    Suunto 9 Peak Pro?
    1.5k Posts 145 Posters 347.7k Views 126 Watching
      MoeJito Bronze Member @Dušan Ković
      @Dušan-Ković The user won’t get hurt (i.e. no electrical hazard to the user, no fire,…). The watch itself (i.e. electrical circuits) might get damaged based on information shared previously. From a (safety) risk management perspective this is considered a user inconvenience, but not a safety issue.
      S9PP
      FR 935
      FR 210
      T6D
      T3D
      • D Online
        dulko79 @Guest
        @mountainChris for gaps in the graph, did you maybe wear watch too tight or too loose during night? How are resources working for you?
        App: beta
        Phone: Iphone
        iOS
        isaziI ? 2 Replies Last reply Reply Quote 0
          isazi Moderator @dulko79
          @dulko79 @mountainChris gaps in HR during the night are known and being investigated.
            Spree Bronze Member @MoeJito
            @MoeJito I really don’t think anyone mentioned anything even close to there being any risk for the user? Electrical hazards, fire? Nothing about a “safety issue” has even been hinted to.
            I really am not getting this entire discussion at all. This watch comes with a compatible cable; nobody even mentioned that the older cable is compatible, and actually there is a specific warning not to use any other cable. The watch itself will tell you not to use the wrong cable if you try.
            And it would be “easier” to create a massive recall of all the Suunto 9 Peak cables out there for no real reason?
              trailcafe Bronze Member
              Dear all,
              one question regarding backlight behaviour:
              I would like to have backlight wrist activation only during exercise and no backlight wrist activation during normal use. When I set it to training only, backlight is always enduring normal use. Maybe someone can give me an advise on how to set it up as I would like to have it?
              Summary:
              No wrist based backlight activation during normal use (but when I press a button backlight switches on)
              Wrist based backlight activation during exercise.
                Spree Bronze Member @trailcafe
                @trailcafe This is what I have now, and it’s set up as follows.
                1. Standy => off
                2. Raise to wake => exercise only.
                This way backlight is never turned on unless you press a button in watch mode.
                  Mff73 @Egika
                  @Egika
                  thanks for this technical clarification.
                    trailcafe Bronze Member @Spree
                    @Spree Thank you… Adaptive was my standby setting. I thought, this will adapt lighting when backlight is activated based on the environement lighting.
                      @trailcafe That’s how it should work; but I suspect the expectation of how high the backlight should be vary between the watch and you :).
                        @Spree 😁 👍
                          freeheeler @isazi
                          thank you, that’s a very helpful information for all 👍
                          and it obsoletes my comment as Suunto solved and prevents the potential risk of damaging the watch with an old cable by software 🙂 …see… that’s the difference between IT and mechanical engineers 😂
                          pulling an “old” cable from the market doesn’t make sense to me and might not even be allowed from sparepart availability regulations.
                          plus: it doesn’t solve the problem (which isn’t actually a problem, as we learned!) of people having both watches and both cables.
                          good to know that’s all good 😂
                          enjoy all your nice new toys out there! weekend is coming 🏃
                          • Werner-Wilfried WasicsekW Offline
                            I just received my Suunto 9 Peak Pro 🙂
                            I’m missing the outdoor watch face, is it not available for this watch or did I miss something?
                            EfejotaE S 2 Replies Last reply Reply Quote 0
                            • EfejotaE Offline
                              Efejota Bronze Member @Egika
                              @Egika @isazi thanks for the explanation. @Brad_Olwin message was really frightening and the reason why I said that it shluld be specifically warned. It is now clear.
                              • EfejotaE Offline
                                Efejota Bronze Member @Werner-Wilfried Wasicsek
                                @Werner-Wilfried-Wasicsek it seems to have been removed, as the information can be accessed with the new widgets, I guess
                                • Łukasz SzmigielŁ Offline
                                  Łukasz Szmigiel
                                  Just out of curiosity: Is FusedTrack still there or was it removed as there’s now 1s fix for endurance mode?
                                  S9PP 2.40.44
                                    @Łukasz-Szmigiel official answer is that it has been removed.
                                    • Dušan KovićD Offline
                                      Dušan Ković
                                      Another upgrade from S9P to S9PP is conection stability and notification response speed. On S9P mobile notifications lagged (from few to 10s at one point). On S9PP notifications are instant, no lag or anything. Not sure if there were some upgrades to BT connection and similar
                                      SR
                                      SA latest beta
                                      Polar Verity Sense
                                      Pixel 6
                                        Shrek3k @Werner-Wilfried Wasicsek
                                        @Werner-Wilfried-Wasicsek said in Suunto 9 Peak Pro?:
                                        A pity as it is my favourite and got to watch face for … ever … and as the selection of attractive watch faces for everyday use is rather slim in my opinion, I hope that the outdoor watch face will at least be kept in the S9, even after the/an update 🤞
                                        using a Suunto Vertical & Suunto Wings; mostly running (AKA stomping around) and cycling mostly through the northern german "wilderness"
                                        OS - Android 15/Pixel Pro 7
                                        E isaziI 2 Replies Last reply Reply Quote 1
                                          el2thek Bronze Member @Shrek3k
                                          @Shrek3k Apparently there were issues with that watchface on the 9PP in testing.
                                            isazi Moderator @Shrek3k
                                            @Shrek3k no watch faces are removed from previous watches, just developers could not focus on make all old watch faces available for the new hardware. But you have widgets now, that have more information than before. The outdoor widget is a good substitute of the outdoor watchface.
