    S9B upgrade / factory reset problem (v2.10.26)
    40 Posts 7 Posters 2.5k Views 6 Watching
      azorg
      Hello friends!
      I am trying upgrade software on Suunto 9 baro v2.10.26 to last version (v2.12.30).
      Watch freeze on upgrade screen (second dot flashing).
      I tried to factory reset but have the same problem on update process.
      I use last official suuntolink v3.1.4.
      Suntolink v2.8.5 (tested too) is too old and don’t work correctly.
      I test some windows machines.
      Is any idea?
      I want to try factory reset and upgrade step by step using old version SuuntoLink
      I am looking for old version Suuntolink_installer.exe (v3.1.3, v3.0.2, v2.28.1, …) but can’t find in WWW.
        azorg
        Some screenshots of Suunto Link
        • surfboomerangS Online
          surfboomerang
          Did you reset the watch as asked by Suunto Link?
          I had this issue long ago. Turned out to be a faulty cable.
            azorg @surfboomerang
            @surfboomerang
            Yes. Overload “v2.10.26 -> v2.10.26” and factory reset - success.
            But upgrade watch form v2.10.26 to v2.12.30 fail 😞
              Did you try to contact support?
              SVTS - 2.40.38
              Suunto App Android 5.4.5 beta
                azorg @sartoric
                @sartoric not yet…
                  sartoric Moderator @azorg
                  @azorg
                  I would
                  SVTS - 2.40.38
                  • Birgit WeissB Offline
                    Birgit Weiss
                    I have the same problem and I don`t know what to do.
                      A Former User @Birgit Weiss
                      I think you can force the update manually. @Dimitrios-Kanellopoulos can you confirm/help?
                        Search for manual firmware upgrade
                        SVTS - 2.40.38
                          azorg @sartoric
                          @sartoric Hmm…
                          My search fail.
                          What software I must use?
                          Suunto Link or another?
                            isazi Moderator @azorg
                            @azorg check this post from Dimitrios https://forum.suunto.com/topic/5396/suunto-spartan-ultra-update-not-available/10
                              A Former User @isazi
                              @isazi said in S9B upgrade / factory reset problem (v2.10.26):
                              This post only has firmware link for spartan, not s9b.
                              I also search and couldn’t find the links for S9B, although I thought I have seen it somewhere
                                isazi Moderator @Guest
                                @André-Faria that’s for the procedure. For the firmware, the name of the S9 is Ibiza. There are links in the forum 🙂
                                  Here it is for the owner of the topic http://firmware.geo.movescount.com/production/Ibiza-fw_2.12.30.3539-F.zip
                                  A 1 Reply Last reply Reply Quote 2
                                    azorg @Guest
                                    @André-Faria Thank you! But manual firmware freeze too 😞
                                      surfboomerang @azorg
                                      @azorg When you connect the watch to your pc do you see a warning from Windows about a unrecognizable device? Assuming Windows is your OS 🙂
                                        @surfboomerang I don’t see any windows warnings…
                                          Mff73 @azorg
                                          @azorg
                                          eventually try with the “shipping mode”, instructions here :
                                          https://forum.suunto.com/post/46365
                                            azorg @Mff73
                                            @Mff73 I tested this method too. No result.
                                            I can only reset my watch with rewrite 2.10.26.
                                            2.11.38 and 2.12.30 freeze on upgrade…
