    Battery drain
    • Ars VitaeA Offline
      Ars Vitae Silver Members @MacMillan
      @MacMillan As @isazi for ex. and many others wrote in this post the hotfix is on its way, just be patient. In the meantime you can do just a little trick advised here many times. And I don’t know since when you have your SV but mine, from november 2023 with first firmware v. 2.25.66 keep battery life as expected, easily up to 45 days (no solar version). Even with this battery drain but applying temporary solution my battery lasts 4 weeks now with 5 workouts every week and with one exception, it was only charged to 87%.
        EdCaballer
        Hello, I got my suunto vertical on Friday, I was messing arround with it, installing maps until saturday, when i fully charged it. Since then I did 16h of activity until wednesday and now i have a 9% battery!! Do you think it is normal?? What could it be?? Thanks!!
        AntoineA Ars VitaeA ? 3 Replies Last reply Reply Quote 0
        • AntoineA Online
          Antoine Bronze Member @EdCaballer
          @EdCaballer said in Battery drain:
          You have to wait for a hotfix release, coming soon, which should correct the battery drain. Suunto teams are aware of this issue.
          Suunto vertical solar
          Coros arm HRM / Suunto wing 2
          Android A55 Samsung
            Ars Vitae Silver Members @EdCaballer
            Do you guys even take the minimal effort to read at least part of what is included in the post?
              A Former User @EdCaballer
              @EdCaballer Not sure if you’ve read this thread. What is your firmware version? If you have not updated yet, I would try to discharge it to 0% and then charge again to 100% and check if it’s better. If you have the latest version, then you have to wait for a hot fix, unfortunately.
                EdCaballer
                Sorry for not read the previous posts. And thanks for the answers!!! i will whait for the hot fix! I’m also having issues with the sleep traking, it says I’m awake 2 or 3 houers before I do, it’s also a firmware issue?? Is there any post to see the firmware issues??
                Thanks a lot!!
                isaziI 1 Reply Last reply Reply Quote 3
                  isazi Moderator @EdCaballer
                  @EdCaballer to your defense, there are already 507 posts here 🙂
                  Ars VitaeA SportsfreundS 2 Replies Last reply Reply Quote 4
                    Ars Vitae Silver Members @isazi
                    @isazi Don’t demoralize forum members 😉
                    • AntoineA Online
                      Antoine Bronze Member @isazi
                      @isazi said in Battery drain:
                      A fix is being tested, if everything works out should be here in a week or two.
                      Are there still issues to investigate or is there a corrected FW under tests ?
                      I still need to do a still to do a soft reset every week (map + navigation) ?
                      Android A55 Samsung
                      • SportsfreundS Offline
                        Sportsfreund Bronze Member @isazi
                        @isazi but not all with this problem. I don’t have.
                          isazi Moderator @Antoine
                          @Antoine as far as I know, the planned timeframe is still September (and today is only the 17th).
                          • K Offline
                            Kramble @Mff73
                            @Mff73 said in Battery drain:
                            @MacMillan said in Battery drain:
                            @Robin123 I agree with you that the advertising claim ( Daily use: Smartwatch mode
                            up to 30 days (60 days with solar)) is not true. With a fully charged battery, I have a battery consumption (without activity and without HR or Oxi Monitor) of approx. 10 - 12 % within 2 days. The advertised runtimes will never be achieved.This advertised battery life was a reason for me to switch from the Suunto 9 Peak to the Vertical Solar.
                            Et ça fait vraiment avancer le schmilblick.
                            Bien dit Milux 😂
                            Ambit 3 peak saphir
                            Spartan Ultra (sold)
                            S7 graphite copper
                            S9 peak all black
                            Wings
                              Mff73 @Kramble
                              @Kramble
                              y tiens dans la main, y tiens dans la main 😂😂
                              • thanasisT Offline
                                thanasis Bronze Member
                                I think I identified a new pattern for the battery drain without actually starting the exercise
                                1. Navigate to quick start menu of a exercise (eg running)
                                2. Configure setting
                                3. Abort (go back)
                                Did it twice after I had resettled the watch from an exercise and I got like 1% drain per hour on idle
                                Dimitrios KanellopoulosD Ars VitaeA surfboomerangS 4 Replies Last reply Reply Quote 3
                                • U Offline
                                  Ultrawalker
                                  When will the hotfix come?
                                  I wear my Vertical only for exercise.
                                  This week, my watch did nog use for 3 days…watch lay on a table and i saw a battery drain of 30%!
                                  Hope that a hotfix will solve this problem!
                                  Suunto Spartan Ultra
                                  Suunto 9 Peak Pro All Black
                                  stromdiddilyS 1 Reply Last reply Reply Quote 1
                                    Dimitrios Kanellopoulos Community Manager @thanasis
                                    @thanasis said in Battery drain:
                                    Configure setting
                                    Abort (go back)
                                    I ll ping the team
                                      Ars Vitae Silver Members @thanasis
                                      @thanasis How long have you been observing such battery functioning? For how many days?
                                        @thanasis question back
                                        Do you know if “Configure setting” refers to some specific settings, or any?
                                        • C Offline
                                          christhepuma
                                          Since the large software update earlier this year (which annoying reset lots of my custom settings) I am now also getting dreadful battery drain. Typically 10% per day. Before the update I could go a month between charge (in idle) but now I need to recharge every week. Any ideas please? I read of a hit fix coming soon. Is this happening soon?
                                          • thanasisT Offline
                                            thanasis Bronze Member @Dimitrios Kanellopoulos
                                            @Dimitrios-Kanellopoulos i was just playing around. But both times i definitely did :
                                            • changed the S+
                                            • entered the write HR setting (enabled/disabled)
                                            • went all the way down to the last item
