    Suunto 5
    240 Posts 51 Posters 24.7k Views 50 Watching
      A Former User @Václav Král
      @Václav-Král said in Suunto 5:
      @silentvoyager OMG. I would never take a watch without OHR. S9 works fine, 24/7 OHR is super COOL and during running and hiking is very useful. And where OHR fails, I can use HR strap.
      But I don´t want never ever sporttester without OHR.
      Are you absolutely sure you are getting correct results? I ran with a HR belt for many years, so I know quite well what kind of HR I should have for different levels of effort. It takes a lot of effort for me to push my HR above 165, and more typically it is in 140-150 range. But with optical HR it goes straight to 170-190 range and pretty much stays there, occasionally going above 200. So basically it measures my cadence rather than HR. Occasionally it drops to the correct HR but at least 75% percent of the time it is wrong. I tried many different suggestions how to make it more reliable, but short of shaving my arms, which I won’t do, the results are the same As I said, I also looked at a few other runners who I know are running with S9, and see the same thing.
      If you are young and have a short history of running, your typical HR ranges could be fairly close to your cadence, so you may not know if you are getting correct values or not.
      • Armin S.A Offline
        Armin S. @zhang965
        @zhang965 said in Suunto 5:
        could it be better if suunto 9 = 7, suunto 9 baro =9;
        so we already have 3 5 7 9?
        I do not think they will rename existing models. Rather, I believe that the new S5 with baro etc. will be later the next S7.
          zhang965 @Armin S.
          @Armin-S said in Suunto 5:
          yes but they renamed once suunto 9 to suunto 9 baro
            Egika Platinum Member @zhang965
            and I thought both exist in parallel ?
            Race S All Black - TI Canary - Titanium Courtney
              zhang965 @Egika
              @Egika
              Yes but initially suunto 9 has baro, just months after they showed a suunto 9 without baro and renamed old 9 to 9 baro
                zhang965
                Suunto 9 Baro
                Just released in June 2018 so don’t expect a replacement before 2020 This is the device reviewed as “Suunto 9” by most reviewers, but is not the newer, crapper Suunto 9
                Suunto 9
                Just released in September 2018 so don’t expect a replacement before 2020. This is the name in all the reviews, but a newer, slightly crap version of the device. Buyer beware, make sure you know what you’re buying. Yes, Suunto do have a watch called the Suunto 9 in both mid-range and high-end. Madness.
                  Dimitrios Kanellopoulos Community Manager @zhang965
                  what do you mean? How is the non baro version mid range if I understand correctly ?
                    zhang965 @Dimitrios Kanellopoulos
                    @Dimitrios-Kanellopoulos said in Suunto 5:
                    I just copied it from GPS rumors
                    • suzzloS Offline
                      suzzlo Moderator
                      I think Suunto 7, will be Spartan Sport evolution (sure you think same) and this model has 3 variants: Normal/Wrist/Baro
                      Non Wrist model makes no sense, so I think, we could see 4 models
                      • Suunto 5 => Baro and Non Baro
                      • Suunto 7 => Baro and Non Baro
                      Differences between 5 and 7 should come (from my perspective) in:
                      • Design => based on SSS, no external antenna
                      • Battery => battery between 5 and 9
                      • Firstbeat => they could add Training Load, or other…
                      We will see 🙂
                      BR
                      Garmin: FR745, Edge 530
                      SA topics:
                      D zhang965Z NicolasPN 3 Replies Last reply Reply Quote 0
                        dulko79 @suzzlo
                        @suzzlo what about price difference between 5 and 7? 😃
                        App: beta
                        Phone: Iphone
                        iOS
                          zhang965 @suzzlo
                          @suzzlo said in Suunto 5:
                          We will see 🙂
                          BR
                          Why they add more firstbeat features to 7? If I followed the 3 5 9 logic, 7 should have less firstbeat features and 9 has non firstbeat features
                          • suzzloS Offline
                            suzzlo Moderator @dulko79
                            @dulko79
                            S3 -> 200
                            S5 -> 300
                            S7 -> 450
                            S9 -> 600
                            makes sense?
                            SA topics:
                            zhang965Z D 2 Replies Last reply Reply Quote 1
                              zhang965 @suzzlo
                              @suzzlo so S7 baro is upper than s9’s price?
                              S5 baro is upper than s7?
                              • suzzloS Offline
                                suzzlo Moderator @zhang965
                                @zhang965 the S7 should have 8 Firstbeat features, since 5 has 6 (https://www.firstbeat.com/en/consumer-product/suunto/suunto-5/)
                                SA topics:
                                Armin S.A ? 3 Replies Last reply Reply Quote 0
                                • suzzloS Offline
                                  @zhang965 no idea, I’m just saying what makes sense to me, no info here, just hopes!
                                  SA topics:
                                  • Armin S.A Offline
                                    Armin S. @suzzlo
                                    … or 18 features like Forerunner 945 🤔
                                      zhang965 @Armin S.
                                      Or a new model called suunto 18 with all of 18 firstbeat features?
                                        dulko79 @suzzlo
                                        @suzzlo 150 jump from 300 to 450 seems a bit steep for better materials, compass, better battery…unless more FB features are added to 7. What about release date?
                                        App: beta
                                        Phone: Iphone
                                        iOS
                                        zhang965Z suzzloS 2 Replies Last reply Reply Quote 0
                                          zhang965 @dulko79
                                          @dulko79 said in Suunto 5:
                                          It’s just a guess from suzzlo
                                          • suzzloS Offline
                                            @dulko79 If I can buy one S7 in black friday for less than 400€ I will be very happy 🙂
                                            SA topics:
