    Suunto 5
    240 Posts 51 Posters 24.3k Views 50 Watching
    • whl_89W Offline
      whl_89 Bronze Member @Dušan Ković
      @Dušan-Ković If i plan this route in komoot or Suunto App altitude differences of ssu is quite correct and s5 ist about 50%. SSU works fine i think
      Dušan KovićD suzzloS 2 Replies Last reply Reply Quote 1
      • Dušan KovićD Offline
        Dušan Ković @whl_89
        @whl_89 One of my friends wants to buy S5, so I’m searching for possible problems with watch. Maybe this is one of the problems with S5. Have you tried GPS, GPS+GLONASS or GPS + GALILEO on the same route with S5?
        SR
        SA latest beta
        Polar Verity Sense
        Pixel 6
        whl_89W Armin S.A sartoricS 3 Replies Last reply Reply Quote 0
        • suzzloS Offline
          suzzlo Moderator @whl_89
          @whl_89 same here
          Garmin: FR745, Edge 530
          SA topics:
          • whl_89W Offline
            @Dušan-Ković i would still recommend it great watch
            • Armin S.A Offline
              Armin S. @Dušan Ković
              @Dušan-Ković YES, there is a little problem ☺
              Run 16.6. with S5 GPS+Galileo. After 0:30 it’s very faulty:
              Same route 10.6. with S3F (connected GPS):
              Same days and same routs exports to Strava:
              16.6.
              10.6.
              Start level 40…42m, highest point 50…52m would be correct!
                sartoric Moderator @Dušan Ković
                @Dušan-Ković said in Suunto 5:
                My 2 cents … if he’s some kind of mountaineer , tell him to go for a baro watch otherwise GPS only is ok.
                SVTS - 2.40.38
                Suunto App Android 5.2.5 beta
                Dušan KovićD 1 Reply Last reply Reply Quote 1
                  Dušan Ković @sartoric
                  @sartoric @Armin-S @whl_89 Thanks to all. I’ll send him the link to this thread 🙂
                  SR
                  SA latest beta
                  Polar Verity Sense
                  Pixel 6
                    Brad_Olwin Moderator @whl_89
                    @whl_89 said in Suunto 5:
                    I bought my girlfriend a s5 and after a fews runs i am a bit confused because the ascent recorded by the watch is about 50% of the real ascent. I use the ssu. I know s5 has no baro but at least it should record the GPS ascent which is about the same i her from the ssu. Is this a known issue?
                    I have done a lot of runs with both the S5 and S9 together, most of the time on the same arm. The S5 is always short in altitude, I mentioned this much earlier in the thread. If you care a lot about real time vertical it is not the right watch. However, I rarely see 50%, most of the time my differences are below 20%. The worst scenario for the S5 are lots of small hills as it does not record a change unless 7m. On big climbs it is much better. If you like I can post some of my SkiMo runs or runs with at least 500m altitude change. I do think that GSP+Galileo gives better altitude readings on the S5 but I have not thoroughly analyzed this yet. Third party sites (Strava, etc) will correct the altitude so in the end it isn’t that big a deal in my opinion.
                    I still think the S5 is a great watch and most of the time I use it for my weekday runs and just let the 3rd party apps correct the altitude. The SSU and S5 should be similar for ascent. Make sure AGPS is current and I would use GPS+Galileo.
                    Dušan KovićD 1 Reply Last reply Reply Quote 3
                      Dušan Ković @Brad_Olwin
                      @Brad_Olwin maybe suunto app should add altitude correction as one of the features. So users can choose to see corrected altitude and original as watch recorded
                      SR
                      SA latest beta
                      Polar Verity Sense
                      Pixel 6
                        Brad_Olwin Moderator @Dušan Ković
                        @Dušan-Ković Probably not a bad idea but… if you have more than one watch as do I, I would want the setting toggled. Better yet, the app could detect you have a watch with no barometer and automatically correct. Maybe this should be added as a feature suggestion?
                        Dušan KovićD 1 Reply Last reply Reply Quote 0
                          @Brad_Olwin I don’t have two watches, I only have S9B, but elevation correction would be good for users with non Baro watches. It should be implemented to SA. Also, users with Baro watches could check if altitudes are correct.
                          SR
                          SA latest beta
                          Polar Verity Sense
                          Pixel 6
                            The correction for Altitude is less precise than the barometric watches, I have checked this many times on Training Peaks. It depends on the filters are algorithms used.
                              dulko79
                              One little remark regarding the strap. During sport activity the watch should be worn 2 fingers above the wrist bone to get good HR reading. For some users due to this position the strap could be too short or on the limit, therefore slight increase of strap length could be useful. ☺
                              App: beta
                              Phone: Iphone
                              iOS
                              • vicarokaV Offline
                                vicaroka
                                Hi!
                                I am a new Suunto 5 user, and the watch keeps restarting and freezing after some minutes. The down arrow is displayed, and after a hard reset, the issue repeats after some minutes. Did software update to latest, not using movescount (only Suunto app).
                                Any suggestions?
                                Many thanks.
                                KR
                                  sartoric Moderator @vicaroka
                                  @vicaroka said in Suunto 5:
                                  What do you mean for hard reset, factory reset + re-flashing the FW ?
                                  Maybe it’s a defective unit. Contact support via email
                                  SVTS - 2.40.38
                                  vicarokaV 1 Reply Last reply Reply Quote 0
                                  • vicarokaV Offline
                                    vicaroka
                                    This post is deleted!
                                    • vicarokaV Offline
                                      vicaroka @sartoric
                                      @sartoric
                                      Yep, soft-reset: upper right+left button for 12 sec
                                      hard-reset: from Suntoolink to flash firmware again.
                                      sartoricS Brad_OlwinB 2 Replies Last reply Reply Quote 1
                                        @vicaroka
                                        So the best option is to contact support
                                        SVTS - 2.40.38
                                          Brad_Olwin Moderator @vicaroka
                                          @vicaroka This should not occur. If you have done a full factory reset you should contact support. The S5 is not recognized by MC so that doesn’t matter.
                                          • Stanley PonS Offline
                                            Stanley Pon @Mi_chael
