    solar charging
    129 Posts 35 Posters 28.9k Views 35 Watching
    • HighlandsH Offline
      Highlands
      Posted in wrong thread. Sorry.
      SV2&SV1
      • Tami999T Offline
        Tami999 Silver Members
        About solar… how it is safe to have long time on sun? I was today on trip, gained a lot of sunny from direct lighting, and my watch was pretty hot. How long its safe to expose watch on direct sun? I know its not recommended, but does was there someone that damaged watch by that?
        sartoricS freeheelerF 2 Replies Last reply Reply Quote 0
          sartoric Moderator @Tami999
          @Tami999
          Well, overheating electronics it’s never a good thing.
          That said there are operating temperature that should be taken in consideration.
          SVTS - 2.48.16
          Suunto App Android 6.4.7 beta
            freeheeler @Tami999
            @Tami999
            I know people who take their watches to the sauna…
            R 1 Reply Last reply Reply Quote 1
              A Former User @riccardo88ve
              @riccardo88ve today I got some trail riding in with plenty of sunshine. 3 rings.
              • thanasisT Offline
                thanasis Bronze Member @Guest
                @Todd-Danielczyk what strap is that one ?? Seems interesting
                  A Former User @thanasis
                  @thanasis it’s a knock off version of the Apple Ultra ocean.
                  NotoCity for Garmin Fenix 6 Band 22mm Ocean Watch Band for Fenix 7, Fenix 5, Fenix 6 Pro, Fenix 5 Plus, Forerunner 955/945, Approach S60/S62, Epix (Army Green) https://a.co/d/8eKD1je
                  Super comfy and keeps the Vertical tight enough to get good HR readings.
                  • R Offline
                    riccardo88ve @freeheeler
                    @freeheeler Thank you, then, in my opinion, my vertical has some problems… it is not possible that in full sun only 2 circles are filled. today I contact Suunto support and let’s see what they say. thanks
                      Brad_Olwin Moderator @riccardo88ve
                      @riccardo88ve May be true, here is last week for mine, no issues. I would contact support.
                      • R Offline
                        riccardo88ve @Brad_Olwin
                        @Brad_Olwin At what level of charge was your vertical?
                          @riccardo88ve not sure but probably 60-70%
                          • R Offline
                            Hello everyone, in the end I sent the vertical to a service center… the whole display was replaced … actually the panel had problems… now everything works perfectly.
                            ? 1 Reply Last reply Reply Quote 4
                              @riccardo88ve Thank you very much for the follow up and good to hear your Vertical is now working correctly after the repair!👍
                              • Tami999T Offline
                                Happened to me today and yesterday. In full sun I have 2/3 rings, not 3/3 like i had in even sunny days than today. Direct sun 29’C, 0 clouds. I’ll probably go like riccardo with that I guess :P. Soft reset doesnt help.
                                • Tami999T Offline
                                  I punched softly watch and so far it works again.
                                    Tieutieu Platinum Member
                                    I wonder If miss something…
                                    I don’t really use solar charging widget since new UI, because SV battery is so huge that I don’t really care.
                                    But lately I wanted to see how it collected sun again, during a bike ride…
                                    I was surprise to see that widget was totally empty whereas it was very sunny. I then notice that widget says that « solar charging is in sleep mode ».
                                    Never saw that before or read about it.
                                    Any idea ? For now solar charging is not working anymore.
                                      sartoric Moderator @Tieutieu
                                      @Tieutieu
                                      It’s always in IDLE status when there is no sufficient light.
                                      But in your case it could be stuck, did you try a soft reset ?
                                      SVTS - 2.48.16
                                      TieutieuT 2 Replies Last reply Reply Quote 0
                                        Tieutieu Platinum Member @sartoric
                                        @sartoric OK thanks for your answer I didn’t know that. I try a soft reset.
                                        When you mean stuck, does that means that widget is stucked ? or solar charging and widget are stucked ?
                                          @Tieutieu said in solar charging:
                                          maybe both, who knows 😁
                                          SVTS - 2.48.16
                                            @sartoric I just did a soft reset. It’s full sun out there. Still “sleep mode displayed”, not indication of solar charging.
                                            I’ll wait for next update.
