    Suunto 5
    240 Posts 51 Posters 40.9k Views 50 Watching
      dulko79
      Anyone bought it today? Any thoughts regarding build quality and new features? ☺
      App: beta
      Phone: Iphone
      iOS
        dulko79
        I have read in dcrainmaker’s pre-review that 24/7 HR tracking is significant load for battery - approx. 3 % per hour. Has anyone else noticed such behaviour? Is this normal or temporary problem due to beta software and will be fixed later with updates?
        App: beta
        Phone: Iphone
        iOS
        Fiox89F NicolasPN Saketo NemoS 3 Replies Last reply Reply Quote 0
        • Fiox89F Offline
          Fiox89 Bronze Member @dulko79
          @dulko79 from what I know is “expected” behavior which also happens on other models too. Continuous heart rate readings requires a lot of battery power, as does sleep monitoring. Maybe there will be more reliable information soon
          Suunto Spartan Sport
          FW: 2.8.24
          SA: 4.17.7 beta
          • NicolasPN Offline
            NicolasP @dulko79
            @dulko79 I have a SST and I think that he said the same. However I can confirm that I have never experienced such battery consumption.
            SST
              Nope for sure not 3%
              • Saketo NemoS Offline
                Saketo Nemo Moderator @dulko79
                @dulko79
                Ray says that ? Mmmm…very strange ! 🙃
                  dulko79 @Saketo Nemo
                  @Saketo-Nemo was that a serious or sarcastic question? 😃
                  App: beta
                  Phone: Iphone
                  iOS
                  Saketo NemoS 1 Reply Last reply Reply Quote 0
                    @dulko79 second one 😉
                    Luís PintoL 1 Reply Last reply Reply Quote 1
                    • Luís PintoL Offline
                      Luís Pinto Platinum Member @Saketo Nemo
                      https://the5krunner.com/2019/06/12/suunto-5-review/
                      SR
                        Brad_Olwin Moderator @Dimitrios Kanellopoulos
                        @Dimitrios-Kanellopoulos said in Suunto 5:
                        Agreed not 3%
                          dulko79
                          Agreed not 3 % 😉
                          App: beta
                          Phone: Iphone
                          iOS
                          whl_89W 1 Reply Last reply Reply Quote 0
                          • whl_89W Offline
                            whl_89 Bronze Member @dulko79
                            I bought my girlfriend a s5 and after a fews runs i am a bit confused because the ascent recorded by the watch is about 50% of the real ascent. I use the ssu. I know s5 has no baro but at least it should record the GPS ascent which is about the same i her from the ssu. Is this a known issue?
                            suzzloS Brad_OlwinB 2 Replies Last reply Reply Quote 0
                              Have you tried a full vertical track, without d- ?
                              Going from 300m to 800m should results 500d+, in S5 and also in SSU.
                              In tracks where there are many up and down you will not have the same results because GPS device store d+ only each 7m gained, BARO device each 3m.
                              btw, 50% less is too much…
                              • suzzloS Offline
                                suzzlo Moderator @whl_89
                                @whl_89 Same here with SSSW (no baro). Are ascend step sort? Usually in my 10-15k run with +400m always have less than +200m
                                Garmin: FR745, Edge 530
                                SA topics:
                                • whl_89W Offline
                                  whl_89 Bronze Member @Saketo Nemo
                                  @Saketo-Nemo i just made two runs with ups and downs but both around 50% of actual ascent. I mean i am aware of the non existing baro in s5 but this huge differences are really bad for a 300€ device
                                  • whl_89W Offline
                                    whl_89 Bronze Member @suzzlo
                                    @suzzlo mixed ascents but shouldnt there bei an algorithm to overcome those recording gaps within those 7m?
                                      just my curiosity: can you share the link of the two activity ? (also in pvt if you want)
                                      whl_89W 2 Replies Last reply Reply Quote 0
                                      • whl_89W Offline
                                        @Saketo-Nemo I will upload them later
                                        • whl_89W Offline
                                          @Saketo-Nemo
                                          S5:
                                          link text
                                          SSU:
                                          link text
                                          • Dušan KovićD Offline
                                            Dušan Ković
                                            Out of curiosity, I wanted to see the altitude diference, so I imported both to QS:
                                            S5:
                                            SSU:
                                            Both have similar graph shape and are in similar altitude ranges, but SSU seems a bit jagged compared to the S5 which looks smooth. Not sure which one is correct. But I’m guessing that SSU has more altitude difference because all those small spikes, also bigger drops in altitude on multiple places.
                                            SR
                                            SA latest beta
                                            Polar Verity Sense
                                            Polar H10
                                            Pixel 6
