    Suunto 9 Peak Pro?
    1.5k Posts 145 Posters 392.4k Views 126 Watching
      altcmd Silver Members @el2thek
      @el2thek Interesting indeed. Not sure what is the issue here. Hopefully it is not the case with S9PP.
      mikekoski490M 1 Reply Last reply Reply Quote 0
      • mikekoski490M Offline
        mikekoski490 Bronze Member @altcmd
        @altcmd Hi. New S9PP here. I have it set for 10:30pm sleep and 7am wake. Last night shows fell asleep 10:46, and woke up 7:20, which is very accurate.!Screenshot_20221103-124724.png
        Current: Suunto Race Ti
        • herlasH Online
          herlas Silver Members @mikekoski490
          @mikekoski490 do you also have HR gaps during the night? think it was said before it’s a known issue being iron out at firmware side. 🤔
          In my case, HR reading gaps during the night are huge.
          SRS Ti
          Galaxy Z Flip 3 / Galaxy S24+
          Umer JavedU isaziI mikekoski490M 3 Replies Last reply Reply Quote 0
          • Umer JavedU Offline
            Umer Javed @herlas
            @herlas wonder if its the sensor moving away from wrist because of sleep position etc or loose band
              isazi Moderator @altcmd
              @altcmd for me, most days Suunto and Oura are in perfect accord about how much I sleep, and my HR at night.
                isazi Moderator @herlas
                @herlas yes they are being investigated, and there is going to be a new S9PP software release in, I guess, late 2022 or early 2023.
                  mikekoski490 Bronze Member @herlas
                  @herlas Hi. I just looked and yes, last night there were 2 gaps in HR readings, but the night before none. I’m sure Suunto will fix it if it’s a known issue?
                  • herlasH Online
                    Here are past 3 nights, not working as expected for me at all, and previous nights are about the same.
                    Watch is not too loose or not too tight, looks like HR sensor goes to sleep with me too 😂
                    SRS Ti
                      @herlas Wow. Those are large gaps. Screenshots from SA below. The first one is 24-hour HR history from yesterday, and the second a snapshot of the gaps last night. For yesterday the early morning gap was watch was off my wrist and on the charger. Not sure what caused the rest of the gaps though.
                      • herlasH Online
                        @mikekoski490 Thx, yeah my gaps are gigantic, the reading while sleeping is the issue for me, rest of the day looks fine, here’s yesterday’s HR, spike is for a run in the evening
                        SRS Ti
                          mikekoski490 Bronze Member @pilleus
                          @pilleus Well, west coast of Canada in November and… there ya go. Storm Alert is definitely working.PXL_20221104_024521794.jpgPXL_20221104_025851126.jpg PXL_20221104_025813671.jpg
                            Will need more nights of testing, but the gaps in HR may already be fixed in beta firmware.
                              Jamie BG Bronze Member @Kurt68
                              @Kurt68
                              Surely if you are testing battery life to battery life you should at least make the comparision fair and should be using All System GNSS rather than the Multi-Band as multi-band almost halves its tracking battery life. I suspect if you were running it using All then the results would be a lot closer in terms of battery life.
                              Kurt68K 1 Reply Last reply Reply Quote 0
                              • Kurt68K Offline
                                Kurt68 @Jamie BG
                                @Jamie-BG That’s why I wrote that the S9PP used 14% less battery when used the same way with all systems. I only did the last unit with multi gps. But even then the difference shouldn’t be that big because Garmin states a running time with multi gps of 36/41 hours. Exactly what Suunto states for all systems.
                                • matthinshM Offline
                                  matthinsh Bronze Member
                                  I ordered one last week, still no update argh! I’m like a kid in a sweet shop waiting for it to come.
                                  Based on the videos and conversation in here, it really does sound like an awesome device. Sorting out the readability in the UI is a massive win, well done Suunto!
                                  • MiniForkliftM Offline
                                    MiniForklift Platinum Member @el2thek
                                    @el2thek said in Suunto 9 Peak Pro?:
                                    @altcmd For me it’s the opposite, my 9B is almost always spot on.
                                    Same, have never had any gaps with my S9B. I’ve started wearing mine to bed again mainly so I can track my HR through the night, that along with sleep/wake time and everything else generally seem to be fairly accurate 👍
                                    Look forward to comparing it to the S9PP when it finally becomes available in NZ in 2032 😆
                                    SV Titanium Solar Forest
                                      freeheeler @MiniForklift
                                      @MiniForklift
                                      same here… no gaps at all.
                                      2032 you’ll go running with your S11 super summit expert with holographic screen 😂
                                      MiniForkliftM D 2 Replies Last reply Reply Quote 1
                                        MiniForklift Platinum Member @freeheeler
                                        @freeheeler said in Suunto 9 Peak Pro?:
                                        @MiniForklift
                                        In 2032 I might be a hologram myself 😅
                                          dulko79 @freeheeler
                                          @freeheeler in 2032 the watch runs instead of you 😀
                                          App: beta
                                          Phone: Iphone
                                          iOS
                                            Oooh so it looks like I might be able to purchase an S9PP through the Suunto UK site, free delivery to NZ too 👍
