    No-Map-Problem
    299 Posts 65 Posters 50.8k Views 62 Watching
    • mikekoski490M Offline
      mikekoski490 Bronze Member @zhang965
      @zhang965 Excellent! Glad you will be heading over to the Garmin Forum now! Garmin users complain about their devices and Garmins lack of support there so your great wit will be a welcome ray of sunshine I’m sure. 🎉
      Current: Suunto Race Ti
      1 Reply Last reply Reply Quote 15
        isazi Moderator @Likarnik
        @Likarnik I have not seen the black grid on the testing firmware for a long time. Unfortunately, I have also never seen it on my production Vertical, so it may just be that the places where I travel have no issues. Anyway, from the bug-tracking system that is accessible to external testers, I see that developers fixed bugs that were causing the “black grid of death”. So, hopefully this is also a thing of the past.
        L ? 2 Replies Last reply Reply Quote 4
          Likarnik Bronze Member @isazi
          @isazi Hope so. Also hope we don’t have to wait until end of the year to push this to production.
          BTW, I created a route in Komoot, is this their fault or suuntos?
          This is from SA (pushed from Komoot). perfect overlay (as I said, out and back route):
            @Likarnik said in No-Map-Problem:
            I hope the same, but have no clue about the release.
            Strange, could be the watch rendering, or the fact that the route is simplified (points pruning) during transfer to watch.
              A Former User @isazi
              @isazi I don’t see the black grid of death but a white background with a few brown lines and nothing else.
                isazi Moderator @Guest
                @Ilya-Sul never seen that, can you share a picture?
                  @isazi Yes, need to get home first, though.
                  The brown lines were also present when the map was displayed correctly (before the reset). I don’t know if they’re supposed to be contour lines or something…
                  I already restarted the watch, re-downloaded the maps and reset the SV several times. Nothing seems to help.
                    laurent92m @Brad_Olwin
                    @Brad_Olwin
                    Hello Brad,
                    So, this week-end,I moved for the first time with the watch to the Nantes region and the map (Pays de la Loire) was not working. ( black grid on the watch).
                    I applied the 2 steps ( soft reset + calibrate compass) and then the map was available on the watch.
                    Moving back to Paris, Paris map was hopefully still working fine with the watch…
                    The coming weekend, I will use the watch for the first time in the Alps, going through 3 differents Suunto maps and I expect to see only the first map to work after having done the usual soft reset + calibrate compass before starting…
                    Will let you know the result in a week time
                    Have a nice week
                    Laurent
                      Brad_Olwin Moderator @laurent92m
                      @laurent92m I have now had the black grid problem with field test firmware as well. I reported this and am going to test my production watch as well. Keep me posted on this as I will aggressively pursue it. I am also not happy when this happens but it is darn near impossible to reproduce.
                      jjpazJ L 2 Replies Last reply Reply Quote 4
                        That’s all that shows up. Needless to say, that’s not what my hometown looks like.
                        ? Henrik JacobssonH 3 Replies Last reply Reply Quote 0
                          A Former User @Guest
                          @Ilya-Sul
                          I scrolled around until I ended up in a different federal state (took some time) and guess what, the map for the adjoining downloaded region shows up. It seems like the map for my federal state in Germany is broken. Great.
                            Egika Platinum Member @Guest
                            @Ilya-Sul which state is it?
                              A Former User @Egika
                              @Egika Don’t wanna disclose that on a public forum. 😬 I’ll contact support about it when I got the time.
                              It definitely worked when I bought the watch and downloaded the map for the first time.
                              • jjpazJ Offline
                                jjpaz Bronze Member @Brad_Olwin
                                @Brad_Olwin I have suffered the “black grid” problem only one time. I don’t know if it has relationship with the problem but before I started the activity with the “no map” issue, the HR widget graph was not working. It seems that the watch stopped “painting” the HR graph several hours before.
                                So perhaps the watch runs out of memory or something like that and is not able to “paint” some graphs and the map.
                                After reset the watch frees memory and the issue is “solved”.
                                Perhaps you can verify if the behavior is similar in case of new “black grid” problems.
                                  surfboomerang @jjpaz
                                  @jjpaz Same experience for me. When I just got the watch I installed some maps. Occasionally I had some semi black grid issues. Only some tiles were missing.
                                  After a soft-reset, I never encountered the issue again.
                                    @Ilya-Sul I contacted support. Support is gonna forward my issue to engineering. Let’s see. I hope the problem’s with the map itself. Otherwise, I don’t have much hope that the issue will be fixed before my upcoming vacation.
                                      laurent92m @Guest
                                      @Ilya-Sul
                                      One thought: as soon as you add a map and before using it for the first time (meaning you are inside this area physically with the watch) you might have to go through steps 1 & 2 below:
                                      1 - Soft reset of the watch (Press 12 sec top right button)
                                      2 - Calibrate compass
                                      At least, it is the case for me…
                                      BR
                                      Laurent
                                        A Former User @laurent92m
                                        @laurent92m
                                        Appreciate the help.
                                        Doesn’t help, though. I already tried all the regular trouble shooting options. I’ve calibrated and reset this watch enough times already.
                                        Support wanted me to factory reset the watch again (after having done so 3 times already) and I respectfully declined. I’m not willing to invest so much of my free time here.
                                          Mff73 @Guest
                                          @Ilya-Sul
                                          In your case, it looks more like a “bad map” issue, rather than “no map” issue.
                                          You seems to see something (but not what you expect ), while no map issue is really black screen with white grid.
                                          just guessing from what is shown.
                                            A Former User @Mff73
                                            @Mff73
                                            Yes, it’s some part of the map for sure. But it might as well be no map. It did work when I set up the watch for the first time. All I can do now is wait.
