    Suunto wristband
    84 Posts 35 Posters 14.8k Views 31 Watching
    • TieutieuT Online
      Tieutieu Platinum Member @Jonathan C
      @Jonathan-C I use the White one, alternatively. I don’t feel a big difference with standard ones.
      So, what makes me use the white (or the green, black, orange, lime or sand…yes I know I have too many 22 straps…) is mainly the match with my outfit ! 😁
      • J Jonathan C referenced this topic on
      • BrunoHB Offline
        BrunoH Gold Members
        Ambassador nylon strap was always my favorite one when I was using S9B. For some reason it feels much softer than the new Suunto Explore I nylon straps. Does anyone have any hints on how to soften Suunto nylon straps? A lot of heavy use?
        My son took that old S9B, but he let me have the Ambassador strap. I finally managed to make it fit Vertical. I used hot water to soften the nylon around the 24mm pins in order to pull them out. With a little more hot water I was able to squeeze the strap between Vertical’s horns using standard 22mm pins. Now my Vertical is complete 😀
        The strap is a bit crumpled but works just fine!
        Compasses: M-311, A-10, SK-7
          Mff73 @BrunoH
          @BrunoH said in Suunto wristband:
          i may read that the new Suunto Race straps are softer than previous ones.
          GiPFELKiNDG EgikaE 2 Replies Last reply Reply Quote 0
            GiPFELKiND Silver Members @Mff73
            @Mff73 where i can buy the new Race bands? Seems not in Suunto Store
            BrunoHB 1 Reply Last reply Reply Quote 1
            • BrunoHB Offline
              BrunoH Gold Members @GiPFELKiND
              @GiPFELKiND those are generic. As long as the band is 22mm wide it fits Race. As for the nylon ones I can only find “Explore I” series bands in Suunto store and IMHO those are not as comfortalbe as my old Ambassador band like I described above.
                Egika Platinum Member @Mff73
                @Mff73 said in Suunto wristband:
                The Race silicone straps are not really softer, they are more stretchy, due to more grooves.
                • Joakim ÅgrenJ Offline
                  Joakim Ågren
                  Do anyone here have the lime green version of the 22 mm Athletic 5 silicone strap by Suunto? I keep getting confused, on some pictures it appear very bright lime/neon yellow but on others comes across as rather pale. Would like to see some good pictures showing more truly it’s accurate colours? I only want it if it is a bright colourway…
                    freeheeler @Joakim Ågren
                    @Joakim-Ågren
                    I would describe it as bright yellow
                    E I 2 Replies Last reply Reply Quote 2
                      Elipsus Silver Members @freeheeler
                      I got a “Wocci” wristband from amazon link, the nylon woven in blue
                      Pretty nice overall, very comfortable to watch and the “eslasticness” make it easy to have it relatively tight without soreness, the color is a bit dull
                      Only complain is that I’m basically at the very very limit in terms of size (minimum), I have 165mm wrists, so, relatively slender wrist, bu that means that any woman will have a hard time getting it to fit, if the strap could be 1-2cm shorter that would be really “unisex” (despite that they advertise it as being unisex.
                      • flucaF Offline
                        fluca Silver Members @Jonathan C
                        @Jonathan-C It is arrived and it is comfortable and airy just like the original one. The RED one, I must admit is not ideal when you are dressed for office. It’s a punch in the eye (as we use to say in Italy).
                          My favorites are the Athletic and the Microfiber. The latter is very comfortable during work days
                          • I Offline
                            i5boi @freeheeler
                            @freeheeler what mount is that on your bars for I’m assuming is a light? Is that the Suunto watch mount?
                              Greennorth
                              Would anyone be able to compare the feel of the different watch straps available from Suunto right now? I have a S9PP with the Ocean Blue (Athletic 3 Silicone Strap) that it comes with, but I find it a little stiff and less comfortable compared to the straps from my previous Suunto watches.
                              Are the current silicone straps all basically the same in terms of feel? Or are there significant differences? Are the urban or vertical ones softer? I would like to try the microfiber one but the blue has been out of stock for a while.
                              Thanks - I appreciate any input!
                              Traverse / Suunto 3 Fitness / S7 / S9PP
                              ? TieutieuT 2 Replies Last reply Reply Quote 0
                                A Former User @Greennorth
                                @Greennorth said in Suunto wristband:
                                my opinion: I have worn my friend’s Race and the strap is much more comfortable than the ones available on the suunto store. Unfortunately, it is not yet available. The microfiber one is also very comfortable but it’s a sort of “meh” when used for activities
                                • TieutieuT Online
                                  Tieutieu Platinum Member @Greennorth
                                  @Greennorth I have been using almost all kind of models with my S9B (microfiber, leather, nylon, silicone…) and now just 3 different ones with my SV (original SV ones : Green Forest/Orange/Lime/black, Athletics 5 suunto branded - which seems similar to Athletics 3, and an Urban 4).
                                  Among all, the Athetics 5 is the softer to me.
                                  It seems like @robis said that the SR strap is better. I wait for it.
                                  I didn’t got a microfiber again because I wasn’t convinced with it on my S9B : maybe the watch was too heavier and bulky for it, and it got durty very fast. I’d never used it for training.
                                  [@GiPFELKiND I posted you a pm with the link ; but I don’t promiss you it will be “bug free” if you order it !! 😇 😇 ]
                                  GiPFELKiNDG Marius Jacobsen EggerudM isaziI 3 Replies Last reply Reply Quote 7
                                    GiPFELKiND Silver Members @Tieutieu
                                    @Tieutieu cool what bag is this!?!?!? 😍😍😍😍Want to buy the same. Please sent me Message 🤗
                                    • Marius Jacobsen EggerudM Offline
                                      Marius Jacobsen Eggerud Silver Members @Tieutieu
                                      @Tieutieu Please share link to the bag.
                                      Suunto Ambit 3
                                      Suunto Spartan Ultra
                                      Suunto Race Ti
                                        isazi Moderator @Tieutieu
                                        @Tieutieu is the bag made on purpose to carry watches? 🙂
                                        • TieutieuT Online
                                          Tieutieu Platinum Member @isazi
                                          @isazi it can (mp)
                                            Greennorth @Guest
                                            @robis and @Tieutieu Thank you! That is helpful. I’ll maybe wait to see if the Race strap comes out.
