    Offline map downloading is not working properly on Suunto 7
    suunto7maps
    20 Posts 10 Posters 2.6k Views 10 Watching
    • Luca GiraudoL Offline
      Luca Giraudo
      Once I attach the watch to the charger, my Suunto 7 starts downloading the maps. But once the battery reaches 100% and the watch is still attached to the charger, then offline map downloading interrupts. I would expect the watch to keep downloading until on charger.
      This was used to work properly before, or I did not notice the problem before
      Brad_OlwinB ? 2 Replies Last reply Reply Quote 3
        Brad_Olwin Moderator @Luca Giraudo
        @luca-giraudo try a soft reset/reboot
        • R Offline
          Robert_mp
          Hi, same problem here since two weeks ago.
          And it’s impossible to take off the card “downloading…”
          • R Offline
            Robert_mp @Brad_Olwin
            @brad_olwin I tried the soft-reset without success. 😞
              Brad_Olwin Moderator @Robert_mp
              @robert_mp Restart the phone as well. I have iOS so don’t know if I can help. It could be poor WiFi, are you using cellular? Open the Suunto Wear app, can you get a location and can you see the heatmaps?
              Finally, you can change the additional offline download location and see if this helps.
              • R Offline
                @brad_olwin i charge it in the same place as always…3 meter aprox to the router (600mb connection). Heatmaps are not working .I tried to dowload with a variation of the personal maps and i’ve had the same error as local maps. Route maps work well. I’ve tried erasing cache of some apps related, restart phone and watch but nothing works.
                  A Former User @Luca Giraudo
                  @luca-giraudo said in Offline map downloading is not working properly on Suunto 7:
                  same for me for few days now
                  Tom WehrleT 1 Reply Last reply Reply Quote 0
                  • Tom WehrleT Offline
                    Tom Wehrle @Guest
                    @metalmi I’m facing the same issue since a few days! I don’t know what happend but it had been worked very well in the past!
                    Does Suunto has any current issues with that?
                      I am reporting this to the team
                      • Nigel Taylor 0N Offline
                        Nigel Taylor 0 Bronze Member @Dimitrios Kanellopoulos
                        @dimitrios-kanellopoulos said in Offline map downloading is not working properly on Suunto 7:
                        For info - I had and worked around this problem already, not knowing it was a wider issue, this might be useful info >>
                        Noticed last few days Offline Maps were getting stuck at 85% and then ending up with a stuck notification only removed by Watch Reboot.
                        I repeated a few times, seemed to get stuck at same place every time. THEN…
                        I disabled Auto Wifi (so just Bluetooth)…another reboot, put watch on charger, offline maps now updated successfully.
                        Having done this - if I now re-enable WiFi, and put Watch on charger…it says, “Offline Maps are Up to Date” (or whatever the message is that is similar to that).
                        I R 2 Replies Last reply Reply Quote 1
                        • I Offline
                          ianharding @Nigel Taylor 0
                          @nigel-taylor-0 Thank you! This was happening on my 9-day old S7. Your workaround fixed it. All maps downloaded.
                          • R Offline
                            Robert_mp @Nigel Taylor 0
                            thanks @nigel-taylor-0 ! In my case, it has also succeed.
                            In any case, It is very strange, because the manual instructions says clearly that the watch has to be connected to the wifi in order to download the maps.
                            • R Offline
                              Robert_mp
                              If you do the opposite solution it also works… To disable bluetooth and download vía WiFi (faster).
                              • H Offline
                                Harboe Bronze Member
                                I have this problem as well. I mean the download interrupted notification.
                                  Nigel Taylor 0 Bronze Member @Robert_mp
                                  @robert_mp said in Offline map downloading is not working properly on Suunto 7:
                                  Haha yes it does.
                                  To be honest, I don’t really see the point of ever enabling WiFi.
                                  Everything works without it, and the only time I’m in range of WiFi, I’m going to have my phone with me anyway!
                                  A month back I did have a problem in that GPS almanac data didn’t seem to get refreshed if I only had Bluetooth connection…(which resulted in progressively longer time to get a GPS fix), but I think that issue has gone now.
                                    Should be fixed
                                    Nigel Taylor 0N ? Tom WehrleT 3 Replies Last reply Reply Quote 4
                                      @dimitrios-kanellopoulos I think so…
                                      I re-enabled WiFi today (+ Bluetooth) and maps updated OK.
                                        Should be fixed
                                        yesterday afternoon/evening maps updated without any issues (didn’t try any workarounds earlier)
                                        • BulkanB Offline
                                          Bulkan Moderator
                                          Looks like solved. 💪💪💪
                                            Tom Wehrle @Dimitrios Kanellopoulos
                                            @dimitrios-kanellopoulos Great job! Thank you 🙂 👏
