    Suunto 9 peak, battery drain - v.2.18.18
    16 Posts 8 Posters 4.5k Views 8 Watching
    • Pascal TempelsP Offline
      Pascal Tempels
      Hi all, not sure why but since my update some weeks ago to v2.18.18, I’m experiencing a very agressive battery drain on my S9P. I already disabled media, and tried to empty/recharge the battery completely, set GPS to BEIDOU… but all without success.
      Currently, I’m not training a lot so it is not that I’m using the watch very intensively. The only difference is the update to v2.18.18.
      Anyone else experiencing this problem and anyone has an idea how when the next update is scheduled for the S9P?
      thanks
        Dimitrios Kanellopoulos Community Manager @Pascal Tempels
        @pascal-tempels what is the battery drain? percentage per day ?
        Creator of quantified-self.io
        Pascal TempelsP 1 Reply Last reply Reply Quote 0
          Pascal Tempels @Dimitrios Kanellopoulos
          @dimitrios-kanellopoulos almost from fully charged to end at the day at 30%. I will start recording some numbers to get an overview
            @pascal-tempels did you reboot the device ? 30% for sure its a problem
              @dimitrios-kanellopoulos yes i did
                @pascal-tempels if that is the case I can help you revert to prev fw if needed.
                Also logs via the Suunto app + PM your email so I can get those can help
                  @dimitrios-kanellopoulos I uploaded the logs to Suunto just now and I will PM you my email. at this stage, there is no immediate need to downgrade. I would prefer to find the solution so if suunto eng. needs me to test something, feel free to let me know.
                    @pascal-tempels I can see the issue
                    Pascal TempelsP plopes73P 2 Replies Last reply Reply Quote 1
                      @dimitrios-kanellopoulos after the factory reset, power consumption is back to normal. thx for the help
                      • plopes73P Offline
                        plopes73 @Dimitrios Kanellopoulos
                        Will a factory reset also solve my issue? I don’t have that much battery drain, but I’m getting a lot of battery drain after upgrading to 2.18.18 in my S9P.
                        As I commented in:
                        (https://forum.suunto.com/topic/7061/software-update-2-18-18-sept-28-2021/286 )
                        S9 Peak 2.18.18
                        Vertical
                        Android 10
                        Suunto App 4.45.5
                          Dimitrios Kanellopoulos Community Manager @plopes73
                          @pedromslopess I don’t know
                          • thanasisT Offline
                            thanasis Bronze Member
                            i do seem to get some weird battery drain as well. Overnight (5 hours 19 minutes) it lost 8% while being in “Do not disturb” mode but sleep monitoring was enabled. still i consider it to be quite high
                            • isaziI Online
                              isazi Moderator @thanasis
                              @thanasis will be fixed with next update.
                              Jordi CompteJ 1 Reply Last reply Reply Quote 4
                              • Jordi CompteJ Offline
                                Jordi Compte @isazi
                                @isazi i have the same problem, battery drain after the firmware upgrade.
                                • XFatManX Offline
                                  XFatMan
                                  I have had some weird battery drain as well since the last update, on a Suunto 5. Will there be a fix for this as well? @Dimitrios-Kanellopoulos
                                  • surfboomerangS Online
                                    surfboomerang
                                    Just wanna give a big thumbs up for Suunto. 👍
                                    The latest firmware fixed the battery drain very good! Depleted the watch completely after the 2.19.42 firmware update and charged it to 100%
                                    After 48 hrs the watch is still at 92% (no exercise)
