    solar charging
    129 Posts 35 Posters 28.9k Views 35 Watching
    • Tami999T Offline
      Tami999 Silver Members @Tieutieu
      @Tieutieu said in solar charging:
      @sartoric I just did a soft reset. It’s full sun out there. Still “sleep mode displayed”, not indication of solar charging.
      I’ll wait for next update.
      Maybe try give it a soft slap. For me worked and since than it works like before. I covered screen and punched it softly on my leg with soft little power 😂
      @Brad_Olwin said in solar charging:
      @riccardo88ve May be true, here is last week for mine, no issues. I would contact support.
      Brad, what’s that black version of Athletic 5? Never seen. Its Suunto Staff only or something?
        Tieutieu Platinum Member
        Well, no display of solar charging…but no reason that my watch would be damaged, I more likely think of a bug. I’ll wait for the next update.
          Hi, yesterday’s update didn’t changed my issue.
          I also did a soft reset => no change
          stop/start => no change
          Unpin solar widget/soft rest/pinn widget => no change
          My solar charging still remains in “sleep mode”, no indications of charge, bright sun.
          It seems that you won’t be able to avoid support😭
          But don’t know when…I have plenty of races and training in the next months…and I’m not motivated to come back to my S9b ; but I guess I may not have choice.
          If anyone has a tip that could help me, it would be awesome.
          I really don’t now when or why it stopped working, it had no special event that could have damaged it
          • EzioAuditoreE Offline
            EzioAuditore Gold Members @Tieutieu
            @Tieutieu Did you try factory restore? I had gps shifts quite bad not being solved by soft. So as a last resort I did factory. Now the track is spot on.
              Tieutieu Platinum Member @EzioAuditore
              @EzioAuditore not very motivated to do so right now…I’ll try after my big race scheduled by the end of august. Don’t want to loose hrv/vo2/shape and all custom modes for now.
              Is a hard reset really so different than an update, except factory settings reset ?
                @Tieutieu I completely understand. But as I said I tried everything and the shift was not going away. After contacting support we decided do a factory before sending the watch. After the hard reset the gps track is spot on. So if is definitely different to the soft
                  @EzioAuditore yep. It will be the « last chance try » before sending it…
                  Mff73M 1 Reply Last reply Reply Quote 3
                    Brad_Olwin Moderator @Tami999
                    @Tami999 said in solar charging:
                    That was a gift from a Suunto employee, it is an Ambassador strap and can’t be purchased. I was lucky!
                      Mff73 @Tieutieu
                      I saw one advice about gently tap your watch on something. Did you try? Maybe solar panel has some little disconnection which could be temporarily fixed like this, or at least tend to prove that it is HW issue?
                        Tieutieu Platinum Member @Mff73
                        @Mff73 I haven’t really tried yet that but I’m really skeptical about that…
                        I’m wondering how and when it stopped working.
                        Battery life of the SV is so huge and we had so few sun past months that I never had questionned the solar charging !
                          Mff73 @Tieutieu
                          I would be skeptical as well, but it doesn’t cost any buck to try 😋.
                          I don’t have solar here (nor so much sun 😬) so I am not used to such behaviours to help more. Just reading some not so silly tricks here and there 😎.
                            I finally decided to try a hard reset…unfortunatly solar charging isn’t working after…
                            No other choice than sending my watch for support…
                            And I was almost ready to order a Race S this morning has 2nd watch…but it’s already out of stock…
                            So I will have to wait till end of summer to send my SV for repairing…😢
                              @Tieutieu Pity 😞 But all the best and enjoy the summer.
                                @EzioAuditore Battery life of the SV is still so huge that I should not feel limited. But I’m sad that solar charging seems to be broken for good…also because I didn’t did anything special to my watch (except lot of training !)
                                • R Offline
                                  riccardo88ve
                                  Hi, I sent the vertical solar for service because the solar charging panel was gone! One week and it was returned fully functional (not all the circles were filled). Now problems again, anyone noticed any bugs in the watch face regarding solar charging indicator? It looks like the solar charging indicator is malfunctioning! Does it happen to you too? I would like to have feedback to rule out a malfunction of the solar panel (it was replaced a month ago).
                                    EzioAuditore Gold Members @riccardo88ve
                                    @riccardo88ve Maybe too much sun/heat ‘unglues’ the connector? I cannot comment on this I am not in very sunny country now. Will go to Greece in couple of days and will see.
                                      Well, my SV goes next monday for repair in the CZ repair center. I hope they will solve issue (anyone experimented this CZ repair center VS finland?)
                                      (I finally ordered a SRs that will arrive tomorrow, so I won’t be naked !)
                                      • SvenSchroeterS Offline
                                        SvenSchroeter
                                        I am experiencing the same issue. Have noticed the solar energy real time widget does not respond, and the collected charge over time bar graph is close to empty.
                                        Tried soft reset, factory reset and full charge cycle.
                                        Nothing has fixed it. Happened from one day to another just over a week or two ago. Have contacted support and they want to see the watch. But I am stuck woth a schedule full of races and events and don’t want to send it in right now… hopefully it’s a FW issue which can be resolved in the next update… but I have my doubts. Let’s see what happens, it’s not a deal breaker as much as it is a little annoying and dissapointing.
                                        Suunto Vertical Ti Solar (Daily)
                                        Suunto Race (Wife Daily)
                                        Retired: Suunto Ambit3 / Ambit / Core
                                        https://www.strava.com/athletes/142980701
                                          Brad_Olwin Moderator @SvenSchroeter
                                          @SvenSchroeter said in solar charging:
                                          I used mine for a 5d fast pack at the end of July and solar worked well, I am on FT firmware but have never had this issue. I am concerned it is hardware, I would contact support or fill out a warranty ticket online and send the watch in.
                                          SvenSchroeterS 1 Reply Last reply Reply Quote 0
                                            SvenSchroeter @Brad_Olwin
                                            @Brad_Olwin - I am pretty confident it is a HW issue aswell. Am considering the suunto race s to get me bye in the meantime… I am in italy and there is no support here… I have to do the online repair request. I guess it will be a few weeks before I have it back. Considering a week just shipping forward and back and then someone on the other end to recieve it and look at it. A few weeks for sure.
                                            Brad_OlwinB sartoricS 2 Replies Last reply Reply Quote 0
