    No-Map-Problem
    299 Posts 65 Posters 116.9k Views 62 Watching
    • R Offline
      Racoon6
      Re: Suunto Vertical: Bug Collection
      Hello, the “no-map problem” also exists here! FW is up to date, map download was successful, soft reset / hard reset without success. Region: Regierungsbezirk Stuttgart
      EgikaE S 2 Replies Last reply Reply Quote 2
        Egika Platinum Member @Racoon6
        @Racoon6 can you please send logs from SA after unseccussfully displaying maps?
        Then tell me in PM your account email und approx time of logs sent.
        Devs will look into it
        Thx!
        • ChrisAC Offline
          ChrisA Platinum Member @Egika
          @Egika I am pretty sure, there’s a problem on Suunto’s side. It can’t be coincidence, that the maps arround Stuttgart and Ulm are not working on different devices for different users. I tried installing the map of “Regierungsbezirk Tübingen” on an my iphone at home, twice, and also like @Racoon6 and @SirMcKey the “Regierungsbezirk Stuttgart” - which did not work.
          I then hard reset the watch, went to the office, paired the watch with an Android device, set up my office WLAN, and again map of “Regierungsbezirk Tübingen” downloaded with “download complete message” and “green” tick. But after going outdoors, there is no map. I sent my logs to @Dimitrios-Kanellopoulos
          Currently Race I
          freeheelerF EgikaE 2 Replies Last reply Reply Quote 0
            freeheeler @ChrisA
            @ChrisA
            I’ve downloaded Freiburg where I’ll spend the weekend… it’s next to Tübingen and I will test and post here tonight once tested
              Egika Platinum Member @ChrisA
              @ChrisA yes, it is a problem on Suunto’s side.
              This is why I wrote the comment right above yours.
              Please follow thiese steps to have it resolved.
              I am in direct contact with the devs and am sure that it can be fixed within short time, once we receive the logs and ideally also the position of where the maps don’t show.
              If you have sent your details to Dimi, he will also take care of it. (y)
              ChrisAC 1 Reply Last reply Reply Quote 4
              • ChrisAC Offline
                @Egika Ok thanks - no problem, new product - anyone should be aware, that there are some glitches. As long as I know that I am not the problem (being too dumb to set it up the right way, or there is a weird technical problem on my side) I can wait for an solution on Suunto’s side.
                For my map position (at the office, no map here also): 48.43332°N 9.96657°E
                Currently Race I
                freeheelerF L 2 Replies Last reply Reply Quote 0
                  freeheeler @ChrisA
                  @ChrisA
                  great mindset 🙏
                  ChrisAC 1 Reply Last reply Reply Quote 3
                  • ChrisAC Offline
                    ChrisA Platinum Member @freeheeler
                    @freeheeler On of my grandmasters alway quoted Laoze, when we asked him, when he will teach us a certain technique: “Have patience. Wait until the mud settles and the water is clear. Remain patient and then the right action arises by itself.” The older I get, the more I appreciate his teachings, often we run an hesitate through life and nothing gets done any faster by doing that 🙂
                    Currently Race I
                    freeheelerF BrunoHB 2 Replies Last reply Reply Quote 7
                      lessthanmore Bronze Member @ChrisA
                      @ChrisA Did you download all suggested maps?
                      I live near three regions and the app suggested to download all three.
                      I do not have any issue so far.
                      ChrisAC 1 Reply Last reply Reply Quote 1
                      • ChrisAC Offline
                        ChrisA Platinum Member @lessthanmore
                        @lessthanmore yes I did (although the ap did not suggest it). I did a walk yesterday and the area I walked is exactly where the map should be:
                        thats where I walked:
                        and that’s the corresponding area on the map I had downloaded before (and for which the Vertical told me, that it had the download completed). So actually there should have been a map 🙂
                        Currently Race I
                          freeheeler @ChrisA
                          @ChrisA
                          that is so true, but only few people know or accept it.
                          I thought that your sport has an influence in that 👍
                          grass is not growing faster when you pull it
                            zhang965
                            Bloody hell, I did a walk, when I begin the map is still there, 10 minutes after it became empty. And I et off route message even I’m on the route.
                            Can’t believe this.
                            StefanoMorganS 1 Reply Last reply Reply Quote 0
                            • StefanoMorganS Offline
                              StefanoMorgan Bronze Member @zhang965
                              @zhang965 Have you contacted Suunto Support? 🤐
                              Suunto 9
                              zhang965Z ChrisAC 2 Replies Last reply Reply Quote 1
                                zhang965 @StefanoMorgan
                                @StefanoMorgan said in No-Map-Problem:
                                You pick my line
                                Can’t believe this.
                                • BrunoHB Offline
                                  BrunoH Gold Members @ChrisA
                                  @ChrisA another great man Freddie Mercury used to say “I want it all and I want it now!” 😁
                                  Compasses: M-311, A-10, SK-7
                                  • mikekoski490M Offline
                                    mikekoski490 Bronze Member
                                    While still waiting for my Vertical to arrive, I thought I would read through the Suunto Vertical user manual online. Just FYI for the Admins here, there is a broken link on the Offline maps section: https://www.suunto.com/en-ca/Support/Product-support/suunto_vertical/suunto_vertical/navigation/offline-maps/
                                    A more detailed instruction on how to setup a wireless network and download offline maps in Suunto app is available here.
                                    The hyperlink for ‘…available here.’ is broken and gets the following:
                                    404 ERROR
                                    PAGE NOT FOUND
                                    Sorry! The page you are looking for does not exist anymore.
                                    Current: Suunto Race Ti
                                    • ChrisAC Offline
                                      ChrisA Platinum Member @StefanoMorgan
                                      @StefanoMorgan Thanks for your hint, but I don‘t see what that would be good for, other than they would also tell me, that there‘s a problem. As long as I know theres nothing I can do, I‘ll wait until Suunto comes up with an solution
                                      Currently Race I
                                      • ChrisAC Offline
                                        ChrisA Platinum Member @BrunoH
                                        @BrunoH yeah… it didn’t go so well for him. What a pitty he died so early. He was such a great musician
                                        Currently Race I
                                          StefanoMorgan Bronze Member @ChrisA
                                          @ChrisA If you read most of his comments, i think you understand how it is meant😉
                                          Suunto 9
                                          • ChrisAC Offline
                                            @StefanoMorgan now i got it 😅
                                            Currently Race I
