    Suunto 9 Peak Pro?
    1.5k Posts 145 Posters 347.5k Views 126 Watching
    • renton82R Offline
      renton82 Platinum Member @freeheeler
      @freeheeler I also noticed that pressing “lap” in pool swim activity results in this strange behavior: every time i press lap button distance gains with a random number IMG_20221110_192335.jpg
      Pressing another time maybe result in 58m…
        freeheeler @renton82
        @renton82
        pool swimming distance is motion triggered (in a way), does that happen when you keep very still, too?
        edit: …ah, I see… 31m is not a standard pool length … long day today 😉
        what pool lenght did you enter in the start menu?
        renton82R 1 Reply Last reply Reply Quote 0
        • Set_218S Offline
          Set_218
          i change my today the old s9p with the s9pp and make my first run with the footpod stryd. everything works fine, but there is no more automatic sync to stryd from the SA. Any Idea ?!
          Ambit2
          Ambit3Peak
          Spartan Ultra Black Titanium
          S9B Black Titanium
          S9P Granite Blue Titanium
          S9PP Titanium Slate
          tazidenT isaziI 2 Replies Last reply Reply Quote 0
          • tazidenT Offline
            taziden Gold Members @Set_218
            @Set_218 weird, maybe just a delay? I couldn’t run today because of $job but so far all my runs were sync’ed to stryd powercenter even without the stryd pod, just using S9PP wrist-based power.
            S9PP
            Set_218S 1 Reply Last reply Reply Quote 1
              isazi Moderator @Set_218
              @Set_218 if you haven’t used it in a while, go to the Stryd app, disconnect from Suunto, and then reconnect. New activities from that point on should sync.
              • Set_218S Offline
                Set_218 @taziden
                @taziden said in Suunto 9 Peak Pro?:
                i hope for a delay. i disconnected now and reconnect it with stryd + Suunto SA . but on my last 2 runs on monday + tuesday with the s9p everything works fine. Now the first Run with S9PP it doesn`t sync.
                Ambit2
                Ambit3Peak
                S9B Black Titanium
                S9PP Titanium Slate
                mikekoski490M 1 Reply Last reply Reply Quote 0
                • mikekoski490M Offline
                  mikekoski490 Bronze Member @Set_218
                  @Set_218 Can Stryd sync with 2 devices simultaneously? If not, make sure it is NOT connecting to the S9P, so disconnect/delete Stryd from the old watch, then restart new with pairing to S9PP?
                  Current: Suunto Race Ti
                  Set_218S 1 Reply Last reply Reply Quote 0
                  • Set_218S Offline
                    Set_218 @mikekoski490
                    @mikekoski490 said in Suunto 9 Peak Pro?:
                    From the old one is everything deleted
                    Ambit2
                    Ambit3Peak
                    S9B Black Titanium
                    S9PP Titanium Slate
                    • renton82R Offline
                      @freeheeler 25m
                        @renton82
                        your settings seem to be fine… this should not happen
                        • renton82R Offline
                          @freeheeler Isn’t it better that lap button would remains disable during pool swim? What is it for?
                          freeheelerF Jamie BGJ 2 Replies Last reply Reply Quote 0
                            @renton82
                            my wife does swim and what I’ve learned from her is that they do different sets of trainings in one session. she doesn’t use it at all (manual laps). but if somebody is very interested in a specific swim style and distance and time: I think that’s what it is for…
                            I thought you use it like that, don’t you? 🙂
                            renton82R 1 Reply Last reply Reply Quote 1
                            • renton82R Offline
                              @freeheeler For now i’ve only trying to simulate a pool swim activity, i barely use Suunto for pool swim since i can’t log my drills.
                                Jamie BG Bronze Member @renton82
                                @renton82
                                Swimming - use of lap button.
                                Don’t have the S9PP, but for the watch I do have I use it determine the rest intervals between swimming intervals. i.e. swim 10 laps, then press lap button which puts watch in rest mode, then press lap button which starts recording the next interval set etc.
                                • renton82R Offline
                                  renton82 Platinum Member @Jamie BG
                                  @Jamie-BG Even if you press lap button, watch doesn’t go in “rest mode”, if you start a new lap without touching anything, it continues to count
                                  • Stas VarazhbitS Offline
                                    Stas Varazhbit
                                    For me, the lap button in swim mode is useless at all, since only automatic laps are unloaded in TP. I use the arrow screen to track intervals in the pool.
                                    Suunto 9P
                                    Suunto 9 no baro
                                    Suunto Ambit3S
                                      Mi_chael Bronze Member
                                      Hi guys !
                                      I delete on the iOS app the S+ running Strava live segment.
                                      There is a number limitation ( 5, if i remember) and i want to have one of all my segments but i can’t sync this one.
                                      How to re install it ?
                                      Thanks a lot.
                                        Dimitrios Kanellopoulos Community Manager @Mi_chael
                                        @Mi_chael maybe try to restar the segment
                                          Mi_chael Bronze Member @Dimitrios Kanellopoulos
                                          @Dimitrios-Kanellopoulos
                                          Yes i try to select just one on Strava but it not appears on the Suunto app.
                                          But my problem now it’s i don’t have the running guide.
                                            @Mi_chael try tbe store ?
