    No-Map-Problem
    299 Posts 65 Posters 75.7k Views 62 Watching
      zhang965 @Guest
      @Ilya-Sul said in No-Map-Problem:
      @Highlands
      I’m so glad I still have my Epix 2 for my holiday.
      Suunto Support has been absolutely unhelpful so far. At this point, I’d recommend against buying the Suunto Vertical / Suunto products.
      But did you find epix 2’s map is slow?
        A Former User @zhang965
        @zhang965
        I bought some Talky Toaster maps for my Epix 2 (which I can wholeheartedly recommend). It’s slower, yes, but considering what an actually routable map brings to the table, it’s no contest really.
          A Former User @Guest
          @Ilya-Sul Still nothing from Suunto Support, even after another e-mail. After this whole debacle, I’ll say goodbye to Suunto, I think. 😔
          • pavel.samokhaP Offline
            pavel.samokha @Guest
            @Ilya-Sul hard to read the whole 200+ messages here, could you describe your problem again?
              That’s all that shows up. Needless to say, that’s not what my hometown looks like.
              My federal state’s map’s been broken since I reset my watch. I tried everything. I can’t fix it, no matter what I reset, re-download or restart. I did everything more than once. There’s no fix on my end.
                @Ilya-Sul could you share state name and location? Here or DM me
                  A Former User @pavel.samokha
                  @pavel-samokha
                  Pavel’s helped me to resolve the issue. ❤️
                  pavel.samokhaP EgikaE 2 Replies Last reply Reply Quote 6
                    @Ilya-Sul Great. Unfortunately it’s not complete solution, there still could be border issues, I’ll share here when we fix the issue fully.
                      Egika Platinum Member @Guest
                      @Ilya-Sul
                      @pavel-samokha
                      that is great.
                      I have asked you like 3 weeks ago about in which state this is happening. Could have solved this earlier 😉
                      But great you got it working.
                      Same issue I kept having at the boarder from Hamburg to adjacent stated of Niedersachsen and Schleswig-Holstein
                        A Former User @Egika
                        @Egika
                        Yes, but as I said: On a public forum, I don’t want to disclose my location any more than I have to. 😁
                        The thing is that it would’ve been Suunto Support’s job to solve this with me, but they didn’t, like at all. So while I’m very grateful to the Suunto dev(s) on the forum, I’m bummed that going through the official channels turned out to be a such waste of time.
                          @Ilya-Sul
                          you are right, support should be able to solve it for you.
                          still this is what the forum is there for: helping users out.
                          no need to disclose your location in public, private message does it as well.
                          • HonzaH Offline
                            Honza Bronze Member
                            Hey everyone. It’s hard to go through everything, and each issue is a bit different. Would anyone be able to let me know the recommended steps if I keep having the no-map issues? It seems to happen randomly where some map squares don’t show at 200m and closer. The map shows at 500m resolution but with less detail than normal for this resolution. I tried the soft reboot multiple times, and it seems to resolve the issue, but it always comes back after a while.
                            Is this a known issue, and should I just wait for the next fw update? Or should I redownload my maps? Anything else I can do?
                            The issue does not seem to be related to a specific map or location. I’m in Czechia most of the time, but I had the issue even when traveling to Austria.
                            • surfboomerangS Online
                              surfboomerang @Honza
                              @Honza As far as I know a reboot works as a workaround. A solution should be provided with a firmware update.
                              • inkognitoI Offline
                                inkognito Platinum Member
                                So I have this issue with the new firmware.
                                When this happened, whole interface started lagging. But my exercise continued.
                                In the end, after “feeling” screen, I got stuck on “Saving…”
                                But I was not really stuck… When I swiped “back”, it took me back to feeling… I went back and forth several times and then tried to press the middle button several times. Then my watch rebooted…
                                I have sent logs and will be happy to provide details!
                                Interestingly, after the firmware update, I noticed that there’s something weird in that location when I tried the 2km zoom and paned map to that location. I saw tiles and my watch became very slow. When I returned to watch screen, it showed this:
                                (info on the top is clearly missing)
                                When I checked the Suunto app, watch appeared to be busy… I restarted my watch and things went back to normal, until I checked that place on map again and the whole thing repeated. So, no, reboot does not work for me…
                                I will try to redownload the map and check again…
                                EDIT: I deleted the map and downloaded again. When I use 2km zoom, I have no-map problem in multiple locations. When this happens, after I exit the map, watch becomes slow and restarts occasionally… Before it restarts, when I check SA, I can see “Watch is busy” state (I hope that it at least tries to send some error report to Suunto).
                                Since there is still no backup for custom sport modes or settings, I do not really want to try the hard reset immediately… Could someone try to pan on the map with 2km zoom and report that it works alright on other device (even when you pan very far etc)?
                                SV: fingers crossed :D
                                pavel.samokhaP pilleusP Majkel PaszekoM 3 Replies Last reply Reply Quote 3
                                  pavel.samokha @inkognito
                                  @inkognito could you send me your location in PM?
                                  • pilleusP Online
                                    pilleus @inkognito
                                    @inkognito
                                    In 2 km zoom I can pan to the border of the downloaded map. There the map changes to black squares (shown in your first picture). I don’t know if this will help …
                                    Suunto Vertical Black Lime
                                    Suunto 9 Peak Pro Black
                                    inkognitoI 1 Reply Last reply Reply Quote 1
                                      inkognito Platinum Member @pilleus
                                      @pilleus Great, I will probably have to try the hard reset soon 😞
                                      EDIT: I tried the hard reset and it did not help…
                                        Juhani @inkognito
                                        @inkognito I’m having similar issues with the new version. I can’t see maps at all on 500m, 1km, 2km. (just the grid) And if I even try 1km and 2km then the bigger zooms (25m-200m) break too and show only part of the map just like in the photo you sent. Afterwards suunto app is not able to connect and soft reset is needed. I have also done factory reset, deleted and re-uploaded maps and nothing helps.
                                        • V Offline
                                          vpet_09
                                          With the latest firmware I am also seeing mostly just black squares in Vertical, with the old firmware everything worked ok and now almost none of the map tiles are rendered. I did try to reset and redownload maps but nothing seems to help.
                                          • Majkel PaszekoM Offline
                                            Majkel Paszeko @inkognito
                                            @inkognito "black grid of death” is still with us. I’m just back from 2h trail run and issue started when i zoomed out map too much. Some map areas (even those visible at start) disapeared. So I ran my way back trough the black fields of death 🙃. And as community said: when it happens it can affect other things as well. In my case it was HR sensor reads which frozen at 180 bmp value till the end of workout. Also afer the workout, many widgets were showing nothing or nonsense untill i soft reset. So it is definitely cache mamory issue driven by some maps operations.
