    Suunto 7 Successor
    123 Posts 24 Posters 18.8k Views 24 Watching
    • suzzloS Offline
      suzzlo Moderator @ChrisA
      @chrisa 😆 😆 😆 😆 😆
      Garmin: FR745, Edge 530
      SA topics:
      • suzzloS Offline
        @chrisa probably I can design some T-Shirts this message: “Keep calm, because watches don’t run”
        SA topics:
          isazi Moderator @suzzlo
          @suzzlo and I’m already listening to “Watches don’t run” a cover of “Boys don’t cry”
          • suzzloS Offline
            suzzlo Moderator @isazi
            @isazi yes, it is very catchy message
            SA topics:
              Brad_Olwin Moderator @lexterm77
              @lexterm77 Funny, this is stuff I know very well
              lexterm77L 1 Reply Last reply Reply Quote 1
              • lexterm77L Offline
                lexterm77 Bronze Member @Brad_Olwin
                @brad_olwin
                It’s similar to other training plans. Majority under AoT, very little between AoT and LT, some Z4 and Z5 intervals. If you put percentage under zones you basically get same numbers 80/20. Part about throwing away watch I liked because watch can’t tell you anything if you never went to a lab. Also I liked how author said the truth about wisely choosing your parents and grandparents and that doing large volume of aerobic stuff at very young age and while growing up has epigenetic effect on how quickly can you adapt to training loads and what can you do.
                What else, nose breathing or talk test is useless if you are not aerobically trained.
                When Killian Jornet noted if you train only 600h a year you can be good at short distances was funny.
                  A Former User @olymay
                  @olymay said in Suunto 7 Successor:
                  The default map area it downloads is a 54km square centred on your location, so pretty wide
                  I was reading the thread and my right eye focused on that number: 54km.
                  I am unable to select an area greater than 42km. Why?
                  • olymayO Offline
                    olymay Gold Members @Guest
                    @g-q said in Suunto 7 Successor:
                    That’s odd, mine defaults at 54km.
                    Where are you looking to get this?
                    I go into the following:
                    Open Suunto App with top right button
                    Scroll down to ‘Map Options’
                    Scroll down to ‘Offline Map’ (under this in grey text it says ‘Tap to define’)
                    This next screen shows my local map with a 54km square. Using the top and bottom buttons on the right hand side of the watch I can zoom in to a minimum of 3km to a maximum of 10,872km (HUGE!). The middle button confirms the selction.
                    You can also use the touchscreen to pan the map around as well as pinch to zoom in and out.
                    Hopefully this works for you.
                    Suunto 7 Graphite Copper
                      directly on the watch, probably that’s the reason
                      • olymayO Offline
                        Yes, this is all done on the watch 🙂
                          @olymay believe or not, it does not work.
                          • olymayO Offline
                            Very odd. In that case, I would suggest contacting Suunto Support.
                            One last thought
                            Is your watch storage full? maybe it is limited on how much storage is left?
                            I have no music or third party apps installed, so have loads of free space.
                              yep
                              One last thought
                              me too, no other apps or anything else installed
                              • olymayO Offline
                                @g-q Are you able to share a screenshot? or a photo of the watch?
                                  Just out of curiosity if you pinch to zoom out to say 20km and then you use the ± buttons are you able to restore your old default i.e. 54km?
                                    @olymay not now, I’ll do this evening. thanks!
                                      Brad_Olwin Moderator @olymay
                                      @olymay @lexterm77 @Jamie-BG @cosme-costa @ChrisA @isazi @suzzlo Let’s continue this conversation on topic.
                                      https://forum.suunto.com/topic/7333/hrv-training-meta-analysis
                                        DavorP @olymay
                                        @olymay
                                        5kruuner predictions
                                        https://the5krunner.com/2021/11/28/2022-sports-watch-update/?amp=1
                                        • BulkanB Offline
                                          Bulkan Moderator @DavorP
                                          @davorp said in Suunto 7 Successor:
                                          @olymay
                                          hahahahahahaha
                                          • olymayO Offline
                                            olymay Gold Members
                                            Would it be too much to hope for a Suunto 7 successor to come this year and be powered by one of these?
                                            Please Suunto
 This could easily be the WearOS champ!!
                                            (although it would need to be priced more competitively than the S7 was at launch!)
