    Suunto 9 Peak Pro?
    1.5k Posts 145 Posters 347.0k Views 126 Watching
    • Łukasz SzmigielŁ Online
      Łukasz Szmigiel @zhang965
      @zhang965 pretty amazing! I’m dead nearly instantly after I reach 170+.
      S9PP 2.40.44
        zhang965 @Łukasz Szmigiel
        @Łukasz-Szmigiel said in Suunto 9 Peak Pro?:
        It’s not amazing, it’s just youth, I normally do my 10k at 180 average. I also did at 191 on average…
          freeheeler @zhang965
          @zhang965
          • Martin VrskaM Offline
            Martin Vrska
            Greetings to all Suunto 9 Peak Pro owners!
            First of all, I would like to say that I am very satisfied with the watch - route recording, battery life, etc… But one thing bothers me a little: the step counting, which is very sensitive, so much so that you just raise your hand while sitting and the steps jump, or at least a step. Can this sensitivity be adjusted somewhere? Do you have a similar experience? Couldn’t another update fix this? Thanks for your opinions.
            Suunto Vertical - Steel Black, Strap Canyon Orange - 2.37.34
            Suunto 9 Peak Pro - Titanium Sand - 2.22.60 - my wife
            Suunto 7 - Graphite Copper - PXDZ.210716.001.A1 - sold
            Sony Xperia 10 III - Android 13
            Suunto App 4.100.12 beta
              zhang965 @Martin Vrska
              @Martin-Vrska said in Suunto 9 Peak Pro?:
              Hello Xperia 10 eye eye eye user,
              Yes, it’s the tradition since S9, the old story is S9 line has no such context sensor so the step counter is less accurate than S3 or S5 .
              My suggestion is, just forget it, don’t look it, be an ostrich.
              Martin VrskaM 1 Reply Last reply Reply Quote 4
                Martin Vrska @zhang965
                @zhang965 😊 Thanks for your quick reply and explanation. Yes, I can confirm that the wife’s S5 does not load steps like this, and I think your head-in-the-sand tutorial is an excellent idea. 😁 Thanks.
                • suzzloS Offline
                  suzzlo Moderator @zhang965
                  @zhang965 uhmmmm I’m usually running above 150-160HR, and rise to wake usually works well…but, sometimes during nights, I found imposible to trigger correctly… my point here is that, from my viewpoint, the functionality deppends in body position.
                  This is at least my impression
                  BR
                  Garmin: FR745, Edge 530
                  SA topics:
                    Brad_Olwin Moderator @Martin Vrska
                    @Martin-Vrska I think that Suunto prioritized step counting with the 3, 7 and 5 series as the individuals purchasing and using those would be more concerned with step counts. The 9 series is I think is more focused on the athletes and at least in my sphere of friends not a single one pays attention to the steps, they pay attention to hours of exercise, intensity, etc.
                    I do not know if enhancing the step detection in the 9 series would affect other functions or if the development is deemed not sufficiently worthy.
                    • U Offline
                      Ultrawalker
                      Has the 9PP a resume later function like Garmin and Coros? Or is it coming soon? That would be great when you have a longer break.
                      When pausing sports activity your watch still uses gps and more battery i suppose?
                      Suunto Spartan Ultra
                      Suunto 9 Peak Pro All Black
                      isaziI 1 Reply Last reply Reply Quote 5
                        isazi Moderator @Ultrawalker
                        @Ultrawalker said in Suunto 9 Peak Pro?:
                        This functionality is not present, but it has been requested.
                        Correct.
                        U 1 Reply Last reply Reply Quote 2
                        • U Offline
                          Ultrawalker @isazi
                          @isazi Hope Suunto will listen to our request! 😉
                            Quick question: When restarting the watch (off -> on) the watch shows 02:00 AM / Jan 2nd and will only show the correct time after a sync with the App.
                            Is that a bug or a feature?
                            If I do not have my phone with me and need to restart the watch, I cannot use it or am I wrong?
                            sartoricS tazidenT 2 Replies Last reply Reply Quote 0
                              sartoric Moderator @Guest
                              @lessthanmore said in Suunto 9 Peak Pro?:
                              Maybe in that case a gps fix it’s enough
                              SVTS - 2.40.38
                              Suunto App Android 5.2.5 beta
                                A Former User @sartoric
                                @sartoric I’ll give it a try but it’s surprisingly the very first watch not “remembering” the time. Very odd.
                                • tazidenT Offline
                                  taziden Gold Members @Guest
                                  @lessthanmore i’ve just tested on mine. You can set the date and time manually in the setting after reboot.
                                  Skip the “sync with the app is recommended” screen, then general settings, there you have the Time/Date entry in the menu, and you need to deselect “Automatic time update via Suunto app” in order to set the date and time manually. It will try to get a GPS fix and then suggest to set manually.
                                  S9PP
                                    freeheeler @Guest
                                    @lessthanmore
                                    for how long did you switch off the watch? is it possible that the battery was empty?
                                    both my kids have an S3 and the sometimes don’t use them for several weeks. when the batteries die, the watch goes back to january.
                                    I don’t think that a simple switch off/on should set time and date back…
                                    • tazidenT Offline
                                      taziden Gold Members @freeheeler
                                      @freeheeler said in Suunto 9 Peak Pro?:
                                      @lessthanmore
                                      On S9 Peak and S9PP, a reboot (stop / start) will reset the date/time unfortunately.
                                      S9PP
                                        freeheeler @taziden
                                        @taziden
                                        did you switch it off and date and time were reset?
                                        …edit: alright, thanks for the update.
                                        tazidenT 1 Reply Last reply Reply Quote 1
                                        • tazidenT Offline
                                          @taziden
                                          Yes, just tested it right now and I’ve already seen this in the past on both models.
                                          S9PP
                                            freeheeler @taziden
                                            @taziden
                                            @lessthanmore
                                            just checked, gps fix sets also time and date, without the phone
