    Battery drain
      A Former User @Sportsfreund
      @Sportsfreund Apparently, using maps during an activity is what triggers the battery drain.
      SportsfreundS surfboomerangS 2 Replies Last reply Reply Quote 1
      • SportsfreundS Offline
        Sportsfreund Bronze Member @Guest
        @obhikkhu OK, since I mostly move in familiar terrain, I only use it very rarely.
        When I run, the map is always on the display. I run often but still can’t confirm the significant loss.
        • Ars VitaeA Offline
          Ars Vitae Silver Members @Guest
          @Matthieu_45 You can use this temporary solution (one of the earlier posts here):
          @isazi said in Battery drain:
          My personal workaround while we wait for a fix is: if you use navigation just reboot your watch at the end, after syncing the activity with your phone.
          This is my personal view, nothing from Suunto
          I managed to send logs to Suunto and hope a fix for this will be included in the next firmware. I also believe it is not the GPS but the storage that is kept active, GPS would give an even larger battery consumption. No confirmation from Suunto yet. I try to keep the forum informed as much as I can 🙂
          • surfboomerangS Online
            surfboomerang @Guest
            @obhikkhu said in Battery drain:
            It’s not only the map. Following a route also triggers this. Even without the map.
            SuperFlo75S 1 Reply Last reply Reply Quote 3
            • SuperFlo75S Offline
              SuperFlo75 Silver Members Bronze Member @surfboomerang
              @surfboomerang I also noticed this behavior… using the map and following a route during exercises drains the battery more than usual, and after that, the drains continue… perhaps the soft reset can help? I try this…
              @isazi I sent log now, 09:35, I don‘t know if this is useful?
              Suunto Spartan Ultra
              SA iOS 3.5.1 (20789)
              Instagram @superflo75
                surfboomerang @SuperFlo75
                @SuperFlo75 no need to send logs. This has already been confirmed by Suunto. Fix will come soon (hopefully)
                In the mean time, just reboot the watch after a navigation activity.
                • I Offline
                  Iggge
                  I know what caused my battery drain.
                  • Ocan Watchface with compass instead of battery.
                    Last 30 hours I have been using Race watchface and there is no battery drain at all.
                    Have gone from 35% to 33%, and i have also been exercising.
                    Mff73 @Iggge
                    @Iggge
                    It will come again, don’t worry 😂.
                    • stromdiddilyS Offline
                      stromdiddily Gold Members @Iggge
                      @Iggge said in Battery drain:
                      On day 6 now with my watch with two running exercises. Battery left 35%. Right now I need to have it in battery saving mode. Can’t charge it either because I forgot my charger 🫠
                      Soft reset seems to fix the drain issue
                      • gerasimosG gerasimos referenced this topic on
                        MacMillan
                        I am also noticing strange behavior with my Vertical Solar when it comes to solar charging. Sometimes the watch is charged within 15 minutes with a battery level of 95% to 100% by solar charging and on other days without activity and the entire day in the sun there is no charging.
                        SuperFlo75S Tami999T 2 Replies Last reply Reply Quote 1
                          SuperFlo75 Silver Members Bronze Member @MacMillan
                          @MacMIllan I have my SV since 05/23, and there is always a ‚crazy‘ behavior of solar charging when the battery was full loaded on the charger… sometimes ther is no solar activity in plain sun until the charging level dropped under 95%, sometimes the normal behavior of the charging icon comes back after dropping under 98%… and after that, I always recognize that the solar charging can bring the battery back to 100% in about 30 minutes of plain sun… I was told that this is a protection of over-loading… nothing new!
                          • Tami999T Offline
                            Tami999 Silver Members @MacMillan
                            @MacMIllan said in Battery drain:
                            Happens to me too. I think its just show wrong value after full charge. If its 95% -> 100% in 5 minutes by solar charging, its just 100% not 95% in real. 1% of solar charging takes 3h+ from my observation.
                            • AntoineA Online
                              Antoine Bronze Member @isazi
                              A fix is being tested, if everything works out should be here in a week or two.
                              Any news, soon ? 😁 ⌚️⏱️
                              Suunto vertical solar
                              Coros arm HRM / Suunto wing 2
                              Android A55 Samsung
                                isazi Moderator @Antoine
                                @Antoine no, last I know it says September for the hotfix.
                                Robin123R 1 Reply Last reply Reply Quote 2
                                • Robin123R Offline
                                  Robin123 @isazi
                                  @isazi Do you know if the the hot fix is also for the 9pp ?
                                  I purchased my watch 2 weeks ago and the battery is far from what is advertised.
                                  First charge 5 days (with about 5hrs of gps activity).
                                  second charge, this time I disabled the OHR during the day, and pulse ox during the night, as well as stand by display. About 3hrs of gps activity: it was 6 days ago, 18%remaining.
                                  Quite disappointing so far.
                                  isaziI M 2 Replies Last reply Reply Quote 0
                                    isazi Moderator @Robin123
                                    @Robin123 all watches, but in my experience S9PP is the least affected by the drain
                                      MacMillan @Robin123
                                      @Robin123 I agree with you that the advertising claim ( Daily use: Smartwatch mode
                                      up to 30 days (60 days with solar)) is not true. With a fully charged battery, I have a battery consumption (without activity and without HR or Oxi Monitor) of approx. 10 - 12 % within 2 days. The advertised runtimes will never be achieved.This advertised battery life was a reason for me to switch from the Suunto 9 Peak to the Vertical Solar.
                                      Mff73M Ars VitaeA 2 Replies Last reply Reply Quote 3
                                      • MiloushM Miloush referenced this topic on
                                      • Mouse CruiserM Offline
                                        Mouse Cruiser Bronze Member @Klaane
                                        @Klaane My experience vith SV (non-solar) is as follows: in exactly 10 days, the battery charge dropped from 100% to 27%, with the fact that during this time I played sports for 7.5 hours (trail running and MTB). I estimate that the watch consumes 4%-5% of energy per day (with 24/7 OHR), and during sports training 3%-4% per hour (full performance mode).
                                        Suunto 9 Baro
                                        Suunto Spartan
                                        Suunto Ambit3 peak
                                        SvenSchroeterS Mouse CruiserM 2 Replies Last reply Reply Quote 1
                                        • SvenSchroeterS Offline
                                          SvenSchroeter @Mouse Cruiser
                                          @Mouse-Cruiser I can confirm your findings. I am on the same consumption. I average about 2 weeks of battery (100% -> 15%) with an average of 6 - 8hours of gps recoding a week. Minimal notifications because I have dissabled most to try and squeeze more out of the battery.
                                          Suunto Vertical Ti Solar (Daily)
                                          Suunto Race (Wife Daily)
                                          Retired: Suunto Ambit3 / Ambit / Core
                                          https://www.strava.com/athletes/142980701
                                            Mff73 @MacMillan
                                            @MacMillan said in Battery drain:
                                            Et ça fait vraiment avancer le schmilblick.
