    Suunto 9 Peak Pro?
    1.5k Posts 145 Posters 363.0k Views 126 Watching
      freeheeler @Łukasz Szmigiel
      @Łukasz-Szmigiel
      aah, I think I’ve mixed up topics now 🙈 sorry
      • aroo7A Offline
        aroo7 Bronze Member
        Perhaps it has already been written about this somewhere, but I have not been able to search for anything so I will ask here.
        I have such a problem that despite deselecting the trail in the route library, they are still visible in the list on the watch (S9PP). The problem affects only 3 or 4 routes at most. I think the problem occurred after connecting to Strava. However, I’m not sure about that and I’m guessing a bit.
        I would appreciate any tips.
          Brad_Olwin Moderator @aroo7
          @aroo7 If you delete the routes from the app and did not remove them from the watch they will remain in the watch. You can fill up the watch with 15 routes as this will push the old ones out, then deselect them all if you like.
          Łukasz SzmigielŁ aroo7A 2 Replies Last reply Reply Quote 2
          • Łukasz SzmigielŁ Offline
            Łukasz Szmigiel @Brad_Olwin
            @Brad_Olwin it would be nice if there was a diagnostic menu on the watch or in SA that would allow doing this in automated fashion.
            S9PP 2.43.12
            • Jordi Genoves EscarrerJ Offline
              Jordi Genoves Escarrer @isazi
              @isazi So won´t be new watch faces coming to the 9pp to acomodate the new weather widget shortcut in the home screen?
              freeheelerF isaziI 3 Replies Last reply Reply Quote 0
                freeheeler @Jordi Genoves Escarrer
                @Jordi-Genoves-Escarrer
                I don’t think so, because new watch faces usually don’t come to previously released watches.
                I recall the peak face was an exception
                C 1 Reply Last reply Reply Quote -1
                  isazi Moderator @Jordi Genoves Escarrer
                  This post is deleted!
                    @Jordi-Genoves-Escarrer not for now, but complications may change in the near future, then you’ll be able to have the weather one in any watchface.
                    Jordi Genoves EscarrerJ freeheelerF 2 Replies Last reply Reply Quote 1
                      @isazi Ok Thank you!
                      • C Offline
                        cemoi71 @freeheeler
                        Does someone knows when the s9pp firmware update comes ?
                        is there a defined date ?
                        or will come soon after the vertical roll-out?
                        suunto 9 peak pro
                        Custom Android (LineageOS)
                          isazi Moderator @cemoi71
                          @cemoi71 May or June I would say, first the Vertical firmware will be finalized (almost there).
                            freeheeler @isazi
                            👍 ran out of kudos again 🙈
                            KetoohsK 1 Reply Last reply Reply Quote 0
                            • KetoohsK Offline
                              Ketoohs Silver Members @freeheeler
                              @freeheeler you’re to generous 🤣
                              I expect a kudos for that…
                              Karoo3 (2024)
                              Vertical allBlack (2023)
                              9 Peak Black (2022)
                              Spartan WHR Black (2017)
                              Ambit 2 Black (2013)
                                freeheeler @Ketoohs
                                @Ketoohs
                                😂 alright
                                …but now I stop, I don’t want to end up on the spammers list 🙊 😜
                                  Since the upcoming things to 9PP are discussed, do you think the different interval of measuring heart rate (second by second) will come to 9PP? I guess this will affect the battery life very much 😞 . On the other side, without second by second measurement I don’t think “Resources” can be fixed or improved, also the potential HRV status feature would be hard to implement for 9PP.
                                  W 1 Reply Last reply Reply Quote 2
                                  • W Offline
                                    wakarimasen Silver Members @Guest
                                    @Dan-Cantir I’d gladly take a hit to the battery for this
                                    Suunto Race Titanium
                                    Suunto Ambit3 Peak
                                    Polar H10
                                    Polar OH1
                                    • HighlandsH Offline
                                      Highlands
                                      My watch face for this week:
                                      • aroo7A Offline
                                        aroo7 Bronze Member @Brad_Olwin
                                        thanks @Brad_Olwin I added 15 routes and the old ones were pushed out.
                                        However, I noticed another problem - despite adding a route to the watch in the app, not all routes were available on the watch. I had 15 routes marked in the app and only 8 were visible in the list on the watch. I synced the hardware several times but nothing changed. Is this related to some kind of memory limit? Especially when syncing long routes?
                                          Egika Platinum Member @aroo7
                                          @aroo7 how many POIs do you have at the same time?
                                          aroo7A 1 Reply Last reply Reply Quote 0
                                          • aroo7A Offline
                                            aroo7 Bronze Member @Egika
                                            @Egika one! 🙂
