    Battery drain
    729 Posts 133 Posters 146.7k Views 115 Watching
    • AntoineA Offline
      Antoine Bronze Member @isazi
      @isazi said in Battery drain:
      My personal workaround while we wait for a fix is: if you use navigation just reboot your watch at the end, after syncing the activity with your phone.
      This is my personal view, nothing from Suunto
      I managed to send logs to Suunto and hope a fix for this will be included in the next firmware. I also believe it is not the GPS but the storage that is kept active, GPS would give an even larger battery consumption. No confirmation from Suunto yet. I try to keep the forum informed as much as I can 🙂
      Same to turn-off Suunto Vertical using general parametrers and to turn-on again i guess ?
      Watch: Suunto vertical solar
      • Mff73M Online
        Mff73 @Antoine
        @Antoine
        yes
          diogao13 Bronze Member @diogao13
          @diogao13 said in Battery drain:
          At the control panel we find the battery percentage. It would be great an update to include more info, like a widget or simple click on battery percentage icon to present:
          • current %
          • last time it was recharged
          • % when last recharged was initiated
          • % when last recharged was ended
          • a prediction when next recharge will be required, based on drain for a selectable period (3 days, week, month).
          • draining graph using recharging date x %.
          This would help us to detect draining activities or functions.
          Scubapro G3 includes some features to help users watching battery
          • K Offline
            Kramble @isazi
            @Kramble said in Battery drain:
            To me it seems there are two drain bugs.
            One with big drain maybe the one you are testing.
            And another smaller one in mere watch use without activities.
            You are also correct, and Suunto is aware of that.
            @isazi Maybe a lead for the small drain :
            Two days ago I got the old synchronization bug on my android beta Suunto app (your watch is no longer found and when you try to pair again then the app fails).
            To solve it I know I have to wipe out the data and cache of the app ( did it from android setting menu), then I have to login again and pair my vertical again.
            It works with a little surprise, no more small drain bug : in 48h with one 50 min trail activity the vertical just lost 4% ! (from 85% to 81%).
            I did nothing else since my last drain (no reset and no full battery cycle, no solar charge).
            So maybe the Bluetooth could be responsible of the small drain ?
            Hope it can help.
            Ambit 3 peak saphir
            Spartan Ultra (sold)
            S7 graphite copper
            S9 peak all black
            Wings
            ? K 2 Replies Last reply Reply Quote 0
              A Former User @Kramble
              @Kramble I had something similar this morning.
              Touch screen unresponsive, would not sync to the Suunto app, battery dropped about 26% overnight and wouldn’t pair even after restarting the Vertical.
              Had to clear the cache and reset the app. Now I have 11 exercise days synced for 2024, nothing pervious dating back to 2019🤔🤣
              • AntoineA Offline
                I used navigation yesterday and today battery drop from 46% to 41% in 9 hours. Only time is displayed today.
                I will try your workaround.
                I have juste sent logs to Suunto.
                • AntoineA Offline
                  Antoine Bronze Member @Mff73
                  @Mff73 not sure that autonomy in activity is not impacted. By analyzing the FIT file during an activity of more than 6 hours i found an estimated autonomy of 40h which was more than 60h before update.
                  To be confirmed…
                  • Fenr1rF Offline
                    Fenr1r
                    Department of Possible Drain Candidates:
                    FWIW, 7 hours after a recorded, route-following activity, the Compass widget is still reporting a value. I seem to remember it quitting much earlier post-navigation on the previous firmware.
                    • K Offline
                      Kramble @Kramble
                      Hope it can help.
                      My bad , my bad I am sorry, I was on holiday and I didn’t notice that the donnot disturb mode was on…
                      Small drain battery is still there 😞
                      Ambit 3 peak saphir
                      S7 graphite copper
                      S9 peak all black
                      Wings
                        My personal update, nothing official, is that two possible causes have been identified. I have not tested a fix yet, but Suunto is aware that this needs to be fixed with next release.
                        • AntoineA Offline
                          I have checked your workaround, seems same for me:
                          • indeed after an activity with maps and navigation the battery usage is ~9% for 16h
                          • reboot (turn off in parameter and long press on upper button)
                          • battery usage is ~2% for 16h
                          • activity without navigation
                          • battery usage is still ~2% for 16h
                          I hope it will be solved very soon as one main advantage of Suunto Vertical watch is autonomy…
                          • jjpazJ Online
                            jjpaz Bronze Member
                            After 17 days without battery drain problem (full charged august 14th, 13% battery level 31th august and full charged again) this past night SV battery level has lowered by 10%-12% without use.
                            Yesterday evening I exchanged watches and I have slept with SR S again… (I was wearing SV full time since august 14th). My last activity with SV was on sunday morning and I didn’t use navigation (hiking with ‘Weather’ S+ App), so it seems battery drain has several faces…
                              A fix is being tested, if everything works out should be here in a week or two.
                              martintrailM gerasimosG Mff73M AntoineA 5 Replies Last reply Reply Quote 9
                              • martintrailM Offline
                                martintrail Silver Members @isazi
                                @isazi omg, the wait is endless 😄
                                • gerasimosG Offline
                                  gerasimos Bronze Member @isazi
                                  @isazi so, it was massive the problem and not for some cases after last update!
                                  by the way great news!!
                                  Suunto Vertical Ti
                                  Suunto S9 gen1
                                  Suunto Ambit3 peak
                                    isazi Moderator @gerasimos
                                    @gerasimos not massive, but there were various causes for the drain, all dependent on user behavior. Meaning, users using certain features would see the drain, others not using them not.
                                    gerasimosG EzioAuditoreE 2 Replies Last reply Reply Quote 3
                                      @isazi now i understand exactly what triggers the problem or one of the main reasons ! 👍
                                      Suunto Vertical Ti
                                      Suunto S9 gen1
                                      Suunto Ambit3 peak
                                      • Mff73M Online
                                        Mff73 @isazi
                                        i am bookmarking this message, i am pretty sure the question will raise again soon 🥳
                                        • EzioAuditoreE Offline
                                          EzioAuditore Gold Members @isazi
                                          @isazi I am always this ‘user’ doing all the wrong stuff 🙂 Not sure though, since I literaly have the same settings and sport use on both the Race and Vertical only different watchfaces. The Race is not showing bat drain the vertical after sport dies in 3 days 🙂
                                          Mff73M isaziI 2 Replies Last reply Reply Quote 0
                                          • Mff73M Online
                                            Mff73 @EzioAuditore
                                            @EzioAuditore
                                            chaos butterfly effect ?
