to see any gain.
                          Thus, it would have been divination, as you said, to enable it one day or the other.
                          Added the fact that on old watches, battery consumption for extra satellite system was increased.
                          Good, really good.
                            Is power working in power walking mode when you trail run? (Steep low cadence) or it goes to zero?
                            If it does, who needs stryd complications 😄
                            • isaziI Online
                              @lexterm77 it does not go to zero while walking, but I only tested power on roads, no trails. For trails, ask @Brad_Olwin
                              • tazidenT Offline
                                taziden Gold Members @isazi
                                @isazi do you know if the values are somehow similar to those given by stryd or like shifted by 50W or something like garmin?
                                S9PP
                                • isaziI Online
                                  isazi Moderator @taziden
                                  @taziden close to Stryd, of course not matching exactly because there is no running power standard.
                                  • tazidenT Offline
                                    @isazi yes, of course. Thx!
                                    S9PP
                                      TyreseJ4 @isazi
                                      @isazi If “dez” is Desfit, he did review the Suunto 9 Peak. I’m not a fan of his channel but I do remember this review: https://youtu.be/q0xYbvZztIA
                                        lexterm77 Bronze Member @taziden
                                        @taziden
                                        I think Stryd does not account for springiness of legs but “metabolic” cost, but I think metabolic cost has much more variables that can be accounted with a motion sensor and they are assumed to be average.
                                        I don’t think power will be standardized any time soon. You need at least volume, density, morphology, interaction between your feet and surface (metabolic cost of running on sand>solid ground). Vs load cell with cycling which is makes it so simple.
                                          Brad_Olwin Moderator @northeast_trekker
                                          @northeast_trekker said in Suunto 9 Peak Pro?:
                                          @Egika Thanks that is helpful. I like the auto scroll. Wish ascent was there
                                          Me too!
                                            lexterm77 Bronze Member @Brad_Olwin
                                            @Brad_Olwin
                                            Your thoughts on wrist power while power walking on S9PP?
                                            What is useful response time for hill repeats?
