    solar charging
    129 Posts 35 Posters 24.9k Views 35 Watching
    • valdis830V Offline
      valdis830 @vlado
      @vlado
      I guess the big drawback is the useful surface of the solar panel. Each m2 of a conventional solar panels have a power around 250w which, extrapolating to our Vertical, would be about 0.25w at full sun.
      As a general rule, USB chargers usually have an output voltage of 5V. So, for example, a charger that is capable of supplying 1.5 A (amps) at 5V (volts) will have a power about of 7.5 W (watts).
      Solar charger does not more than a little help to extend the life of the battery;)
      • EgikaE Online
        Egika Platinum Member @valdis830
        @valdis830 as the watch has a super high battery efficiency, luckly not so much energy is needed.
        The solar option in Suunto Vertical will increase the battery time during activity significantly (in the range of +30%)!
        This is leading the competition of comparable watches and really makes a difference.
        Even if on a 2A power supply, the charging circuit of the watch will reduce the charging current to what is healthy for the battery. It will not reach 7.5W
        • aroo7A Offline
          aroo7 Bronze Member
          Is it known what the bars on the widget graph mean? And how to interpret them when they are “full” of light? 🙂
          • SuperFlo75S Offline
            Today, I went on holidays by car… the sun was shining on my left wrist about 4 or 5 hours… solar charging increased the battery from 78% to 80%… i could see a little effectiveness of solar charging!
            Suunto Spartan Ultra
            SA iOS 3.11 (20282)
            Instagram @superflo75
              I noticed all these days that the scale of the solar display is changing… when I go into the sun in the morning, the stripe of of display increases, and if the sun is strong, the stripe is ‚full‘… but after some more 10min periods, the scale changes and the stripes don‘t reach the max anymore… in the evening, when the sun goes down, it goes backwards and the scale is like in the morning. Regarding to this, it is not possible to reach a ‚full‘ max solar stripe at noon… who can explain? How can I increase solar charging when sittung in the full sun at noon?
              Only one minute later…
              SA iOS 3.11 (20282)
              BrunoHB aroo7A 2 Replies Last reply Reply Quote 0
                martin Bronze Member @Tieutieu
                @Tieutieu modern cars often have athermic window treatments in order not to become too much of a hot oven in the summer. I guess what does not warm your car is also what you would need to charge your battery through the solar panel…
                • BrunoHB Online
                  BrunoH Gold Members @SuperFlo75
                  @SuperFlo75 Just noticed the same thing. I had my first full solar bar, but the next minute the scale had changed 🤔 . What’s going on?
                  Compasses: M-311, A-10, SK-7
                    surfboomerang @BrunoH
                    @BrunoH I noticed this behaviour if the watch collects a lot of sun in 10 minutes.
                    For example, if your watch collects enough sun for almost a full bar it will show this. If the next 10 minutes it collects even more because you intentionally point it towards the sun, the old bar is cut in half.
                    I suspect that the graph scale changes when the solar charge was near or over 100% for 10 minutes.
                    This was the previous post
                    @surfboomerang said in solar charging:
                    Is the some kind of scale on the solar history bars?
                    I noticed today that 2 10min bars were almost full. Once a third appeared, with a slightly higher value than the previous ones, the previous two changed to half full.
                    Anton VanderpoelA 1 Reply Last reply Reply Quote 1
                    • Anton VanderpoelA Offline
                      Anton Vanderpoel @surfboomerang
                      @surfboomerang the solar charging is very fast if there is sun i several tmes reset the watch before i noticed no charge percentage after resetting the watch the charging is very fast
                      BrunoHB 1 Reply Last reply Reply Quote 0
                      • Danny polegD Online
                        Danny poleg Silver Members @Dimitrios Kanellopoulos
                        @Dimitrios-Kanellopoulos I’m trying to understand why two suunto verticl at the same point show a different level of solar charging, one very weak and the other a full circle
                        • inkognitoI Offline
                          inkognito Platinum Member @Danny poleg
                          @Danny-poleg Screen protector on one of them?
                          SV: fingers crossed :D
                          Danny polegD 1 Reply Last reply Reply Quote 0
                          • BrunoHB Online
                            BrunoH Gold Members @Anton Vanderpoel
                            @Anton-Vanderpoel said in solar charging:
                            Is there any truth in this? I don’t know if Anton is referring to soft reset or factory reset, but is there a possibility that solar charging might become more effective after wipeout?
                            • aroo7A Offline
                              aroo7 Bronze Member @SuperFlo75
                              @SuperFlo75 I have the same and it looks very strange. Especially when you leave the watch in the sun for an hour and the straps don’t even get halfway up.
                              What are your experiences with charging? I never bumped up the battery more than 1% even when I left the watch in full sunlight for several hours. Not counting when the battery was almost full, then it charged to 100%, but this is probably a known bug so I don’t count that 😉
                              SuperFlo75S Yamazaki HitomiY 2 Replies Last reply Reply Quote 1
                                SuperFlo75 Silver Members Bronze Member @aroo7
                                @aroo7 I reached some times 2% more battery over the day with solar charging, but this was in the time of my holiday with taking a sun bath for all the day… now with working and sports after 5pm solar charging is as expected not good.
                                It depends of the direction of the sun… doing sports in full sun is not so effective as taking a sunbath and taking care of the right direction 😂
                                SA iOS 3.11 (20282)
                                  surfboomerang @SuperFlo75
                                  @SuperFlo75 said in solar charging:
                                  I can tell you that windsurfing comes really close 😉
                                    Danny poleg Silver Members @inkognito
                                    @inkognito no
                                    • Yamazaki HitomiY Offline
                                      Yamazaki Hitomi @aroo7
                                      @aroo7 said in solar charging:
                                      把手表放在阳光下一个小时,表带甚至都升不上一半时。
                                      您在充电方面有哪些经验?即使我将手表放在阳光充足的地方几个小时,我的电池电量也从未超过 1%。不
                                      Put the watch in a glass filled with water and bask in the sun, perfect!👙
                                      • R Offline
                                        riccardo88ve
                                        hello, I have a problem with solar charging, if I expose the screen directly to the sun (with full sun and 26 degrees outside) it reaches only 2/3 rings of solar energy, never full. Sometimes, if I cover the screen for a second and then re-expose it to the sun, it has all the energy rings but a few seconds after that it goes down to two again. Can someone help me? Should I send him for assistance? Thank you
                                        sartoricS Todd DanielczykT 2 Replies Last reply Reply Quote 1
                                          sartoric Moderator @riccardo88ve
                                          @riccardo88ve
                                          Did you try a soft reset ?
                                          I usually get “maximum” charging level, if the sun straight hit the watch (almost perpendicular, not inclined) but be careful to not overheat the watch leaving it on direct sun for too much time.
                                          Suunto App Android 6.3.3 beta
                                          • R Offline
                                            riccardo88ve @sartoric
                                            @sartoric I tried the soft reset and bring it back to the factory settings… nothing maximum two circles. The suunto assistance tells me that it takes from 12 to 24 hours after the soft reset to resume the solar panel ( ??? !!!)
