Suunto wristband
@Mattg576 Only way is loose strap + get it higher or tight and wear it lower. :D.
I noticed that Athletic 5 is much softer for skin than original SV, even over time, but SV original one is much easier to find good spot on hand. -
@Mattg576
I’ve used an Athletic 5 strap for about 5 months and it doesn’t seem to have stretched. Like you, I find it’s either a bit loose or a bit tight. I wear it in the tighter hole because I don’t like the watch bouncing around and don’t notice after a short while.
The best Suunto strap I’ve had for comfort, hole spacing and stretch was the Athletic 1 that came with the 9 Peak. But it’s only available in relatively subtle colours, pink excepted. -
@MKPotts Thanks for that, I’ve also been going with the tighter hole & as yet my hand hasn’t fallen off. I’ve started doing wrist rotations with dumbbells to try & bulk up to the next hole LOL
TBH I found the original Race strap really comfortable & could adjust it perfectly for my wrist (just a bit boring in plain black).
Any idea why Race 1 strap is probably only one that is not sold separately? Used 9P for a short time, 9PP, Vertical Ti Solar, Race 1 Ti and now Race 2 Ti, and Race 1 Ti strap was most comfortable silicone I’ve used. I’ve used default Race 2 strap + Run’s textile, but I like silicone becouse its easy & fast to clean after training, and pretty comfortable. Its probably only watch that can be bought only with watch. Its so scretchy and better than R2. So good i kept R1 Ti strap when I sold this watch, but its gettin worn out.
