    Suunto 9 Peak Pro?
    1.5k Posts 145 Posters 391.9k Views 126 Watching
      A Former User @jjpaz
      @jjpaz Yes, I do. The touch for me is only good when I use the maps on my F7X. That’s my second day with the Suunto, so it’s way too early for comparisons. For me the F7X is the better device.
        273 steps while I’ve been asleep? Awesome 👏, I had no idea I was a sleepwalker 🤣
          gambacorta
          Saturday I put the watch in charge (it was at 40% but I needed more autonomy) but when I went to put it on the screen was all black, as if it were off, I tried to hold down the upper button for 12 and more seconds but nothing, he’s still dead, after contacting assistance IMG_8358.JPG
          zhang965Z isaziI G K 4 Replies Last reply Reply Quote 0
            zhang965 @gambacorta
            @gambacorta said in Suunto 9 Peak Pro?:
            Send it back to Suunto support for repair.
            If you keep it as is, congratulations, you get a true all black, all black edition.
              Jugger @freeheeler
              @freeheeler said in Suunto 9 Peak Pro?:
              @Jugger
              very strange. yes, please try a soft reset and keep us updated.
              Soft reset has no effect. Few times a got normal jingle but long beep came back. Only in indoor sport. Also 10 sec loading time after mid button press didn’t go anywhere. Maybe it’s time for factory reset.
                isazi Moderator @gambacorta
                @gambacorta if you are in contact with support already, follow their advice.
                  gambacorta @isazi
                  @isazi yes thanks, I have already prepared the package for shipping
                    freeheeler @Jugger
                    @Jugger
                    I would avoid factory reset if it is the long beep “only”, and no other issue.
                    interesting thing is that my wifes pro did the long beep only once at the first trial and worked fine with every next trial.
                    is it standard or customized sport mode? maybe try to remove it and use a “new” one?
                    Zdeněk HruškaZ J 2 Replies Last reply Reply Quote 0
                    • Zdeněk HruškaZ Offline
                      Zdeněk Hruška Bronze Member @freeheeler
                      @freeheeler I am having the “long beep” at the beginning of the workout every time I am using the weight training or circuit training with the SuuntoPlus custom guide on. So it is somehow related to indoor workouts it seems. And happens to a lot of people:)
                      jjpazJ 1 Reply Last reply Reply Quote 2
                        Jugger @freeheeler
                        @freeheeler I use standard modes in indoor. I’ll make new with my own setting and try that.
                        Ok, I won’t do factory reset as everything is working well. Also that 10 sec time is recorded so no worries.
                          gerold @gambacorta
                          @gambacorta Hi, I had the same problem with my 9PP two weeks ago. After sending it to Suunto support, I got a replacement watch today…
                          • jjpazJ Offline
                            jjpaz Bronze Member @Zdeněk Hruška
                            @Zdeněk-Hruška I have sounds deactivated in my S9P but vibration is activated.
                            In my indoor activities (deactivated GPS) my watch also makes a long vibration before starting (preactivity screen) or just after the start. It’s similar to the “GPS locked” vibration before an outdoors activity so I’m suspecting if the watch is syncing GPS altough is deactivated in the activity… 🤣
                              zhang965
                              After weeks of cloudy weather,
                              I got a very bad gps track with a Sunny day.
                                gambacorta @gerold
                                @gerold thanks, I sent it yesterday, I’m waiting
                                  The watch came with 83% battery on 18/02. Now it shows 32% battery with total gps activities for nine hours - starting on 18/02 have done, including today, outdoor activities in performance mode, every day, incl. today. Everything is on, except pulse-ox (it provides unrealistic values anyway - with 84% saturation I wonder how I’m still alive).
                                  For such a microscopic watch, the battery life is freaking amazing. Battery-wise, kudos. What do you think, guys?
                                  mikekoski490M K 2 Replies Last reply Reply Quote 6
                                  • Umer JavedU Offline
                                    Umer Javed
                                    Re: the beeps above. I’ve noted that a few times also. I’ll try and see if I can capture some videos and more info.
                                    Another thing I’ve encountered sporadically is that the watch alarm sometimes keeps beeping even after I turn it off. This usually happens right as I wake up and start moving, so I’m wondering if it’s related to the watch starting to show me my sleep stats and something gets stuck. (I wear the watch to sleep.)
                                    This morning it didn’t stop beeping and I had to go to the activity menu and start an activity for it to stop. Usually too tired to pay attention to this right after I wake up or capture walks log but it’s happened maybe half a dozen times now.
                                      Is it possible to use two Suunto plus apps simultaneously during an activity?
                                      freeheelerF zhang965Z 2 Replies Last reply Reply Quote 0
                                        freeheeler @Guest
                                        @skifun
                                        unfortunately no, but it is on my wishlist, too
                                          zhang965 @Guest
                                          @skifun said in Suunto 9 Peak Pro?:
                                          Please keep calm, we don’t want s9pp get the reboot issue too soon.
                                          • mikekoski490M Offline
                                            mikekoski490 Bronze Member @Guest
                                            @skifun I totally agree on battery life. I don’t even think about the battery charge status on the watch day to day. On your blood oxygen, mine is usually spot on for overnight readings. If it’s off though I’ll try to update it during the day and find keeping still and putting gentle pressure down on the watch against my wrist, gets the fastest most accurate reading (also did this with COROS and Garmin).
                                            Current: Suunto Race Ti
