    solar charging
    129 Posts 35 Posters 28.9k Views 35 Watching
      mikeorbreak @freeheeler
      @freeheeler said in solar charging:
      @DMytro
      @Egika once explained it well to me in a pm… I stopped worrying that moment 😉 👍
      Do you want to tell us? With permission of @Egika of course…
        freeheeler @mikeorbreak
        @mikeorbreak
        as said before, long story short (what I recall): don’t worry, it takes long for watches to reach charging cycles 🙂
          surfboomerang
          The solar widget confuses me a little bit.
          I had an office day on Friday with probably 1 hour of sun that day. On Saturday I had a 3 hour windsurf session with probably 5 hours of sun, but the graph doesn’t seem to show that.
          W D 2 Replies Last reply Reply Quote 0
          • W Offline
            wotus Bronze Member @surfboomerang
            @surfboomerang Could it be that the graph shows the relative energy balance, on Saturday the collected and consumed energy during windsurfing were almost equal, but on Friday more energy was collected than consumed?
            • V Offline
              vlado
              I left it this morning on clear sun for some 3 hours, battery was at 14% at the begining and after those 3 hours it was still on 14%, it did not raise…but that was 8 hours ago and it is still on 14. My question is…when it is being solar charged does the percentage raise or it just stays on that initial percentage for a lot longer than when it did not had solar charge?
              Suunto Ocean
              Suunto Vertical Solar Canyon
              Suunto Ambit 3 peak Sapphire
              surfboomerangS valdis830V 2 Replies Last reply Reply Quote 1
              • SuperFlo75S Online
                The last two days I could test the solar charging… after a long period of raining we had a slighty cloudy sky with periods of sun 🤩 I noticed the the force of the solar charging is very very depending of the direction or the angle of the incoming sun… but I don‘t want to change the watch from the left to the right wrist when I change the direction of my activity… 🤣
                Suunto Spartan Ultra
                SA iOS 3.5.1 (20789)
                Instagram @superflo75
                  sartoric Moderator @SuperFlo75
                  @SuperFlo75 said in solar charging:
                  Well, that’s actually how solar panel works, unfortunately
                  SVTS - 2.48.16
                  Suunto App Android 6.4.7 beta
                    deserthike20 Bronze Member @surfboomerang
                    @surfboomerang I’m seeing similar behavior on the weekly solar chart as well. It doesn’t seem to be displaying the info correctly.
                    Suunto 9 Peak Pro
                      surfboomerang @wotus
                      @wotus would definitely be a nice idea, but then I would suspect negative values since I ended up with a lower battery percentage at the end of the day.
                        surfboomerang @vlado
                        @vlado it does raise, but you need a lot of sun and patience.
                        • C Offline
                          craigeggleton Bronze Member @Dimitrios Kanellopoulos
                          @Dimitrios-Kanellopoulos left mine in direct sunlight for 30 minutes (off wrist), screen went black, and zero charging.
                          surfboomerangS MiniForkliftM 2 Replies Last reply Reply Quote 0
                            surfboomerang @craigeggleton
                            @craigeggleton it took me around 50 minutes for 1%. So normally 4-5 full solar bars
                            • MiniForkliftM Offline
                              MiniForklift Platinum Member @craigeggleton
                              @craigeggleton said in solar charging:
                              The screen will go blank if the watch isn’t being moved, but it will still be charging. IIRC the solar functioning is actually better once the watchface has gone off
                              SV Titanium Solar Forest
                                Tieutieu Platinum Member @surfboomerang
                                @surfboomerang today tried during a car travel.
                                With this amount, I didn’t won any single % of battery. Still have to experiment…maybe amount of sun behind glasses was not as strong as direct sun. 😧 IMG_5163.jpeg
                                surfboomerangS M 2 Replies Last reply Reply Quote 0
                                  surfboomerang @Tieutieu
                                  @Tieutieu No, the amount of sunlight in the car is way less than outside. When I wrote 4-5 bars, I meant totally full bars. I was outside and the watch was facing the sun.
                                  Also, if I understood correctly, the bars are only showing 50000 lux and the watch is capable of collecting more than that. So it could be that in my test the watch was receiving way more light than a full bar.
                                    @surfboomerang thanks for explanations ! It Confirms I need more time (more sun !!) to have decent results. I have a long race to come next weekend, it will be a good test !
                                    My only concern is that I my skin turns usually very quickly to full red when there is a bright sun !! 😆
                                      freeheeler @Tieutieu
                                      @Tieutieu
                                      …the solar charging bar can be dual use… when one bar is full it’s time to think about putting on sunscreen 😉
                                      isaziI 1 Reply Last reply Reply Quote 4
                                      • aroo7A Offline
                                        aroo7 Bronze Member
                                        Is it known what exactly the stripes on the viewer represent? Suunto only reports light output in lux (or I didn’t read something) but that’s not information on how much of that energy we gained.
                                        A cool addition, by the way would be a statistic info in the solar widget showing how much energy we gained from the solar panel during the day and the whole week
                                        L 1 Reply Last reply Reply Quote 3
                                        • L Online
                                          Likarnik Gold Members @aroo7
                                          @aroo7 And graph in SA like steps/calories
                                            isazi Moderator @freeheeler
                                            @freeheeler I know that if the battery of my Vertical solar starts going up I need to apply suncreen more than once. Happened to me twice.
